cannot delete pre programmed sirius xm presets
iceguysiceguys Member Posts: 18
edited October 2020 in Acura
I have tried everything to delete and add my own Sirius stations to the presets. The issue is I do not have the ADD button. If I go to a station I want to program and then hold one of the presets, nothing happens, just reverts back to the pre-programmed station. Additionally, If I try it another way, there is no add button, only a delete button which I have tried to no avail. Any info would be helpful.
  • MichaellMichaell Moderator Posts: 267,513
    @stickguy or @pensfan83 - you both had a TLX, can you assist?
  • stickguystickguy Member Posts: 54,080
    Best I can recall, it worked normally by just pressing until it beeped. But it’s been a while since I did it and no longer have the car to try it out. The RDX has a different set up.
    Just pull out the owners manual. Answer will be in there.
    To set the presets for AM/FM/Sirius you should be able to just press and hold the numbered button on the touchscreen and it will save/override the selection for the station you want. To access more buttons you need to slide over to the next page on the touchscreen using the buttons that look like reverse or fast forward on a VCR.
    Have you tried this on AM/FM bands and having the same problem? If so, it might be a hardware issue with the touchscreen. If not then I'm stumped because I set all mine using the method I described above.
