Rear axle problem
I have a 1999 Durango with 5.2 4wd and I have rear axle play. Clunks when driving and when I jack up the back of it I can pull the axle shaft back and forth about half a inch freely and I know that’s way more than it should. My question is what would cause that? The wheel bearing on that side or spider gears or some thing else? Any advice would be helpful. Thank you
Answers
End play specification is around .060" . At 1/4" you have wear that could allow the C clip in the above picture to slide off of the axle shaft and then the axle walk out of the differential. Wear could be occurring to the differential pinion gear pin, the internal side gear, the axle shaft and the C-clip.
Here is a video showing normal movement
This one is excessive.
