What do you think of lease offer - 2019 Audi Q5 Premium Plus
SaintsDSaintsD Member Posts: 11
edited September 2019 in Audi
Msrp $53,745
RV 54%
MF 0.00116
10K/36mos
$625/month all in (zip 90712)
Including costco’s 10% discount with no other incentive.
Best Answer
Answers
  • MichaellMichaell Moderator Posts: 270,997
    SaintsD said:
    Msrp $53,745
    RV 54%
    MF 0.00116
    10K/36mos
    What is the selling price?
  • SaintsDSaintsD Member Posts: 11
    @Michaell its at $48,300+
    Initial payment was at $690+ then i countered and after few hours of back and forth, the above was what they offered. Does the number make sense?
    I get $625/mo, as well.
    However, I show the base MF as .00047 for the Q5.
    Tell the dealer you won't sign anything unless you get the base MF; the hike is adding over $50/mo to the payment
    @Michaell appreciate you looking into this. If i can get even close to $50/month reduction from $625 now, i will go for it right away. Will let em know bout base MF. Thanks!
    Don't quote the number - they know what the base rate is.
    Just tell them you want it or you'll find a dealer more accommodating.
    Ok @Michaell will do that exactly. Would you mind sharing how you duplicate the number using the lease calculator? Having a hard time playing with the digits.
    @Michaell thanks so much. Thisd be helpful!
  • raz0407raz0407 Member Posts: 30
    @SaintsD curious where u landed on your negotiation? i am in your area too, looking same car/trim. appreciate you sharing your numbers, really helps get to the bottom line.
    1
    SaintsD said:
    1
    not sure if it was a typo. pls share the numbers if its possible
