2006 Mazda Tribute 4cyl - Transmission issues
So cat was running fine, parked it in drive for the night. Next morning... nothing... Battery checked out good, starter will turn moter over if i jump it. So with those two checking out good, i noticed that when i turned on the key the dash lights came on like normal but the dash showed it to be in Drive... but the floor shifter was in Park. I checked the transmission to make sure it was shifting as I was moving shifter knob, it was! I cam to the conclusion that the Transmission range sensor (also know as range position sensor, among others) which tell the PCM what gear the tranny is in was bad...so i put in a new one...checked the wiring clips and wire for damage, also made sure the new sensor was aligned correctly and that it moved as i shifted the shifter knob. I was certain that thos was the problem.. it did not fix me.. whats next??? Any ideas?
Best Answer
Mr_Shiftright Member Posts: 64,481
Is your battery now fully charged. If your car is running with low voltage, the various modules in the car will start going beserk. So a fully charged battery and fully operative charging system are essential before further diagnosis can begin.
5
Answers
Maybe you need to start over and explain exactly what the symptoms are and what problem you are trying to solve.
