For this region, that $600 trailer is a red herring IMHO, because practically speaking it should be offered at twice that and include the brakes you're gonna have to add... (speaking from my perspective, of course). Wasn't it Toyota's Rav4 that was marketed without a rear bumper ? Kind of brings that to mind...
I like the idea of heavier duty brakes in a tow package, but I wonder about the relative weight of the tow vehicle to the trailer, and whether you can make that make sense. I suspect, (but not being an engineer, I'll have to leave it at that), that you rapidly get to where the tow vehicle doesn't have enough mass to safely control the trailer in some situations (like a steep downgrade in slippery conditions) without having a braking effort at the trailer wheels.
Perhaps the Forester in its current incarnation is close enough to the engineering limit not to warrant a beefier tow package in practice ?
I've had apparently knowledgable people caution me about towing too big a load with a short wheelbase vehicle, because you don't have enough leverage via the tow vehicle's wheelbase to suppress sway in high cross-winds (which we also get here). While I can't comment, really, as to the veracity of their concerns, it makes some sense to me. I wouldn't tow a tall trailer behind a Forester for that reason.
I guess what I'm driving at here is that the Forester might have some limitations due to the priorities that were met and the compromises that were struck at design time.
Don't get me wrong, I'm not against trailer brakes at all. In fact, I favor them. What keeps me on this discussion is that, where I live (Maryland), you can't find a small utility trailer with brakes that's rated at only 2000 pounds. Maryland doesn't require brakes on any trailer under a 3000 pound rating, so they don't exist. When I mention adding brakes to something that small, the trailer dealers just look at you kind of funny.
Bob
Bob
-mike
PS pump fixed/replaced
Clutch (the one in there is slipping)
Air-suspension converted over to std suspension
So for now I'm driving Zephyr's RS, I didn't hurt the clutch too much, hopefully. My biggest problem was going into the slalom after a 3rd gear sweeping turn, going down into 2nd w/o blipping the throttle caused me to violently slow down, but by my last run I had that sorta sorted out.
-mike
Range Rover
1,650 lbs unbraked on road
1,100 lbs unbraked off road
6,500 lbs braked Hi-Range on road
7,700 lbs braked Lo-Range on Road
2,200 lbs braked Lo-Range off road Hi or Lo Range
Discovery
1,650 lbs unbraked on or off road
5,500 lbs braked Hi-Range on road
7,700 lbs braked Lo-Range on road
2,200 lbs braked off-road Hi or Lo Range
Freelander
1,650 lbs unbraked
2,500 lbs braked
-mike
Bob
paisan: there had to be a learning curve. I guess depending on the course, if a lot of shifting is required you'd be at an inherent disadvantage just because the others are used to shifting.
Meanwhile, I'm sure both your hands are hanging on for dear life! I know mine were! ;-)
-juice
Bob
Bob
Disk brakes:
Most cars use single piston disks, with a full sliding caliper providing the pressure to the other side. Better designs use two, or even 4 pistons for the most even application of force. In either way, pressure on the pad is pretty consistent and proportional to fluid pressure. The open design, large mass, etc. helps with shedding heat, reducing fade. ABS works better as they can be cycled faster.
Drums:
As the piston pushes outward at the top of the shoe mounts, the movement is in a sweeping motion, not perpendicular. Wear is uneven, and much of the surface area of the shoe never contacts the drum. The star gear at the bottom only occasionally readjusts the pivot point, reestablishing sweep area. And the natural tendancy of the rotating contact area to 'pull-in' / 'push-out' results in one shoe doing more work than the other (sorry, a difficult concept to verbalize). Fade is greater as they do not shed internal build up of heat, and they cannot 'squeegee' out water.
In the case of front brakes, disks might even be cheaper (less parts) to produce & assemble, and are certainly more effective as they do most of the 'braking'.
Rear disks get expensive because of the redundant parking brake mini-drum in the center. But from a performance standpoint, it is something I look for when buying a vehicle.
Interestingly enough, rear brakes can indeed be too good. Some mfgs who tried rear disks before ABS and proportioning systems came of age ('80's, early '90's), got into trouble with rear lockup in panic stops.
Steve
-juice
Nice write up. Rear discs are also something I look for when I buy a vehicle. That's what led me to fork up the extra $$ for a Forester S.
Ken
"Well, guess you haven't heard. I have a new 2002 WRX sedan, World Rally Blue, of course! I traded the Outback, and sold the Coupe last week. My girlfriend, Colleen, is selling her 98 M3 (a great car, great price)and has
bought a 2002 Forester S with the big Sunroof!! Our kayaks and bikes and her
dog go in the Forester, I go in the WRX. She liked the Forester enough better than the Outback that we didn't swap her into the Outback. I am more impressed with the Forester every time I am in it.
My WRX is loaded. I got all the fun bells and whistles. I put on the 17" Gold Prodrive P1 wheels (like Makinen's) and a set of Bridgestone S-03s. I talked to the guy that Denise McCluggage mentioned in her Autoweek column (the one about M3 owners getting WRXs). He talked me into Mintex front pads and a Stromung muffler. The turbo spools up a little sooner. I had it at the
track for the first time this past weekend, VIR long course. Yeehaa! And it rained!! Double yeehaa! Car was fantastic, surprised many, including myself. I did 295 miles on the
track."
-Dave
Unless they changed the rules you should not have to wait 37 months before you can use the certs to buy a car. I would call MBNA customer service if there is any question. Their number is on the back of the card.
SoA should put out a promo like recommend someone, and when they buy you get something like... a T-shirt or a Rally cap...or something.
What y'all think?
-Dave
-Dennis
-mike
Bob's talking about towing...
Paisan's about XT6 and auto-x...
so, what's new?
Pat got a new pooch! Very cute, congrats!
Interesting discussion of discs vs drums. Can I pitch in my female perspective? Discs are better because when I wash wheels, I like to see that shiny disc surface behind the spokes! In comparison, drums are so boring to wash.
I'm a big McCluggage fan, too.
I may have to convert my wife - she just got a ticket for 57 in a 35! Gotta dump that V6 and put her in a Legacy L or something, sans H6! Trade off some straight line speed for better handling and grip!
The cop reduced it to 54, and she's going to court to try and avoid points, but I told her to chill out!
-juice
:-P
-Colin
Ross
-juice
-Dave
How could I have been so lax? Next time I launch into one of my educational talks, I must remember to include the aesthetic implications. The only open question then would be in the ranking of importance. Should that be first, middle or last??? ;-)
Actually, you are very right in this case!!! Nothing beats the look of big, meaty multi-piston calipers and a huge, shiny ventilated disk visible thru open spoke alloy wheels... A standard 9" drum looks wimpy. Could I go as far as calling it a 'manly' look without offending anyone???
Steve
What amount of purchases apply to points? Restrictions on purchases?
Similar topic: there used to be a GM credit card that could accumulate $thousands towards GM auto purchases. Any chance of applying that to a Sube purchase?
-james
-juice
-mike
But nah, diesel is painfully expensive in Potomac. It costs a little more than 93 octane does, even.
-juice
-mike
Craig
My coupons say on the back
"If 500 points are earned each year, a total of 2000 points (equivalent to a dollar discount of $2000) may be applied to the purchase or lease of a new Subaru vehicle after the 37th month"
Craig
Patti
Steve
-Frank P.
Jim
Patti: anything to check out? Absolutely! Grab all the data you can. If you get a brochure I'd love a copy. I'd like to know everything, wheelbase, ground clearance, rear leg room, cargo capacity, payload, towing capacity, roof rack capacity, date of availability (2.5l and turbo), and pricing.
And if they're handing out free sample, grab one for ME! :-)
-juice
Bob
KarenS
Owners Clubs
Sedonia worst ever tested. Impreza not great either.
http://story.news.yahoo.com/news?tmpl=story&u=/ap/20020313/ap_on_bi_ge/bumper_tests_1
SUV crash tests
http://www.onetomany.com/jeepnews/indexnoflash.htm
Bob
Funny that the Wrangler scores better than the Grand Cherokee and the Liberty, both newer designs. Forester and Legacy crush them all, though.
-juice
-Colin
