Max tongue weight for Elantra
Helping a friend with a car purchase. She likes the Elantra but needs a car that can support a hitch with an electric lift and mobility scooter. I believe the minimum weight is 200lbs but is likely more. Can the Elantra handle over 200lbs? If not, any suggestions for another small sedan?
Best Answer
thecardoc3
Member Posts: 5,871
Several reasons, the first being the carriers for the chair have more options with the receiver that the class three hitch uses. The class three hitch also connects to a wider section of the subframe spreading the weight and torque over a greater span which is why they can carry 500lbs tongue weight. A class 1 only carries 200lbs and a class 2 is virtually the same price as the class 3.Mr_Shiftright said:Why does he need a Class 3?
1
Answers
