Dodge Dakota: Problems & Solutions
Which tranny do you have. I am not asking manual/auto... I mean what is the model# of your tranny?(hint... it it based on what ENGINE you have)
Since it is "out of warantee" Feel free to get some other opionions. This is not a 'showstopper' and you can drive it while you decide how to handle this issue. Since the transmission oil sits on the BOTTOM of the transmission, the seal at the top is not a big deal. I have owned trucks that leaked there and they went over 150,000 miles with no xmission problems. What is the big deal with an occasional drip from that seal?
You may opt to just change the xmission oil more often. You could get a LOT of oil changes for $744. At least 8 years worth. (your truck would be 11 years old by then)
BTW: My 2000 Dak (with the NV3500 manual xmission) has over 50,000 miles on it.... Has yours been parked for a couple years?
The quote given to me was for the tranny being dropped. They said that they might be able to only partially drop the tranny to replace the seal, which, would "cost a little less".
Unfortunately, it doesn't appear to be a minor/slow leak - there is fluid "everywhere".
I agree, $744 plus is ludicrous! Thanks, I'm already checking out the local tranny shops...
Yes, I have "babied" my truck. It is run every week, I just prefer to walk to school.
I'm still very curious as to what would cause the seal to blow suddenly.
I think what you may be referring to is the gasket between the shift tower and the transmission case. This should be very simple, but unfortunately it appears to require the transmission be removed from the vehicle.
According to my manual the only specified transmission oil that is to be used is Mopar Manual Transmission Lubricant. I am not familar with this product so I can't tell you anything about it. The 4x2 versions take 4.8 pints, the 4x4 versions 4.2 pints.
For the transfer cases (NV233 & NV244), ATF+4 is specified.
Dusty
I agree that no fuel injected motor should exhibit a rough idle.
After giving this some thought I am pretty sure that in the past when my idle was a little bumpy the idle speed had dropped below the normal 600 RPM, as indicated by the factory tach. Since mine hasn't done this in quite a while it may be some time before I can take note of this again. I will say that the first time I seem to recall a "rough" idle was during some very extremely cold weather.
Best regards,
Dusty
The NV3500 is a VERY robust tranny. It is used in millions of Dodge and Chevy trucks worldwide.
I cannot think of any way for this seal to "blow" there is absolutely no pressure in the transmission case that can "blow" a seal of any kind. I am wondering if this can be accessed from ABOVE by pulling the shifter and the center console. Once this is removed, the top of the transmission is visiable while sitting in the drivers seat.
This may be just a case of some loose bolts too.
There is the slim chance that the breather for your transmission is plugged up somhow (kinked hose?) This could allow pressure to build up within the xmission possibly causing leakage at the point you are having problems.
I just cannot beleive that you are seeing a whole lot of leakage at that point. There is very little xmission lube up there. (just an occasional 'splashing')
Are you SURE you they are not talking about the front shaft seal? (the shaft between the engine and the xmission.)
BTW: I use RED LINE "MTL" (ManualTransmissionLube) in my NV3500. This special synthetic lube makes it shift much nicer especialy in sub-zero weather.
I will keep RED LINE MTL in mind when I move back to more temperate climes...
Now, onto read more about spark plugs, tilting trucks, popping front ends...
I'll pick my truck up today, they don't want to keep me in a new mini van until parts come in.
What they have fixed;(covered)
Gas tank sending unit replace.
Battery replaced, why I don't know but it was free.
Wiper delay circuit.
What I paid to have done;
Coolant replace.
Auto trans. service.
Mick
My memory is often times faulty nowadays, but I seem to think my son's '91 Dakota had a leak from that area and as I recall there was no gasket there, just an RTV seal. If that's true then a transmission under pressure from a clogged vent would probably "blow" the RTV seal away.
Keep us posted.
Best regards,
Dusty
not control arms.
mick
No more shimmy when I hit a bump at speed also.
Cold start hesitation is gone. (new battery
or injector cleaned?) They said battery.
Fuel guage works again.
All have a Merry Christmas.
Sure glad to get my truck back, even thought I was
driving a new Town & Country van for a week!
As far as vans go, it drove very good, but didn't
comepare to the Toyota Sienna I owned and the new
Sienna's are even BETTER!
Mick
I think when I get to 36,000 miles I'll probably install grease fittings on the joints. Most Dakota owners I talk to haven't replaced ball-joints, but enough have that I believe insufficient lubrication is likely the cause.
Dusty
mailman
Ron
cost due to warrentee.
I just glad to get all fixed. I was surprised they
replace upper and lower ball joints without any
fuss. Service manager told me he hadn't replaced
any. Looks like Dodge is replacing ball joints if
any complaints come up.
The swaybar links, frt/rear were all replaced.
Also the wiper module was replaced with just my
word that is was intermitent.
mick
Best of luck,
Dusty
(3.9 V6, 5-speed)
Dusty
mm
I could use one for my ATV as well.
Best regards,
Dusty
Bookitty
Ron
Bests,
Dusty
There's been a couple of sets of U-joints, a water pump, and a number of drive belts replaced. Brakes, of course, and three exhaust systems. The heater core is now leaking, I guess. The only rust hole in it is the tailgate, and even that's not too bad.
Good luck with yours.
Dusty
With the exception of one Chevy PU and one Chevy van, I've been relatively lucky. My last car, a '93 Sentra, only cost me $1651 above the price I paid for it to operate it ten years.
As long as you have a Saginaw steering rack, anticipate periodic replacements. Yep. The seals go. The radiator in my son's is still the original, believe it or not, but probably most '91s have had them replaced. I don't remember anyone having starter troubles in those years. After two Midas exhaust systems in three years, my son spent the big bucks and bought Dodge factory exhaust parts. They've been on now for better than five years.
Dusty
pulling out of garage (temp in the 20's).
This happened about 6 months ago, I hit the steering wheel and all was well till this morning.
Hitting the steering wheel didn't help. I moved the steering wheel up one notch and the radio and
turn signals came back on. There's a connection in the steering column that seems to be the problem? I could move steering wheel up and down
and problem would come and go. Great I can repeat
this and show my dealer! After driving all day and
the interior warmed up, I could not repeat my finding. My truck is 2wd auto trans.2001 quad.
Mick
Ron
When I bought my 2003 I asked one of the Dodge service technicians about this and he said that they haven't see many clock spring problems on Dakotas after '02. I inquired as to the root cause and he believed that it was a component quality issue. He did not know if the clock spring components were still being supplied by the same vendor or not.
Good luck,
Dusty
Yesterday, I asked the parts guy about the 4.7L short block's price and it was in their computer. Hey guys and gals, keep changing your oil because they want $6,710 for one.
Dusty
My question is; "Where are they getting all of the 4.7L blocks to remanufacture?" They have not been around around long enough to start wearing out.
Actually, since it is almost IMPOSSIBLE for any normal shop to seperate the block to rebuild it, It sounds to me as if they are taking advnatage of that fact. No one is seperating a 4.7L or its little brother the 3.7L in their garage.
Some people may forget that the 4.7L (and 3.7L) are quite high-tech with the 2-part block with Nodular Iron bottom plate. Teflon-coated pistons with special ring design. The extreemly close tolerances. Magnesium valvecovers. Low thermal conductive intake manifold. Coil-over ignitors. I still have printouts of the original engineering reviews for the 4.7L engine.
A friend of mine just put a remanufactured engine (complete) in his GMC and I think he said that the out-the-door price was around three-grand.
It wouldn't surprise me though, as you pointed out, that a 4.7 short block would be more expensive because of the materials, special coating applications, and the way its made.
Best regards,
Dusty
BRAKES
As I reported here in another thread, in 2002 the brake components were changed on the Dakota/Durango, including different pads, calipers and rotors. I was told that this has brought the in-warranty replacement rate down to near zero. Prior to 2002 Chrysler bought rotors from five or six suppliers and getting consistent quality was a serious problem. Some would be good while some would be way too soft. It was mentioned that the '98-'99s were probably the worst, although they continually got better. They did say they had one '02 Durango replacement at around 30K, but the rotors were replaced under warranty as good will. The owner had pulled what was though to be a boat way over the towing specification.
HEATER/FAN BLOWER MOTOR RESISTORS
I was told about some low incidence rate of heater/fan blower motor resistors failing. I think someone here has already experienced this. It appears that Dodge made a running change and went from a conventional type of wire wound resistor (rectangular shaped bar) to a new "flat style." It is this flat style that they encountered some failures. I was told they've replace "a few" since changed in 2002.
TRANSMISSIONS
No 545RFE transmissions have failed so far in roughly 1400 units sold since this transmission was introduced. The repair and failure rate is also way down on the remaining "RE" series. One of the techs was the transmission guy and he said that he has yet to work on any auto that was built in or after 2001. He's had a couple of repairs to 2000-built units, but none requiring complete rebuild. He also said that use of the wrong fluid and/or abuse accounts for much of what he sees today, clogged valve bodies the most common. On older Dakotas and RAMs he is replacing solenoid packs, but stated that these are almost always first-time failures. He knows this because the solenoid packs and other valve body components had been upgraded in '99 and he's still finding the old versions when he works on them. This indicates that most of these are probably first time service. He said he just did a '97 (supposedly one of the real bad years) at 155K and was a first time rebuild. Now how many Ford or GMs go that far without a rebuild?
287 (4.7) MOTORS
I was surprised to hear that they had two 4.7s with bad oil pumps. These were early built engines (2001s?). Since those they have had no 4.7s apart for any other reason!!! All four of these guys -- who had also worked at competitive make dealerships -- said they know of no engine that has been as trouble free as the Chrysler 4.7. One of these guys worked at a Toyota store.
I asked about rough idle. They said they've had a few that had this complaint, but no reports of stalling. The universal symptom has been intermittent rough idle, especially during very cold weather. I got mixed opinions about this. One tech said, because they've had a very low incident rate of this, that he thought it was due to a combination of Idle Air Temperature sensor and Manifold Absolute Pressure sensors being at the edge of their acceptable tolerance range. Another fellow, who owned a 4.7 Dakota, said that once the PCM went through the complete temperature range a couple of times, this symptom would decrease in incidence and intensity. Another guy mentioned a PCM flash that was issued back in 2001 to fix this.
I asked about spark plugs and they seem to all agree that on the 4.7 spark plugs are rarely the cause. This one surprised me. I asked about dirty injectors and one tech thought it was sometimes a problem depending on the kind of fuel that was used.
SUSPENSION
I asked about sway bar bushings making noise and the answer was unilateral acknowledgement.
I asked about premature wearing of ball-joints. I was told that in 2002 the suspension components were upgraded, mostly by shifting to another supplier. I asked if they knew who that was and one guy said Moog and another said TRW. In 2002 the lower, upper, and tie-rod joints were enlarged and used a better heat treating process.
Maybe more later.
Happy New Year to all,
Dusty
Feel free to mention my name, quote me here on this board if the situation presents itself the next time you have the opportunity to speak to the Dodge techs. Ask them what Dodge can or will do to rebuild consumer confidence in their products.
Mention, if you will, the four sets of replacement rotors I went through. I would love to hear their reaction to that.
To answer your other question, if Chrysler has addressed issues like this and made corresponding changes to increase component quality, what more can they do? Isn't that what you would want, to improve component quality so that these no longer are issues?
Dusty
At the least, its a piss poor excuse for aborted product development. As far as I am concerned, this is an issue that never should have surfaced. Designing and building solid, reliable braking systems was a mopar hallmark for a number of years. I know this from personal, not observational experience with other mopars. Its not my job or the job of any purchaser to perform unpaid duties as a product development engineer. I understood, incorrectly as it turns out, that this was "included" in the 23K price tag of the truck I once owned.
What can mopar do? I am not sure at this point. Its like the bad girl in town who changes her ways and goes straight; for a while, no one will believe her. At any rate, it takes a large leap of faith to invest over 20 grand in a vehicle from a manufacturer that blew it the first time. Chrysler is paying six figure incomes to marketing guys in Detroit, let them figure it out.
Then go back and build a solid truck and keep the accountants hands away from the brake budget.
It's still bs though.
I too once had a love affair with mopar. Believe me, no one had more loyalty to Chrysler products than me except maybe my uncle, god rest his soul. I tore them down, built them up, read countless books, magazines and spend hundreds, if not thousands of hours in garages of enthusiasts.
I researched the entire company, from its beginnings to present day. I got to know about Lynn Townsend, John Ricardo, Steve Sharf, and others. I knew where the KT Keller building was in Detroit. I knew where each and every assembly plant was, what it did, when it was built. I knew people who worked at the factories. I used to spend Saturday afternoons at Daily Motor, part time work, filing invoices and re loading microfiche machines. I learned about part numbers, the byzantine way Chrysler categorized parts. I read countless articles and books about Walter Chrysler, even visited his boyhood home in Hayes Kansas. I used to dream about working in at Chrysler, maybe in sales, maybe in product development or QA. I have read every book imaginable on Lee Iacocca. I used to have a portrait of WP Chrysler in our garage back in Indiana.
Obsession? Yes! I am/was guilty of this. For me, it wasn't enough to know that it was 10w40 summer, 10w30 winter. I wanted to know exacly how my mopar was built. What made it tick. I learned about the virtues of torsion bar suspension, the simple but effective use of leaf springs in the rear, the gear reduction starter, the easy to service and bulletproof alternator, the RV2 compressor, still IMHO, the finest AC compressor built. I also learned to detest Carter Thermojunk Carbs! I learned to carry a spare ballast resistor in the glove box. That too you could set the air gap on the dist. pickup with a matchbook if you didn't have a .007 non-metallic feeler gauge. That the plug gap was .035.
Hell, I even remember the firing order of my old Cordoba 360 v-8, 1-8-4-3-6-5-7-2! (also the same for the 4.7 engine)
I had Clymer, Haynes, Chilton, and Motor books.............whew..........did I miss my calling here?
Yes, it was a passionate relationship, heated at times, but always solid until the Dakota.
I liken my parting of ways to a divorce, painful, yet sometimes very necessary. But Chrysler is the ultimate loser because as a consumer, I have many choices out there in the car market.
I copied this website's info and will pass it back to the local dealership. I'll let you know if they say anything to explain their "continental" price difference.
>>>the comment about relying heavily on brakes is like chastising a soldier for relying heavily on his weapon for defense. This demonstrates a very out-of-touch mindset on the part of mopar engineers.<<<
Well, I failed to communicate this accurately and that's my fault.
No, I think the guys I talked to are very straight shooters. The message they were imparting was that even during the '98-'99 years not everyone had problems with rotors. This was due to two factors, 1) inconsistent rotor quality from suppliers, and 2) some drivers would use the brakes MORE heavily than others.
Perhaps I should have stated it in the reverse, some people would rely on the brakes MUCH LESS and not experience a problem. What these techs were trying to impart was that rotor performance was suffered from marginal rotor quality. I do know people that own or have owned Dakotas of that time period and most of them have not had experienced premature rotor replacements.
That being said, I'm sure you're aware that in the last eight or so years rotor problems were not unique to Chrysler in the industry. In addition, the aftermarket seems to have had a problem, too. Including myself, I've known a lot of people who had premature rotor warpage with aftermarket stuff. Sometimes it does pay to buy factory, even if that wasn't the case with older Dakotas. My wife's '89 Acclaim went 116,000 miles on factory rotors. Her '99 Avalon has already had two replacements. Since her driving style has not changed, it is a cursory, if not fair assumption that Toyota rotors are not as robust.
Now, please, don't interpret what I've explained as trying to make excuses for Chrysler. As a consumer you have the right to expect better performance out of your Dakota than what you got. With regards to the rotors I suspect that maybe Chrysler was just as much of a victim as you were (I'm checking on something that was told to me a while back), but that's no excuse for not taking care of a customer, whether they be loyal or not.
By the way, I appreciate the fact that despite your disatisfaction with your Dakota and Chrysler, you are not in here contributing just to reinforce something negative.
>>>I wanted to know exacly how my mopar was built...I learned about the virtues of torsion bar suspension, the simple but effective use of leaf springs in the rear, the gear reduction starter, the easy to service and bulletproof alternator, the RV2 compressor, still IMHO, the finest AC compressor built.<<<
You might enjoy this story.
I once worked in a general auto repair establishment and the "master mechanic" was cursing at something he was working on the bench. I walked over and saw a Chrysler starter in the jaws of a vise with a motley collection of screwdrivers inserted through the back end. I asked what the problem was and he said what POS "these Chrysler are" and that they couldn't even make a starter correctly. He was trying to install the armature assembly into the housing and get all four brushes started onto the armature. I asked him what he did with that little four-pronged piece of metal that I knew was on every Mopar starter ever built, and he said he always throws them away because he couldn't ever figure out what they did!
Best regards,
Dusty
FWIW......the Ford starters were the easiest. They also ran Fafnir needle bearings in comm end and drive end.
Was that little piece of metal they guy threw away the shift fork?
The Mopar gear reduction drive starters were actually pretty strong units, but unfortunately prone to overheating on hard-starting engines (they drew more current, as I recall). For most years they were the only starter to spin an engine close to idle speed, which is one of the reasons they made that...'yip-yip-yip'...sound. The taxi versions usually got a direct-drive starter, which very few guys even knew about.
Bests,
Dusty
Bookitty
They used bushings but those bushings were much thicker and longer then what GM used. Plus, the drive end was better metal, more of it than the GM units. Ford's drive ends were pretty good too.
Yup, in test the Chrysler starter consistently pulled about 175 amps, more if the reduction gear was too tight. The ford GM units would pull about 140-160 on average.
The GM unit was by far the cheapest made with the solenoid right on the damn unit where it served as a heat sink right to the field coils. I did tear down on GM units and 9 out of 10 had burned coils on the top side next to the solenoid.
Those were the days.........non union low pay but a good incentive to finish college with a degree in hand.
When it comes to Fords my most vivid memory is of my father's '65 Fairlane. It was actually a pretty good car, but in those days the 260-289 water pumps were famous for early failure. My dad's '65 puked the seal for day and I told him I'd be over to where he was do the complete job in the field (I was getting good at it!).
Anyway, thought I was fully prepared but when I got there I found that I had the wrong pump. In that year they made a with A/C, without A/C, automatic trans, manual trans, and one other that I can't remember. When it came to Mopars it was one pump for sixes, one pump for LA-series, and one for "B" blocks. How much simplier could you get. I think it was pretty easy for starter motors, too.
I also agree on those Mopar (Prestolite) alternators. It was either the brushes -- which could be replaced without ever breaking the case open -- or the front bearing was making noise (I still have the Mopar pulley puller for that). Unlike the Ford and GM versions, about one in every ten would be a failed diode.
Book, thanks for the kind words. I try to share my knowledge in a positive way and that's what the majority do in this forum. It's unfortunately obvious that a few are only here to find a reason to throw in a negative comment about Chrysler at every opportunity. Everyone is entitled to their opinion, but seventh grade personal attacks are totally uncalled for. It's obvious that I've made an enemy because I've challenged the attempt to cast everything in the same negative way and tried to bring balance to the discussion.
No one is infallible. Because I am a member of that genotype called "human" I, too, make mistakes. But when people base what they say on bias, assumption and hatred, the cause and underlying message eventually becomes crystal clear and intentional.
Hope you guys have a good year.
Bests,
Dusty
