2019 Nissan Rogue Lease Deals
MiteyJoeMiteyJoe Member Posts: 28
edited May 2019 in Nissan
Can I please get the MF, Residual and Incentives for both the Rogue S and SL AWD 36 / 12
  • MichaellMichaell Moderator Posts: 270,433
    Whatis your ZIP code?
  • MiteyJoeMiteyJoe Member Posts: 28
    Sorry, zip code is 19083
    Actually, can you make the model the Nissan Rogue SV FWD? Everything else stays the same.
  • kyfdxkyfdx Moderator Posts: 275,136
    .00101 MF and 55% residual
    $2325 incentive
  • toe22222toe22222 Member Posts: 13
    Can I get RV, MF and incentives for 2019 Rogue S, SV & SL (FWD) on 36/15 for 35226.
    S/SL: .00003 MF and 49%/52% residual
    SV: .00101 MF and 54% residual
    $975 incentive
    $975 incentive
    Does MF typically change monthly or quarterly? Trying to decide if I should wait and hope July MF stays the same and RV increases.
    $975 incentive
    RV rarely, if ever, goes up as the year progresses.
    The numbers could change every month.
  • hello,
    can I get the MF, residual, and lease credits for a 2019 Nissan Rogue SL AWD, 36m/10k, zip 11763
    thank you!!
    hello,
    thank you!!
    36/12 (no 10K from Nissan)
    .00003 and 51%
    $3400 incentives
  • Jon82JonJon82Jon Member Posts: 3
    Can I get the MF and Res Value for 2019 Nissan Rogue S AWD 12/36 in 95843?
    .00020 and 49%
    $2200 incentives
