2020 Chevrolet Colorado Lease Deals and Prices
2
  • Nmorales02Nmorales02 Member Posts: 23
    Hi. Looking for MF, Residual value and any incentives on the 2020 Chevrolet Colorado LT Crew cab 4x4. 36 months, 12k miles. Zip is 22003. Thanks
  • kyfdxkyfdx Moderator Posts: 273,973
    .00118 MF and 60% residual
  • Drgrady0725Drgrady0725 Member Posts: 4
    Looking for money factor, residual value, and any incentives on 2020 Chevy Colorado Zr2 Crew Cab Long and Short Box with 4WD in 61356. 36/10k.
  • MichaellMichaell Moderator Posts: 269,764
    .00168 and 65%
    No incentives
  • bzogbzog Member Posts: 11
    edited April 2020
    Hello, may I please have MF and RV for 2020 ZR2 4x4 Crew Cab in 61821, for 24/10k? Thank you!
    .00219 and 71%
    No incentives
  • BigGreenBigGreen Member Posts: 2
    Hi. Looking for MF, Residual, and incentives for 2020 ZR2 (Bison), crew cab, short box for zip code 90049. 36months/12k miles.
    Also, if available the same figures for the upcoming 2021 ZR2 (Bison).
    Thanks in advance.
    Thanks in advance.
    .00168 and 64%
    No incentives
    No numbers this month for the 2021 Colorado.
  • GasdonGasdon Member Posts: 5
    edited May 2020
    Hi I’m looking for mf rv for a Colorado zr2 crew long and short bed 36/12,36/15,36/18. 2020,4x4 Thank you.11740
    What is your location?
    We only have residuals up to 15K/yr
  • e46guye46guy Member Posts: 75
    Good morning,
    Can I please have the MF and residual for a Colorado ZR2 Crew Cab short bed 4x4 for 36/12 in 84095. Any difference in the Diesel MF and Resid?
    TIA.
    .00168 MF and 62% residual
    e46guy said:
    Good morning,
    TIA.
    .00168 MF and 64% residual
    All engine choices
  • guille82guille82 Member Posts: 45
    Hello, can I please have the lease program numbers for a 2020 Chevy Colorado Crew Cab Short Box 2 Wheel Drive WT in Miami, FL 33125. Lease would be for 36 months and can I have numbers for both 10K and 12K miles per year. Thanks.
    .00126 MF and 60% residual
  • trickracentrickracen Member Posts: 86
    Hi can I get R/MF for ZR2 Crewcab, 3yr 12k and 4yr 12k. Zip 91311, and any incentives. thanks
    Flyinfish said:
    sorry if this is the wrong place for this question, but what is the minimum credit score needed in order to get the MFs quoted here?
    700+ is tier A1, which is everything quoted here.
    A2 680-699 add .00063
    A3 660-679 add .00108
    B1 620-659 add .00206
    B2 580-619 add .00283
    B3 <580 add .00313
    B3 <580 add .00313</p>
    Forgot to mention, they use Transunion
    36/12 - .00168 and 64%
    48/12 - .00178 and 57%
    No incentives
  • caltmancaltman Member Posts: 287
    edited May 2020
    May I have MF and residual for 2020 Colorado Crew Cab Short Box 4WD ZR2 for 15k/24mo and 36mo in Minneapolis please? Any other month length with better sweet spot? Any incentives?
    24/15 - .00219 and 69%
    36/15 - .00168 and 62%
    no incentives
  • t_davis1t_davis1 Member Posts: 12
    Are the June lease deals out yet? I am looking for MF and residual on 36/15 and 24/15 Colorado 4WD LT for ZIP 60503.
    May I have MF and residual for 2020 Colorado Crew Cab Short Box 4WD ZR2 for 15k/24mo and 36mo in Minneapolis for June please? Any other month length with better sweet spot? Any incentives?
    .00141 MF and 65% residual
    .00135 MF and 59% residual
    24/15: .00219 MF and 69% residual
    36/15: .00151 MF and 61% residual
    Nothing better than 36 months
  • zepontiffzepontiff Member Posts: 7
    edited June 2020
    Could I please get the MF and residual for the following for a 36/10k lease:
    Crew Cab 4X4 LT
    Crew Cab 4X4 Z71
    Both long bed and diesel if that matters
    Still a lease loyalty this month?
    Zip: 58103
    Also if I buy somewhere else do they still use my home zip?
    Crew Cab 4X4 LT
    Crew Cab 4X4 Z71
    Zip: 58103
    LT: .00135 MF and 61% residual
    Z71: .00129 MF and 61% residual
    $1500 lease loyalty
    Most likely, it is the dealer's location that matters.
  • WobbleWobble Member Posts: 8
    edited June 2020
    I would appreciate MF, Residual, and incentives for 36/15k in 93003 for Crew, Shortbed, 4wd, WT
    .00126 and 58%
    No incentives
  • pcarrollgpcarrollg Member Posts: 17
    I was wondering if someone could provide the MF and RV for a 36 month / 12k mike lease for a z71 and a zR2 Colorado. I’m located in 12065 and am currently leasing a Cruze.
    Z71 - .00129 and 61%
    ZR2 - .00151 and 63%
    No incentives
  • russ120712russ120712 Member Posts: 17
    What is MF, residual and incentives for 2020 Colorado 4x4 crew cab short bed both LT and Z71 models for 11729? thanks in advance
    36/10000 or 39/12000
    LT
    .00135 MF
    61%/58% residual
    Z71
    .00129 MF
    61%/58% residual
  • jcalvarez97jcalvarez97 Member Posts: 10
    Hello, I'm looking for MF/Residual for a 2020 Colorado Z71 Trail Runner Special Edition 4x2 with lease terms of 36/10 and 39/10. If any incentives for 33155 also would be nice. Thanks in advance for the help!
    .00129 MF
    62%/59% residual
    HI, can I get MF/R for Crewcab ZR2 3yr/12k, Zip 91311 and any incentives.
    .00151 and 63%
    No incentives
    Hi, I was wondering if I could have the MF, RV, and any incentives for a Crew Cab Short Box 4-Wheel Drive LT RST Special Edition, and for a Z71 4WD Crew Cab Short Box? For 36/12 and the location is 12065.
    LT: .00125 MF and 61% residual
  • RT_ZeroRT_Zero Member Posts: 46
    Looking for the MF, RV, and incentives for a 2020 Colorado ZR2 Turbo Diesel. Zip is 91730.
    *Z71 turbo diesel, sorry about that
    12K miles/36 months & 45K miles/36 months
    .00129 MF and 59% residual
  • Legionx39Legionx39 Member Posts: 16
    MF/RV/Rebates
    2020 COLORADO Crew Cab Short Box 4WD WT
    zip 08053
    Legionx39 said:
    MF/RV/Rebates
    zip 08053
    Would MF and RV be the same for any colorado in my zip or would it change if the trim changed?
    If it changes can I have info for the below?
    MF/RV/Rebates
    2020 COLORADO 4WD Z71
    zip 08053
    MF/RV/Rebates
    zip 08053
    .00129 and 61%
    No incentives
