Mystery car pix
1109911001102110411051475
  • andys120andys120 Member Posts: 23,676
    edited August 2019
    This brings back memories, my first sports car looked like this right down to the silver painted wheels which were originally white. My avatar photo shows me behind the wheel of it.
    Posted via Firefox 8/12 @ 8:57AM EDT.
  • ab348ab348 Member Posts: 20,493
    I'll leave the ID to someone else but the pic raises a question: is that a crank hole at the bottom center of the grille?
  • fintailfintail Member Posts: 58,671
    Given the origin of that car, there's a good possibility it at least has crank potential.
  • stickguystickguy Member Posts: 53,853
    Maybe a PTO from the engines days In a tractor?
    It’s a TR4. Love those. Not sure if a sub model though (an A?)
    The crank hole in the grille was not functional. It was a carry over from the TR-2/-3
    which did come with a crank in case Lucas went on strike. TR-4s and 4As still had the hole
    but the TR-250/TR-5PI dropped it.
    Sports car legend has it that the 4-banger used in the TRs was originally a tractor motor.
    I think it's entirely possible since it had quite a bit of low-end torque, it redlined @ 5000 but there was little extra power beyond 4200 .
    The pictured car was a 1962 TR4 from the second year of production. The TR-4A with a revised chassis and optional IRS came along in 1965.
    Mine was a 1966 TR-4A with the leaf-sprung solid axle rear suspension.
    The VW Thing in the 70's could be started with a hand crank. And didn't need a crank hole in the radiator. :)
    https://www.youtube.com/watch?v=uFEVNL9Je7w
  • tmarttmart Member Posts: 2,414
    Nice looking 56 Plymouth.
    Looks like a Fury from the pix. Didn't know it came out before the 57's.
  • lostwrench1lostwrench1 Member Posts: 1,165
    And, there is a 1959 Fury in there too.
  • bhill2bhill2 Member Posts: 2,617
    Of course, by then the Fury was just the posh trim level. If you wanted the 'special' model you had to get a Sport Fury.
    Firefox surprisingly back on the job this morning.
    Mostly interested in the vehicle front and center but there are a couple of others here too. Cool pic, regardless.
    The grey one is a Nash ca.1949-50, probably an Ambassador.
    Woody appears to be a 41-48 Ford, maybe impossible to narrow further with this angle.
    Tu-tone Chevy coming from behind the sign could be a '55 or '56.
    72 escort RS?
    Is that the Mexico model Escort?
  • magnettemagnette Member Posts: 4,237
    edited August 2019
    On that Australian picture there was a Ford Cortina - to the far side of the Holden FC wagon - and the grille on the Cortina looked like the one we had on the lowest spec early Consul Cortina for 1962/3 with wide slats, whereas the ;rest here had a more detailed grille. That may be due to the need for better ventilation in Australia.
    However the chrome lettering across the lip of the bonnet appears different from anything we had too.
    I think the Cortina was assembled locally there by Ford presumably at the same plant where the locally produced Falcons and other US models were assembled.
    edited August 2019
    72 escort RS?
    Pretty close, it's a 1973 Escort Mk1 modified as a replica WRC car, so close to a Mexico or RS version.
  • texasestexases Member Posts: 11,163
    Vector M12?
    texases said:
    Vector M12?
    Close enough for g'ment work, it's a 1993 Vector W8.
    Let's see if I can load via Firefox>
    Eureka!
    1961 Ford Falcon.
    That must be fun to drive in today's traffic.
    That era Falcon seems to have a surprising survival rate, given their rustability.
    1961 Ford Falcon.
    Exactly, what gave away model yr.?
    andys120 said:
    1961 Ford Falcon.
    No wide "hood scoop", side strip did not widen at its front end, and it has a convex grille.
    Looks like a Corvair gathering with the coupe, convertible, and wagons.
    A red 1962 Corvair and behind it, a 1961 Corvair Lakewood wagon.
    Yup, the red car is captioned as a 1962 Corvair Spyder but IIRC ought to be titled a Corvair Monza Spyder.
    Once again I have to ask how you knew it was MY '62? Was it the spiffy faux wire wheels?
    edited August 2019
    You can see enough of the front end to identify the year. A black and chrome bar on either side of the center of the front is the giveaway.
    Yes, there is not a single horizontal bar across the front but rather two horizontals with a space between them containing a badge.
    Ok, and why is the Corvair Lakewood wagon behind it a '61?
    edited August 2019
    Because Corvair stopped using "Lakewood" after 1961?
    Some unreliable piece of junk according to Scotty Kilmer. :laughing:
    The last year of the Corvair Lakewood wagon was 1962.
    Two easy ways to see that one is a 1961 is that there is no red plastic surround in the backup lights and the top badge of the hatch has a point on its bottom.
    I remember the TV show "Bonanza" having Chevrolet as one of its major sponsors. One of its commercials had "Little Joe" Cartwright driving a coupe or 4 door Corvair through a swampy area and the Corvair "with its engine over the drive wheels" did not get stuck. I thought, wow, that's the car I want when I get a driver's license. Never did own one but drove my cousin's Corvair Coupe and it was a fun drive, not safe with its gasoline tank up front, but fun.
    Anyone remember the other Bonanza Chevy TV commercial which showed a line of various Chevrolet vehicles, in line, crossing the desert with the song "Chevrolet, Ole. We made the Baja Run. Toughest run, under the sun. Chevrolet, Ole." That's Ok, you don't have to answer and show your age as I just did.
    In '62 the Corvair offered the Monza and 700 station wagons.
    Lakewood seems to be a 1 year only Corvair wagon in 1961.
    You are correct. Although the wagon was made in 1962, the name "Lakewood" was not used. I based the Lakewoods' existence on numbers made, which listed 1961 Lakewood - 20,451 and 1962 Lakewood - 3716. They should not have listed the '62 wagon as Lakewood.
    I always liked the Corvair - it would probably have had an unblemished reputation if sold just in mainland Europe with the wide range of rear engine cars - not just VW but Fiat, NSU, Tatra, Renault, Simca even Hillman.
    Wasn't it mainly dangerous only if the tyre pressures were neglected - which applies to all the above as well I think.
    edited August 2019
    Well, the problem was the recommended pressures (15/28 front/rear cold, 18/33 hot) were WAY different than any car most Americans (or gas station folks) had ever dealt with. They'd fill them up to 'normal' pressures, say 28/28, and the bad handling would occur.
    Beetles weren't as extreme, 18/27 or so, but I wonder how they handled if the specs were ignored.
    edited August 2019
    Here's a cool pic, circa 1972 or '73 I think, of what seems to be the intersection of La Cienega Blvd and Santa Monica Blvd. in Los Angeles. Can't imagine there would be so little traffic there today.
    Firefox still on strike against images, Chrome to the rescue!
    ETA: That motel sign you see belonged to the Alta Cienega Motel (still there) which is where Jim Morrison of the Doors lived in the '60s. He was friendly (ahem) with several of the dancers/strippers working at The Phone Booth, apparently.
    edited August 2019
    i wonder if that Petersen building is related to the Petersen Car Museum.
    2 past the chevy wagon with roof bag, is that a ramble, or a late run Stude? 62ish Corvair other side of wagon. Can't tell what that is right next to the wagon. Square. Looks like a Rebel?
  • imidazol97imidazol97 Member Posts: 27,731
    Ford near the far end under the saloon sign: 1957 Fairlane 500 two-door sedan. in Neptune Green with white.
    The car past the 67/68 Chevy wagon looks like a Rambler to be circa 1965-67.
    The pair of taillights next to the Chevy, belongs to something small, perhaps a Triumph Herald or a Hillman Minx.
    Definitely a '57 Ford and the oldest car in the picture (the only 1950s iron.)
    The hardtop had a narrower combination of chrome than the faux hardtop with chrome covering the door frame on the front. The wider chrome is why I said it's a two-door sedan. . I had one back in the day.
