2019 Nissan Armada Lease Deals and Prices
24
  • kyfdxkyfdx Moderator Posts: 272,623
    tdog55 said:
    Can you please privide this month's numbers for a 2019 Nissan Armada Platinum AWD, 36/15?
    What is your location?
  • tdog55tdog55 Member Posts: 3
    Central NJ
  • MichaellMichaell Moderator Posts: 268,929
    Central NJ
    .00174 and 55%
    $2000 NMAC lease cash
    $1000 Dealer cash
    Central NJ
    .00174 and 55%
    $1000 Dealer cash
  • bbc3vbbc3v Member Posts: 5
    Hi! Can I please get numbers for Platinum 4X2, 36/15 in 78731? Thank you!
    .00174 MF and 52% residual
    $4100 customer lease cash
    $1000 dealer cash
  • mpgxsvcdmpgxsvcd Member Posts: 179
    edited May 2019
    Looking at the numbers it appears that this is the only Nissan car where the 24 Month numbers are better than the 36 month numbers. Is that correct? Plus 9% is a big jump for going from 36 months to 24 months.
    It looks like you could get the SV Armada at one point for under $300 a month for 24/12. That is at least a $49k vehicle. If you can put up with cloth seats and no frills that is a lot of car for the money.
    Correct, 9% on this trim in 2WD
  • JGRTJGRT Member Posts: 1
    Hello!
    Looking for numbers on AWD SL for 36/15 in 43560. Thanks
    JGRT said:
    Hello!
    .00174 and 58%
    $4100 incentives
  • speedfreak81speedfreak81 Member Posts: 4
    Hi can I get MF/RV & incentive numbers for a 19 Armada Platinum 4WD 36/15 in 20152? Thanks
    .00174 and 55%
    $2000 incentive
    .00174 and 55% $2000 incentive
    Thanks! Are the numbers any different for a 12k mileage?
    .00174 and 55%
    $2000 incentive
    plus 1%
  • srr22980srr22980 Member Posts: 48
    Platinum awd
    36mo 10k mile and 48mo 10k mile lease mf and residual?
     zip 52205
    Please and thank you.
    srr22980 said:
    Platinum awd
     zip 52205
    36/12 (only term available close to your request)
    .00175 and 56%
    $3725 incentive
  • will102will102 Member Posts: 1
    Hi! can you give me numbers for a Platinum 2WD 36/12 , zip 91737. Thanks!
    .00175 MF and 53% residual
    $1000 dealer cash
    AWD residuals are 3% higher, if you decide to go that way.
  • Hud1Hud1 Member Posts: 1
    Good evening, looking for numbers for 2019 Armada 2wd Platinum, 36/12 for zip code 34997. Thanks for your help.
    .00175 and 53%
    $1000 dealer incentive
  • givemeadeal2givemeadeal2 Member Posts: 14
    Can I please have the MF, RV and Incentives 75229 24/12 and 36/12k on a SL. Appreciate it.
    RWD or AWD?
    both please
    both please
    .00175 MF
    67%/59% residual for AWD
    65%/56% residual for RWD
    $4100 customer incentive
  • chicitycodychicitycody Member Posts: 25
    Could you please provide numbers for a 4wd SV 36/12k 39/12k in 60053
    .00175 MF and 60% residual
    $3975 customer incentive
    39 mo term is not supported
  • aekchianaekchian Member Posts: 66
    24/10 and 36/10 numbers please for SL 4x4 trim and Platinum 4x4 trim.
    91206
    91206
    .00175 MF
    SL: 67%/59% residual for 24/36 mo, 12K/yr
    Plat: 64%/56% residual
    If 10K/yr is available on the Armada (and, I think it might be), add 1% to residual
    Any lease incentives or is that just for other areas? I saw some on the SV trim.
    Oops.. sorry.
    Lease terms please for
    77001
    SL 4WD
    77001
    SL 4WD
  • Sam_JaySam_Jay Member Posts: 26
    Hi Guys,
    What's the MF, Residual and lease credits for a 2019 Armada Platinum AWD, 24/10K. Zip 75070
    Thanks a lot!
    Sam_Jay said:
    Hi Guys,
    Thanks a lot!
    24/12 (no 10K allowance from Nissan)
    .00137 and 61%
    $3725 incentives
    Can I please have the MF, RV and Incentives 75229 24/12 and 36/12k on a SL AWD and RWD. Appreciate it.
    .00137 MF
    $3725 incentive
    AWD: 65%/57% residual
    RWD: 61%/55% residual
    Can I please have the MF, RV and Incentives 75229 24/12 and 36/12k on a Platinum AWD and RWD. Appreciate it.
    AWD: 61%/54% residual
    RWD: 58%/51% residual
    Otherwise, same numbers as SL
  • bamatacobamataco Member Posts: 3
    Can I please get the MF, RV and incentives 37355 36/12 on a Platinum 4WD? Thanks!
    .00137 and 54%
    $3725 incentives
  • Hooch252Hooch252 Member Posts: 4
    Good afternoon -
    Can I please have the MF, RV and Incentives:
    Platinum AWD
    60048
    36/12k & 36/15K
    Thank you in Advance!
    Hooch252 said:
    Good afternoon -
    Platinum AWD
    60048
    36/12k & 36/15K
    .00137 and 53%
    $3725 incentives
  • derekd1972derekd1972 Member Posts: 2
    Good afternoon. Could I please have the MF, RV, and Incentives:
    SL AWD
    Platinum AWD
    44202
    36/12 & 36/15
    thanks!!!!
    SL AWD
    Platinum AWD
    44202
    36/12 & 36/15
    thanks!!!!
    .00137 MF
    56%/53% residual for SL/Plat
    $3725 incentive
    Add 1% for 36/12
  • rbarnum1rbarnum1 Member Posts: 23
    Good afternoon -
    Platinum / SL RWD
    77304
    36/15k
    rbarnum1 said:
    Good afternoon -
    Platinum / SL RWD
    77304
    36/15k
    .00137 MF
    54%/50% residual for SL/Platinum
    $4725 incentive
  • Lukin70Lukin70 Member Posts: 3
    Can I please have RV, MF, and incentives for:
    SL AWD / Platinum
    36/12k
    Zip 08096
    SL AWD / Platinum
    36/12k
    Zip 08096
    .00137 and 57% (SL) or 54% (Plat)
    $3000 incentives
  • ArmadafanArmadafan Member Posts: 1
    Hi, I am new to the group and working on my first lease. Thank you in advance.
    Platinum AWD
    Zip: 19027
    36/10k & 36/12K
    Platinum AWD
    Zip: 19027
    36/10k & 36/12K
    .00137 MF and 54% residual
    $3000 incentive
    If 10K/yr is available on the Armada, add 1%
