Visitor Agreement.
Anyway here's the text:
Four wheel drive vehicles get new electronically shifted transfer cases with a rotary instrument panel control. Sport and SLT models get new 15" aluminum wheels, while special new Tire and Handling options with new wheels and tires are added. The Sport gains a body colored front fascia. All models get new 6x9 side mirrors.
The instrument panel has been redesigned. A new tilt steering column has more positions, and the transmission indicator now has a digital display (44RE and 46RE automatics). The optional premium overhead console now has a universal garage door opener. Stereo options are improved.
The interior has basically been redone, with more cupholders, compartments, and power outlets, more comfortable / better-padded seats, and leather available on the Quad Cab.
The vent system has been improved with more heating and cooling capacity, two additional outlets, and recirculated air available in bi-level mode.
A battery saver is standard, and a rear window defroster is available on the Club Cab. Front seat belt pretensioners are now on the Quad Cab. The optional security alarm has a Sentry Key. The 3.9, 4.7, and (soon-to-be-replaced) 5.9 engines all meet low emission vehicle standards in every state.
http://www.kollerdodge.com
Allen-
I have the Infinity sound system with the AM/FM/CD in my 01. The sound is great, but occasionally, while listening to FM, the sound will become muted for a second or two, then return to normal. At first I thought it was only happening to distant stations when the signal became weak, but now I notice it even on stronger local stations. I don't think the problem is in the speakers because when I'm playing CDs it sounds great. AM seems to be okay too.
Has anyone else noticed this problem?
Some multi-viscosity oils are manufactured by starting with a light oil (ie 20-weight) and adding long-chain polymers to the mix. The polymers tend to 'bind' the oil molecules together so when they get hot, they do not spread apart as much. Result.... the oil does not thin out as much as a "normal" 20-weight oil would at high temperatures.
HOWEVER
These polymers tend to get 'chopped' into little pieces by meshing gears and other EP(Extreme Pressure) loads. Thus... you end up with the original 20-weight oil after miles of use.
Any modern, brand name motor oil should not exhibit this characteristic.
The reason that designer - oils (read synthetics) do not succumb to this 'shearing down' is because they are NOT made of something that came out of the ground then was modified. Instead, these oils are made in a Chemists Lab with SPECIFIC design characteristics in mind.
In any case...
I always enjoy a good technical discussion...
Are you familiar with the base used for Castrol Syntec synthetic oil? Is it also of non hydrocarbon based polyol esters like Mobil1? Have you noticed that Mobil1 has recently changed its formula to match Syntec's acid-neutralizing characteristics?
Nice info. update - as usual... :-)
The problem is not in the tach since you can feel the boost in rpm's and see its transient effect on the speedometer. If not in gear, the engine drops through the 1,100 zone so quickly that I can't see or hear if is happening. Any one else having this happen?
Firstly, apologies for the abrupt departure - I went away for a few days and wasn't planning anything more, then got bogged down with an unexpected business trip and forgotten jury service.
Anyway, I am now back, don't have time to catch up, but will try and get back up to speed asap.
I must take a moment to thank everyone who expressed concern over my abrupt departure.
I have experienced this on past vehicles (Honda and Nissan). The engine is actually turned off during decell. Then, at a specific RPM, the engine is turned on again and the idle-speed-contoller takes a moment to figure out what to do.
This is a product of fuel-injection and economy programming in the ECU (EngineControlComputer)
Also keep in mind that 2000 is the VERY FIRST YEAR that this engine ever saw a manual xmission. Some of the built-in characteristics that work in tandem with the special 4Speed automatic seem odd when there is a direct connection to the drivetrain.
Bookitty
I think we should go back to the middle ages and the witch hunts. They used to test people to see whether they were witches by throeing them in a lake - if they floated they were witches and were subsequently killed. If they drowned then they weren't witches and were found innocent.
There seems to be a small flaw in that system, but I can't quite put my finger on it...... :-)
Bookitty
Just don't tell anyone else, let's keep it our little secret. That's why I hid this comment - to keep it a secret. Shhh!
Bookitty
Bookitty
KnK
Dakota. I've had it about 6 weeks now and just love the darn thing. I will say that I had forgotten what it was like to drive a "fun" truck. I find myself making excuses to drive it. I've got about 1600mi on it and am getting a solid 17MPG. I've allowed a handful of my fellow workers take it out for a spin and everyone really likes the 4.7L with the 5-speed. I haven't had the heart to take it off-road yet. Only some dirt roads so that I could get used to engaging 4HI and 4LO. I drive up to Colorado every summer for some 4 wheeling fun. However, I've already taken my trip this year with my previous truck ('99 Mazda B3000). So the real test will have to wait until next year. Drat!
I have added some after market items that include window tinting (a must for Arizona), dashboard cover, seat covers, door sill covers, a rubber bed mat and bed extender. Today, I finally ordered a Roll-n-Lock. I should have it sometime this month.
Let me know what you find out about the rear anti sway bar. I wonder why the T&H package for the RC omits this. I'd be very interested in this addition, if feasible. Sorry for the long post. But as you can tell, I'm enthusiastic about this truck. Distinctive exterior, great drive train, roomy and comfortable. The Dakota is real keeper!
Tell me a little about your '91 5.2L. It's going on 10 years old now. How has it held up for you?
Any major problems or gripes? How do you think the 4.7L compares to the 5.2L? Seems like you are in a position to express some worthwhile opinions on the subject, having owned both. Just curious. Thanks again...
Later,
Mailman
So Xena1a, your in AZ? What part? I live out in the Buckeye area but work in Phoenix.
Keith
Mailman
Xena1a how much did you pay to have your windows tinted and what % are they?
I believe the two door windows have 18% tint (PT18) and the solid rear window has 38% tint (PT38). Materials were listed as $35 and labor $60. I got out of there for about $100. Yea, a bit pricy. But it sure looks nice, and man, does it help block out the sun and heat...
Speaking of tint, I had the sides done with 35% for about $75. This was the lifetime stuff, the best they had. My rear slider window came tinted from the factory.
Keith
"The problem is that the hose may be pinched shut. This may cause transmission fluid to be expelled through the filler tube, which could cause an underhood fire with the presence of an ignition source."
This is probably why some of us have transmission dip sticks that don't want to stay seated.
Anybody else with a 4.7/Auto get notified yet?
Keith
Anyway Thursday at 3:00 PM. Then I can feel SAFE again..
Whish me luck I wouldn't want to catch on fire before Thursday!!
Allen-
Bookitty
hope that helps.
robert
According to the notice "The On-Board Diagnostic (OBD) system on your behicle will not detect a catalyst failure as required by the Canadian emission standard"
The remedy requires the dealer to "reprogram your vehicle's Powertrain Control Module"
The really bad news is that this affects some 2000 model year Ram Vans / Wagons, Dakotas, Ram Pickups, Durangos, TJs (Wranglers in US), Cherokees and Grand Cherokees - so I'm guessing it is going to be a long wait to get it fixed.
Bookitty
Actually I managed to find a dealer near the office who will do it for me tomorrow - gotta love five star dealers. The dealer where I bought the truck went bust a couple of months later - I knew I got a good deal, but I didn't realize it was that good!!
Incidentally guys, I am starting to position myself for transport requirements when I move to the middle of nowhere next summer, so the Dakota may be sold in the next 6 months or so. Wifey keeps pointing out that we need a BIG truck for the dogs and she wants a second 4x4 (but honey the XJ-S is almost as practical). Current favorites are a GMC Sierra Crew Cab 3500 (Dodge don't make a crew cab 1 ton) and a Jeep TJ (Wrangler) for wifey. No definite decisions yet.
robert
But don't sell the Quad. You (and we) will regret it. I'd probably inherit bookitty for this board thing, and we all know he's a cat - hatchoooo! - guy. And trucks are (still) dog 'things.'
Bookitty
This is in theory! I wouldn't want to test it on my quad.
