Visitor Agreement.
This truck was delivered 11/18/00.
If anyone knows if this is possible please share the information.
I agree this is stupidity not to have them. Is this Dodge's way of cost cutting?
I may have solved the problem with installing tow hooks on my 2001 QC.
I spent the day measuring, drawing, drafting, and designing a couple of specific pieces of steel that will bolt into the existing holes in the QC frame up front.
I took them to a machine shop to have them made.
As a result, if all goes well, I will be able to mount standard tow hooks up there that will pass through the holes that Dodge cut in the facia. They should be plenty strong enough too.
I took the specs to the shop this morning and will receive them probably by Monday at the latest.
I keep you guys updated when I get them.
It is off of the 4.7 V8 Magnum.
The link is:
http://cgi.ebay.com/ebaymotors/aw-cgi/eBayISAPI.dll?ViewItem&item=571093191
thanks,
tom !!!!!!!!!!!
After 3weeks of 90-degrees... This shoveling snow and cold is hard to deal with... Perhaps its the jetlag...
I am allready scheduled to go back to Singapore in 2weeks.
KarenS
Owner's Clubs
A bunch of you have been asking me for more information on the Herculiner, Do-It-Yourself bedliner. I added it to my page so you guys can see what it is all about.
Let me know what you think.
http://www.ayrow.com/bed.html
great pictures (again). You always seem to do a hell of a job on all the mods you've done with your truck. Your description, also is entertaining, and informative. I also LOVE your plywood frame. You might want to consider applying for a patent!
scottie
The plywood frame is so simple, I doubt that a patent would do me much good.
Thanks again!
Tod
You convinced me to pay someone else to do it. If you saved $200 dollars for 15 hours of work ($13-14/hr), my wife won't let me work for less than $30/hr.
I'm saving my money now,,,,,,,,will make my decision then!
PS At 3500 miles the truck is great, but does seem to be developing the "popping" in the front end when turning the wheel over bumpy surfaces.
skylerk "Dodge Dakota Owners - FAQs" Dec 15, 2000 4:39pm
any help greatly appreciated
robert
This site has been the one most prominently mentioned in these boards. I may have to visit them if/when my Quad shows up. Let us know how it works out for you. I'm kinda interested in the 4yr/75,000 plan myself. Waiting for the dealer offer to see how much I can save.
http://www.chryslerwarranty.com/
Ron35
robert
Thanks for whatever real-life experience you can share about this outfit!
Skyler
i have heard great things about them but dont use their payment plans!
good luck
robert
Be carefule with extended warranties.
Who really owns your warranty? Who really has your money?
You need to know about the "transfer of risk" associated with warranties. A transfer of risk is when the dealer pays money to an administrator that sets up "reserves." These reserves are used to pay for repairs. Why is this important?
Some dealers DO NOT pay into the reserve, they do not "transfer the risk". They are gambling with your money. Your warranty is then only as good as the financial status of the dealership. If they hit hard times, your warranty is in jeopardy.
If the dealer hasn't "transferred risk" to an administrator that maintains an excellent claims paying ability and the dealership is sold OR GOES OUT OF BUSINESS, you're out of a warranty, and you're out of the money you paid for that warranty.
Warranty Gold won't play games with your money.
Back to top
Why should I care about Vehicle Breakdown versus Wear and Tear?
You should care because you may be covered for one (breakdown) failure and not for another (Wear and Tear) failure with your current warranty.
A breakdown failure occurs when a component or part BREAKS. A wear and tear failure occurs when a component breaks AND/OR fails to perform up to manufacturer's specifications.
For example, piston rings do not break. They wear out. This is wear and tear failure, not breakdown failure.
Another example: Suspension items normally do not break. They wear out. This is wear and tear failure, not breakdown failure.
This is a critical distinction because many manufacturer's warranties and after market warranties DO NOT COVER WEAR AND TEAR FAILURES.
Warranty Gold's Vehicle Service Contract covers breakdown AND wear and tear. It does not exclude repairs due to "wear and tear".
Ron35
Sounds like this will have to be a custom machine shop job unless there are adaptors available.
good luck
Bookitty
will
255 is about the maximum width I would put on the OEM rims which are 7"
I have 255/60-15 Pirelli Scorpion Zeros on my 97 and I love them. Stick like glue. A little noisey but I don't care. I like the handling.
I tried to remove the door trim from my 2001 QC to get at the side-mirror from the inside. I started by removing all of the screws. Then I started to pull from the bottom to snap the trim loose. However, it seemed more like I was breaking it off rather than snapping it off.
My question is; does anybody know how to remove to door trim without destroying it? What was I doing wrong?
Ayrow
its a torx head screw right behind the door latch
will
Willwill, you did not mention what size rim you had
BTW, a 235 on an 8" rim is fine. It just doesn't give the wheel much protection but it really helps stiffen up the sidewall by keeping it straight. In fact for maximum handling using a tire on the widest recommended rim is the way to go. Ask any racer. A 235 tire is suitable for use on rims 6 to 8" in width. In contrast a 255 is approved for widths 7 to 9".
Remember the question was what is the biggest tire that will fit the stock wheel. My answer was in terms of maximum width on the OEM wheel and maintaining close to OEM diameter to minimize errors in the speedometer and the computer. Too much of a change can effect how the computer controls the engine and tranny. The OEM wheel on the Dakota unless you have the tire and handling package or the R/T is 15 X 7 steel (on base models) or alloy (on Sport and SLT)
The 255/60-15 I can recommend based on personal experience. That is what I have on the stock alloy rims, (15 X 7) on my 97 Dakota SLT. Pirelli Scorpion Zeros and they fit great and handle great. The wear pattern is perfect. No excess wear in the middle that you would get if the tire was too wide. Persoannly I like the wider tire on the narrower rim as on the street with curbs and such the sidewall of the tire will protect the rim from minor damage. I will trade the slight edge in handling for a little protection in the real world. Samr reason why I won't go to the 45 series tires.
If you don't beleive me about the tire and rim widths, go to various tire manufacturers websites and check out their data.
Ron35
Well, there are all sorts of ideas on here and the DML both that relate the limiter to manual/auto, Tire&Handling/base, rear-end ratio, and other stuff. It always seems that for every rule, an exception pops up in the next post, so I'd like to figure this out. Those of you who have hit your limiter, would you please e-mail me with your:
Year
Body (RC, CC, QC)
Engine (2.5, 3.9, 4.7, 5.2, 5.9)
Transmission (Auto or Man. will do, I'll work out model numbers if it proves to be a factor) Drivetrain (4wd, 2wd, Awd)
Rear End (3.21, 3.55, 3.92)
Tire/Handling (Yes, No)
Heavy Duty Service (Yes, No)
Indicated Speed Limit
Also, I understand that Silver's a little faster, so let me know...
Crit in Atlanta
crit@engineer.com
I installed side turn signals under the mirrors on my QC.
http://www.ayrow.com/signal.html
Ayrow
What have others dome to remove this unwanted wax residue?
Hope this helps...
Ron35
tried various household cleaners and other products (citrus based), but to no avail. On a hunch I tried Armor All, and it did the trick. I have had to re-apply it only once in 4 years. It may be worth a try.
Bookitty
Once caution... DO NOT GET IT ON THE PAINT. any silicone on the pant will really mess up your wax-job.
