Chevy Suburban Stabilitrak Issues
                    Hello, I own a 07 Suburban 1500 LT 4x4. I was driving and the stabilitrak activated my abs brakes and reduced the power to the motor making the vehicle un-driveable.  I limped into a big box auto store and they read the code for me before the tow truck arrived ** Code C0455 ** Steering Wheel Position Sensor. I just replaced this and the truck still does the same thing.
I then went through the DIC center and noticed that the tires were not registering any pressures. So I then proceeded to reprogram the tire position in the computer. This failed I tried 3x's to now have a failure in that system ** service tire monitoring system ** I figure this is because of to many failed attempts.
I read the OBDII codes and there are now in the computer.
It did read an B0110 but I think that was in the history of CEL's not entirely sure.
I also inspected the front speed sensors and the connectors are clean with no corrosion.
Brake fluid level is also fine, motor idles fine as well the reduced power is a safety feature not a symptom
Any I mean any helpful input would be great !!!!!
-Scott
-Scott
I checked my resources to see if I could come up with anything helpful for you as you troubleshoot this but as I am limited in technical information was unable to do so. If you decide to work with a dealership, let us know as we're available to assist in that process. Otherwise, I hope that you get some great feedback from the community and are able to get this resolved!
Sarah, GM Customer Service
The vehicle was towed to the nearest dealership this afternoon as I was unable to diagnosis any further with out the equipment to read body chassis codes.
I hope so as well. I have seen that you also represent on the Chevorletforum.com and I have also posted my issue there with a ton of pictures. Same user name.
It is very frustrating to have read literally hundreds of similar posts with limited to varying results to resolve what seems to be a design issue across many GM platforms: Tahoe, Silverado, Suburban Envoy, Trailblazer. GMC sister models in addition to Cadillac sister model even Corvette was not immune which screams recall or at least a better TSB to resolve this issue.
I will definitely post the results of what the dealer reports back to me. The failed part, why it failed if they can identify that, the fix required and the over-all customer experience. I have been treated fairly by this dealer in the past. I just need to step back as currently my emotions have the best of me. I may have the wife talk with them until I am able to. I am not accustomed to requiring service on my vehicles as you may have noticed from my posts. I am not a mechanic but I have a very strong background in automotive repair.
Thanks for letting me vent Sarah and Edmunds I will keep everyone posted with a possible resolution to this issue.
-Scott
If you wanted for us to follow up on this with the dealership, you can contact us directly at socialmedia@gm.com (include your name and contact information, the last 8 digits of your VIN and mileage, the name of your dealership, and a brief recap of the situation).
Sarah
GM Customer Service
If you would like for us to check into this further with your dealership, we're happy to do so. Please send us the following information at socialmedia@gm.com so we can get a Service Request set up: your name and contact information, the last 8 digits of your VIN and mileage, and a summary of the situation.
it been 2 weeks now, including a significant amount of additional rain, and its been running great with no stabilitrak or electrical issues.
Summary: check how we'll the fuse box cover is situated. it's not a good design to get on and off correctly. make sure all 4 clips are secure and good luck.
My truck was a money pit with all these issues and more service than a 07 should ever see.
Oil usage test was a complete waste of my time and money!!!!!
I believe the oil usage was addressed in the 09 model and newer. I'm not sure about the stabilitrac issue though.
I can go on and on but the best decision I made was to trade it in. Sorry for the negativity but being all the issues I had, dealer & GM non-addressing of these issues and the anger I felt for fixing many issues on my own.
Again sell it, as you will see from hundreds of posts here & on many other forums there is no answer just tons of complaints, that speaks volumes as to the issues are not being addressed by GM nor are they being taken seriously
I just paid off my 2011 Silverado Z71 and now I'm just terrified as to when it's Stabilicrap system is going to ruin my life. Did I mention that I hate Stabilitrak?
Debbie
Did you start a class action lawsuit?
Had diagnosed.. So far these things have been done -Replace lifter, rebuilt valve heads, coolant temp sensor, oil pressure sensor, all sensor on engine, new plugs, coils tested fine.
Im now being told it could be electrical. After I turn off ignition I hear an electrical buzzing sound.
Suggestions? We've dumped a ton of money into this. I'm in ministry and my husband is needing surgery and we are praying it is an easy fix! We need a working vehicle ASAP. Thank you.
I have a 2009 Chevy suburban. It seems to always have one issue or another. Today I was driving with my 3 children and my car started vibrating and making small ticking sounds. I received messages on my dash to service stabilitrak and traction control and my stabiltrak light came on. When I drove at faster speeds the vibrating and noise were minimal. As I slowed down and stopped it was much worse. Even in park in vibrated quite a bit more and made horrible noises. I’ve read several posts in your forums of many folks experiencing the same problems and no dealership or mechanic can seem to figure out how to fix it. Many people have paid thousands of dollars trying to solve this ordeal but do not have a good outcome. When is a recall going to happen? How can I be a help to myself and others and try to get a recall going on this? I’m beyond frustrated with this car and I want a solution. I will never buy a chevy again!!
Many different maladies can trigger the Stabilitrak response. Another person's solution might have nothing to do with your car. That's what makes this tricky, and why you or someone you hire has to do a methodical diagnosis.
Hope the dealer is able to find the problem for you.
Keola
NHTSA Complaint Number: 11163558
On three (3) separate occasions in the past year, the vehicle enters what appears to be an "Electrical System Reset" of sorts. This has occurred on long distance trips during operation at highway speeds. The entire electrical system will suddenly power off and on repeatedly, the electric door locks will unlock and relock, the engine will lose power (quite scary at highway speeds) and the vehicle must be removed from the road, powered down, let sit idle for 5-10 minutes and then can be restarted to a normal operating condition. It is almost as if the computer system is resetting itself while the vehicle is in operation and moving. This has happened three (3) times in the past year - all on long trips - March, July, and November. The most recent, instance occurred about three hours into a return trip home and recurred again about 1-1/2 hours later (10 minutes from home) during the same trip. By restarting/resetting the vehicle, I was able to get home. I took to Advanced Auto and the diagnostic came up negative - no codes, battery and startup all good. I have a large family and use this vehicle to transport them around town and for vacations and such. This is quite a dangerous situation when it occurs and I am afraid it may leave us stranded at some point in time, or worse.
