blend door
                    I broke the post on my hot/cold blend door and had it screwed/epoxied for 2 yrs now it is loose again and won\t stay together with epoxy.How hard is it to replace the blend door itself or should I just continue to change from hot to cold manually?(I drilled a hole in the plastic and use a thin hooked rod) Thank You in advance
