The 200K Club
thecardoc3
Member Posts: 5,878
Have you driven a car to 200,000 miles or beyond? There are a lot of vehicle owners who don't get to see that kind of vehicle longevity and there are many reasons for that. Getting a car into high mileage range takes a solid service routine and a willingness to fix what ever breaks along the way. Properly maintained today's cars are capable of significant vehicle life and a discussion about just what that takes might help a lot of owners.
This Ford Escape just reached the 200K mark. Along the way it needed several repairs which included a valve job at 176K. I'm looking to see this one go well over 500K barring some catastrophic event, time will tell.
Meanwhile who has their car over 200K?
Over 300K?
Further???
Share your routines and what has had to be fixed along the way.
Over 300K?
Further???
Can't take credit for it, though. We bought it in 2014 with 205K miles.
All it takes is taking care of them
I don't count the chipmunks chewing on my wiring harness as a "car problem" since the Bucket of Death took care of the critters for me
And the payments are usually pretty darn low as well!
Don't believe the engine ever had to be opened up, just regular stuff done for the most part. Never drove it under severe conditions so never got that 3000 mile oil thing done, more like close to 6000 miles with properly specified oil. A few kind of weird things that show up with age like both shift cables and some plastic part for cooling system that did not agree with dexcool (not the gasket thing).
Made for a couple interesting moments also from my sometimes cruel mind when the salesman I was talking to about replacement and he asked if I had trade-in
I shouldn't have said anything. Now, you're going to be listening.
Repairs are starting to become more frequent. Since the first post last year in March I have replaced;
the rear wiper motor,
front hub bearings,
rear door glass hinges (salt corrosion) ,
blower resistor,
rear hatch lift struts,
front brakes and rotors,
the serpentine belt,
and a set of tires.
Maintenance items are;
eight engine oil and filter changes,
two transmission drain and fill, (about 70% of the fluid each time)
Engine and cabin air filters.
The corrosion issues aside the car is in fine working order. If you calculate the total monthly payments for another car, and you total up what the retail value of the repairs and maintenance were, you will see that it has been cheaper to repair than replace. I'll be over 300K before the end of the year with ease and there are no other issues of concern at this time beyond corrosion. The rust through warranty wasn't worth the paper the paper it is printed on. Sacrificing that warranty by having aftermarket under coating applied would have been a wise choice.
Now I have to replace the door locks (auto-lock doesn't work--gears inside strip out, very common), and recharge the AC. Then we'll be 100% again!
With high mileage cars, you have to stay on top of them, or all these little breakages can render the vehicle barely usable even if it does "run" well.
The fog lights were a ROYAL PAIN---obviously, Dodge installed the bumper and headlight assemblies after it inserted the fog lights.
My oldest daughter IS getting close to 200K on her 2007 Versa hatchback. But with a first child due any moment, they're thinking of replacing her car, so the milestone may not be reached.
I'm sure you can still do it though. Just got to stay on top of the maintenance!
This year had to replace the front control arms (includes ball joints and bushings), as mentioned elsewhere the cylinder head was replaced due to a burnt valve. Regular maintenance on the ignition system which means coils and plugs. Replacing the coils protects the PCM since it is the ignition module.
Three drain and fills on the transmission which amounts to six of the nine quarts that it holds each time.
Twelve oil and filter changes.
Other than the corrosion issues the car is working just fine.
Expect to reach 400,000 sometime in 2020.
pdfs to me while I am driving.
Onward towards 400,000.
As the years have passed by the Ford specification has advanced and improved. It started with a 5W20 that met WSS-M2C930-A which is what I believe your Escape called for. Then it went to WSS-M2C945-A. Today the current specification is WSS-M2C960-A1.
You can find out more at.
http://www.fcsdchemicalsandlubricants.com/Products/Details?cid=70&pid=394
And research the differences in the specifications at
https://online.lubrizol.com/relperftool/pc.html
