Top 7 Urban Legends About Motor Oil | Edmunds
edited October 2019 in General
Urban legends, lies and distortions surround oil changes and engine oil use. We bust the myths and reveal the truths about the top seven urban legends about oil.
  • LimoPhilLimoPhil Member Posts: 1
    My college professor says oil never loses its viscosity. He said if you change the oil filter regularly, that your oil would stay clean enough to continue to lubricate properly for years
  • kyfdxkyfdx Moderator Posts: 271,645
    That assumes the filter is 100% efficient.
    Then, you would need to know the filter change interval. If it's the same as the oil change interval, I can assure you oil does not stay clean enough to keep running, ad infinitum. All you have to do is look at it, at the end of the cycle.
    Nonsense. Oil is made up of several components, some of which are used up with miles. What kind of a professor is he?
  • IsabellamasonIsabellamason Member Posts: 2
    Thanks for sharing information in your blog
    Thanks for sharing a beautful information in your page
