Overheating
Need help still running hot I took the thermostat out the radiator is leaking will stop leak work and are the heads blown even if no water in oil or smoke
Answer some questions:
Fast overheat or slow overheat (how long does it take from a cold engine)
Overheats at idle only and ok on highway, or ok at idle, overheats only on highway, or both.
Is coolant currently leaking out somewhere.
Can you hear/see the cooling fans kicking in at some point?
