Suburban stalls
I have a 2003 suburban that stalls while driving, mostly during the afternoons when it is about 95° out.
Have looked at quite a few forums and have already replaced numerous parts
Replaced spark plugs
Air filter
Camshaft position sensor
Crankshaft position sensor
Fuel filter
Drives fine in morning and late evening hours, but during the day it will lose power, and stall. When gas pedal is depressed seems to backfire and stutter. When it finally dies after about 5 minutes it will restart, but usually dies 10 minutes later. At a loss for what else it could be any help is greatly appreciated!
Air filter
Fuel filter
Answers
Every stalling event is different. There's no one cause you can "find" just by asking. It could be caused by many things.
If you have some basic diagnostic tools like a spark tester and a fuel pressure gauge, when the truck stalls, and if it won't start right up again, you could check to see if you have lost spark or pressure.
If it is stalling and starts right up again, this could be electronic or an air/fuel mixture problem .
Thank You in advance.
