Cobalt reliability?
How reliable is the Cobalt? I read the forums and even Cobalt owners roast the car. Is unreliability the reason GM got rid of the Cobalt? I'm worried because my Cobalt is about to hit 100,000. I also heard that workers at the factory that made the Cobalt purposely sabotaged the car because they were mad at management.
Here's a general OVERVIEW of the car's reliability. As you can see, in some areas it's good and in some pretty mediocre.
After 100K, you'll going to have to expect to spend some money on maintenance and repairs---things do wear out, after all.
Where the Cobalt was built, Lordstown, OH, was known forty years ago for worker sabotage, but it's forty miles down the road from where I live and I think I'd have heard something like you're saying, lately, if it were really the case.
It did develop a noise in the intermediate steering shaft, much like some of the H-bodies did.
The dealer is replacing parts that have worn causing the noise under the extended GM warranty that I bought before the original 3/36 was up.
Earlier it had a noisy auxiliary air pump that pushes air into the exhaust on certain cold starts to fire up the catalytic converter quicker to get the low emissions on startup. That was replaced under warranty (emissions?) and after good advice from cardoc3 on here I replaced the diverter valve on the exhaust manifold myself--2 bolts and a couple of gaskets. That valve closes off the exhaust port when the air pump is not pushing air. But these sometimes leak exhaust into the long tube going down to the air pump on bottom of the engine. That exhaust leak can cause damage to the air pump with the hot corrosive gases.. So I replaced the valve myself with an ACDelco branded part for a hundred or so plus the little high temp gaskets. That protects the new air pump.
The engine is great. Good mileage for a PZEV. Transmission has been perfect. The ride is good. I have Michelin tires on it. Just took it back from my son who now drives a '15 Cruze 2LT to work. I expect the same service level from the Cruze.
How was the car driven? Town? By whom was the car driven and in what manner?
When was the transmission serviced? 50,000 miles for an oil and filter change in the transmission?
