Max tongue weight for Elantra
JazzyclemmonsJazzyclemmons Member Posts: 2
edited November 2018 in Hyundai
Helping a friend with a car purchase. She likes the Elantra but needs a car that can support a hitch with an electric lift and mobility scooter. I believe the minimum weight is 200lbs but is likely more. Can the Elantra handle over 200lbs? If not, any suggestions for another small sedan?
Best Answer
  • thecardoc3thecardoc3 Member Posts: 5,870
    edited November 2018 Answer ✓
    Why does he need a Class 3?
    Several reasons, the first being the carriers for the chair have more options with the receiver that the class three hitch uses. The class three hitch also connects to a wider section of the subframe spreading the weight and torque over a greater span which is why they can carry 500lbs tongue weight. A class 1 only carries 200lbs and a class 2 is virtually the same price as the class 3.
Answers
