2020 Chevrolet Suburban Lease Deals and Prices
2»
  • Wolverine_1Wolverine_1 Member Posts: 4
    edited May 2020
    Can I get the MF, Residual and Incentives for 2020 Suburban LS, LT, Premier for 36mo, with 10, 12 & 15k miles, in 48642
  • MichaellMichaell Moderator Posts: 260,196
    LS - .00104 and 54%
    LT - .00135 and 51%
    Prem - .00075 and 46%
    No incentives
    edited May 2020
    LS - .00104 and 54%
    LT - .00135 and 51%
    No incentives
    Can I please also see the 12k & 10k mile MF & Residuals?
  • kyfdxkyfdx Moderator Posts: 262,539
    LS - .00104 and 54%
    LT - .00135 and 51%
    No incentives
    +2% or +3%
  • MattNJ2020MattNJ2020 Member Posts: 1
    Can I please get the MF, Residual and Incentives for a 2020 Suburban LT 4WD for 36mo with 10k miles. I live in 07302 but the dealership is located in 02062 (not sure which one matters for the purposes of this calculation). Thanks so much in advance!
    .00135 MF and 54% residual
    Dealer location
  • BFLOBILLBFLOBILL Member Posts: 1
    Can you share the MF, Residual and Incentives for a 2020 Suburban LT and Premier Trims. 36 months 12 miles.
    33483 Zip code. Thank you in advance!
    LT: .00135 MF and 53% residual
    Prem: .00075 MF and 48% residual
  • LittleGlassesLittleGlasses Member Posts: 2
    Looking for the money factor for a 2020 Suburban LT 4WD, 39 or 36 month lease, 12,000 miles per year.
    What is your location?
  • sector16_sector16_ Member Posts: 2
    2020 Suburban Premier, MSRP $71,195. Telling me 46% residual on 39 month lease, 12k miles. Wants $3500 down, and payments of $1224. Seems very high and very low residual to me. Zip code 33472.
    got the residual up to 48% on a 36, but with all the extra fees, with $0 down they have the payments at $1378. Too much for that SUV. full cost with fees and tax over 80k
    .00075 MF
    48%/46% residual for 36/39 mo
    No Suburban leases well, but the Premier trim is the worst.
  • EfecktEfeckt Member Posts: 13
    I would never pay that. You could work a deal on a limited or platinum max Expedition 3k down low $700s or zero down low $800s. Newer tech, second row seats slide, parks itself, panoramic sunroof etc. At least drive it before you buy a GM.
  • edubpmdedubpmd Member Posts: 29
    Please if you don't mind
    RV and MF for...
    2020 Suburban - Both LT and Premier
    39/12
    Zip 11747
    RV and MF for...
    39/12
    Zip 11747
    LT
    .00135 MF and 52% residual
    Premier
    .00075 MF and 46% residual
    Need MF/RV for 2020 LT 2WD
    Zip 92337
    39/10
    Much appreciated!
    Zip 92337
    39/10
    Much appreciated!
    .00139 and 53%
    No incentives
  • cdeed50cdeed50 Member Posts: 47
    Hi - looking for July residual value and money factor for 2020 Suburban in zip code 21754
    -36 or 39 months/15k LS FWD
    -36 or 39 months/12k LS FWD
    -36 or 39 months/15k LT FWD or AWD
    -36 or 39 months/12k LT FWD or AWD
    Any incentives?
    Any incentives?
    LS - .00104 and 54% / 52% for 36/39 months and 15K
    LT - .00135 and 51% / 50%; either drive
    No incentives
  • brandloyal21brandloyal21 Member Posts: 24
    Please provide MF, RES and any incentives for 2020 Suburban LT 4WD, 36mos/15K miles year in 02420
    .00135 MF and 51% residual
  • frenchiemutfrenchiemut Member Posts: 15
    MF, RV and incentives for 2020 Suburban Premier Plus 4wd, 36/12 in 66221
  • Nakattack42Nakattack42 Member Posts: 9
    Good Afternoon,
    Looking for MF, RV and incentives for 2020 Suburban RST 4wd, 36/12, 48820
    Good Afternoon,
    I don't see that trim for a 2020 Suburban
    Good Afternoon,
    I believe it to be an LT
    Good Afternoon,
    .00135 and 53%
    No incentives
    FWIW, there is an RST specific trim for the 2021 model year.
  • jknastjknast Member Posts: 5
    Can you provide the MF and RV for Suburban LT and Premier, 4WD, 36mo/12k and 39mo/12k. Thanks in advance!
    08033. Thanks.
    08033. Thanks.
    LT: .00135 MF and 53%/52% residual
    Prem: .00075 MF and 48%/46% residual
    $500 customer incentive
    08033. Thanks.
    Thanks for the info. The dealer I am working with is adamant that the residual is 44% for 39 months and 46% for 36 months for the Premium. Will different packages cause the residual to go down?
    jknast said:
    08033. Thanks.
    Nope.. guessing he is reading the number off the chart (which assumes 15K/yr).
    +2% for 12K/yr
  • ma60521ma60521 Member Posts: 2
    Can I get the new MF, Residual and incentives on a 2020 Suburban Premier, 4WD, for 24/36/39 months (or any other sweet spot you see) and 12k miles in 60521? Thanks!
    .00123 and 55%
    .00075 and 48%
    .00075 and 46%
    $500 incentive
  • cable23cable23 Member Posts: 55
    Hello! Just curious, are you still able to provide MF, residuals and any incentives for 2020 Suburban models?
    Looks like lease support has ended for the 2020 models
    Thanks again! I’ll check the 2021 forum.
