replacement tire recommendations needed...
I am looking for some recommendations for an all-weather tire for my AWD Mazda CX-5 Grand Touring...the tire size is P225/55R19...I live in Missouri so we get some snow and ice but nothing like Chicago...thanks
Once you have made those choices, go to Tire Racks website. They have a Decision Guide under their Reaseracvh and Advice to help you decide.
It's a great website for choosing tires, even if you aren't buying from them.
In 2014, 19" tires weren't as prevalent, and most of them were V-rated. I doubt TireRack would recommend a tire that didn't meet the requirements of your vehicle.
From a general standpoint, H-rated tires are good up to 130 MPH.
You might check the load factor required of your tire, as well.
It appears that the V- and H-rated tires all have the same 99 load rating. If Tirerack is putting them up there, you should be good.
But, that still won't guarantee that the wheels have the proper offset and backspacing. A test fit is the only way to know for sure.
