Visitor Agreement.
It finally got to where it was cutting out completely on Sat morning, so I took it in today. Most halogen bulbs are just a pain in the behind for where you have to fit your hands, but HID is truly out of my league.
They wanted to diagnose ballast vs ignitor vs bulb... not sure if this was just a convenient time suck. The service writer mentioned that the bulb was roughly $500 total. So while I waited I was looking at YouTube videos showing bumpers needing to be removed, but also seeing prices for the HID bulb in the 100-125 ballpark, with Genuine Acura parts at the 125 end. I let them do it, total 460+tax... and when I saw the itemized tab it was 232 for the part (holy markup, Batman!) and 228 for labor (actual shop time was maybe 1:15 including diagnostic time).
So for future reference, does the Louisville crew know any indie shops that are good with Honda/Acura? This dealer is way better than any Euro car on the routine maintenance but this headlight seemed to unexpectedly take me back to that level of sticker shock.
my TL (a 2000) had Xenons. Toward the end, one of them occasionally would go out, but it was intermittent. I knew it was going to be expensive, so as long as it usually was on, I did not bother with it (car did have 175,000 miles on it!) Just so much easier and cheaper to replace a normal bulb.
BMW had the halogen bulb for the inside DRL go out. Had to remove the air intake, and could barely squeeze three fingers in there to get it. After trying for 20 minutes, got on the internet and found this post: "My hands won't fit in there, I have my girlfriend do it." After 30 more minutes, and all the skin scraped off my right hand, I finally got it changed out.
I remember when Dad bought his '73 Volvo new, it was the first car we had with halogen sealed beams. At the time he still had his '68 Volvo as well, which had regular headlights. The difference driving the '73 the first time was remarkable. Not a weak yellowish light but a much stronger beam with almost a blue tinge to it by comparison.
2014 BMW 428i convertible, 2015 Honda CTX700D, 2025 Hyundai Tuscon Limited.
I feel your pain on that one.
I found that the 15 Cruze needs to have the bumper removed per the book method. One of the headlamp units had the amber plastic internal shield over the amber running light bump break loose. Didn't replace.
My 08 Cobalt just the headlight units pop out and you can replace the bulbs. I just replaced the whole wiring harness (about 12 inches long) for the 3 bulbs on one because the contact for the headlight had corrosion and heated and weakened, reducing voltage due to poor contact. These were replacement headlight units because the originals had fogged a little.
But what I learned long ago, is there is often a different method that can be used without doing the bumper removals to get at the headlight units.
$200 per hour is the rate you paid per their using the book time. That's the incentive the techs have for finding the alternate shortcuts--they get paid book time (and the store does too) and they spend less than book time.
14 Malibu looks like both bulbs, projector and high beam halogen, can be removed by loosening some things behind or just forcing to get a little room.
“good old days”- seriously? Maybe if you never drove over 45 mph at night. Sealed beam headlights are absolutely worthless. When I purchased a car with sealed beams the first thing I did was throw them in the garbage can and replace them with Cibie or Hella E-Code lamps. Even my Jeep got a set- with OSRAM Night Breaker Plus H4 bulbs.
The real peeve IS indeed the price of the bulb, especially with plenty of dealers online in other places showing ~$125 for Genuine Acura/Honda, even knowing that it's just a Sylvania D2S. Way too much markup at this store!
Grandson #1 (now a college freshman) just installed one of those bruser bars with LED lights on his 2012 Escape. When I was over at Son #1’s house this past Sunday night my grandson wanted to show me his handy work. Those LED lights are blinding in comparison to his clouded plastic lens head lights. Son #1 said he used 2 different plastic lens refurbishment kits and they did almost nothing. He said he doesn’t like the idea of his son driving at night with the clouded lens and he’s considering taking it to his mechanic for another rub down, if possible, or getting replacement lights altogether which are not cheap even if he got the after market jobs. He then ask me what I thought. I said, (1) have him slow down when he drives at night, seems pretty logical to me and (2) put more carrots in his salad.
I guess I lead a charmed life; the Clubman is the only car in my garage that has even a
hint of clouding on the headlights. I recently bought the top rated Sylvania headlamp restoration kit and plan to try it out in a few days. And yes, I realize that it’s a hazardous DIY procedure; I’ll have a fire extinguisher close at hand in case anything bursts into flame.
The only other car I ever changed the fancy new bulbs on was my old Lincoln. It was tricky from a getting my hands in there standpoint but fairly straight forward. The trouble was that the headlight design was poor and the problem wasn’t the bulb it was that the heat from the bulb burned up the reflective material inside the housing. MarkVIII owners became known as “high beamers” because that was the only way to see at night.
I did not want to put in the extra bright bulbs to compensate like the Sylvania bulbs that just blast light everywhere. Those make more heat, pull a little more current, and failed more often.
It doesn't get driven in the winter, so that does help.
I kinda want to buy an older car, just so I have a reason to do some putt with it projects.
https://albany.craigslist.org/ctd/d/albany-2016-volkswagen-golf-18t/7204691419.html
Or if you want a real old hooptie there’s this:
https://newlondon.craigslist.org/ctd/d/fiskeville/7198414038.html
Basically a Mitsu Eclipse underneath.
of car styling..
Even looks a little like the 2018 Chev pickup with the 4 headlights
All those lenses are plastic.
a 16 YO Chrysler? Hard to talk myself into that one. But the manual, interesting. Did not even know they came that way. And it has a moonroof, and certainly cheap enough.
Possibly, maybe, it was when I wound up with the $1,000 300z, but I think that came much later.
She told me she was having her car towed to her mechanic's garage to see what could be done. I suggested that she have the car towed to her local Honda Dealership since, as she described what happened to me over the phone, it sounded like either her engine gave out or that something was wrong with the transaxle. She followed my advice and had the car towed to the Honda dealer. I told her I would help her and, after showering and shaving, I drove up to her work and picked her up.
I drove her to her apartment so she could pick up the title to the Honda Accord EX Coupe, her checkbook (which had enough in the account to pay for a nice dinner at Morton's Steakhouse, but not a penny more, and her insurance paper work. I then drove her to the Honda Dealer. She tried out several models and finally landed on a Honda Civic EX Coupe in white with black cloth interior. MSRP was about $24,455 which included shipping. Edmund's stated that the average purchase price was $22,908. Then they added dealers fee of $999, tinting, pinstriping, and a bunch of other BS add-ons for $1800, 7% sales tax (6% + $50.00), DMV stuff, etc., and came up with a price out the door of $27,990. I told them I would give them one price - if they met that price we would buy the car - if not, we walk. My offer was $26,000 out the door. They argued that I was not paying for the dealer fee or the add-ons and wanted the car for dead invoice. I responded "YES"! After about 20 minutes, he came back and said they couldn't meet my price. Their counter offer was for $26,001.00. They were being cute.
Now that we had arrived at a sales price, we needed to find out if she could finance the car. Her credit history is a bit tarnished - I'm being positive here and that was the best way I could describe her FICO score - so they came up with a 6.1% 75 month loan with Wells Fargo, the only bank willing to finance her purchase. Since she keeps a car for many, many years, she also wanted an extended warranty - so through Berkshire-Hathaway, we added a 6 year 100,000 mile bumper to bumper warranty (3 additional years over and above what Honda Warrants) with no deductibles and no exclusions. Honda dealership accepts that insurance up to $5,000 on a consignment basis. Honda didn't offer an extended warranty on this car. So, we added $1700 for the warranty and she ended up with a payment of $329 a month.
Needless to say, I am exhausted from all the rushing around. I really hated the fact that that dealership had leg up on getting a deal done because the broken axled Accord was in their service department and if we didn't buy a new car there, we would have to pay to have it towed somewhere else.
All in all, it was an experience I never, ever want to go through again for the rest of my life. Besides, It cost me $8000 which is $8000 less I have in reserve and $8000 less the kids will inherit.
UGH!!! :'(
