The air not flowing to the engine
I have a 2008 Envoy, as I start the truck (cold mornings and afternoons) it will start up but will idle and shut off. It will continue to do this until it has warmed up. I will pull off and it will jerk and turn off. It will start back up with no problems. I have had the fuel injector cleaned, the map sensor and throttle replaced. I am still having this problem even after the GMC dealership told me I need to get my fuel injection cleaned because the air wasn't flowing through to the engine as it should, which would explain why the check engine light is on. Has anyone else had this problem?
Please Help
-Frustrated and Confused
Please Help
If the dealer can't fix your car, try this website and click on "repair shops" to see if there is someone close to you. These are very well trained technicians.
http://www.iatn.net/
