I have a 1999 Isuzu trooper v6 4x4 automatic tranny
I was driving it home it slipped then it would not shift into 2nd. 3rd or 4 the gear we changed the filter and oil no change so I buy on the from junk yard put it in it did the same thing so befor I called them I took it to a good machnice we changed the computer the winter and power button same so I returned it for another on put it in but not realizing the rear seal has 3 screw's in it we put a note on in it shifted but it got hot and blew the seal so we figured it out got the one with the 3: screw's in and it doing the same thing won't shite R works 1st works so I took it to aamco t put on the scanner or what ever it is they said no code came up need to rebuild so I took it to another shop no charge they kept it about a week couldn't figure it out so then I replaced the tranny computer and it still doing the same I need help if any one has any thing to say please help me
Answers
Another thing that needs to be considered with a 19-20 year old vehicle is whether the cost to repair is going to be worth spending. That's going to depend on a lot of things. General condition of the vehicle, how many other things are likely to need to be repaired or replaced going forward (with a vehicle this old, things start to happen)
If it's going to be a couple of hundred dollars and you think that gets you another year or two, maybe that's the way to go. If it's going to be $1,000+, you may be facing the hard choice.
