Visitor Agreement.
I read that approx 29,000 vehicles are affected with this situation and that it goes back as far as 2000 and for only certain Dakotas and Durangos. I previously mentioned this in #609 on the General Topics thread but, no one had encountered this. At least until now...
Anybody else receiving a Recall notice for this?
Best Regards,
dataguru
Yes, I remember seeing your note.
I think that the limited application of this recall corresponds to wiper motors manufactured between certain dates. The vendor knows the affected population of motors by date. I don't know if they made a slight manufacturing change or if it was a material or design change.
Anyway, the Dodge assembly plant knows the approximate trucks affected by matching the wiper motor change to the range of trucks built with the affected units.
I'm not yet sure what the remedy is, whether they change the motor out or what.
Best regards,
Dusty
How many miles?
Dusty
My Dakota just turned 48K miles.
A guy I work with has a '00 that just started leaking at 69K. Others I know have not reported any leakage at the output end of the transfer case -- yet.
Dusty
I've seen some leaks from the transfer cases on Dakotas (it's a New Process...er... New Venture Gear unit also used by GM) and I think many of them start to weep a bit with age. But your's may be a little more severe.
A question, though: Does it appear to leak only when parked for periods of time? Is the vehicle parked on an incline? It's possible that you are realizing fluid loss because the vehicle is not on a level surface. You shouldn't get leaking out of any transfer case seal if on a level surface since the fluid level is below the lowest point of any seal when stationary.
I just checked my service manual and they don't talk about a front or input shaft seal. I can't believe there isn't one. There's one for the front and rear output shafts.
If you appear to lose less fluid during periods of operation, I would suspect that you have a seal that's dried out.
Best regards,
Dusty
Pat
The stated lubricant quantity in the transfer case is insufficient to come to the bottom of the seals of the shafts when level. So a leak at any of the seals indicates an overfilled transfer case or being parked on an incline.
Dusty
You have the NV3500 transmission.
Assuming the lubricant is the correct type and the transmission is filled correctly, you could have a problem with the gear shift lever itself or the shift tower cover. It's possible that the Shift Shaft, the Shaft Lever, or the 1-2 Shift Fork are defective. Since you had this problem from day one, it was likely defective from the start. You could have a cracked or damaged 1st syncro-ring.
I'd put some more pressure on your dealer. This is a problem that requires the transmission to come out and be inspected. In general these are pretty hardy units. Shift lever pins breaking and front input shaft bearing noise is the most common complaint on high mileage units, but if the lubricant is the correct type and never gets too low, even that would be relatively rare.
Best regards,
Dusty
I wanted to change my rear end fluid, probably to a synthetic,(mob1). How much does it hold?. Is mobil1 gear oil a good choice?
Also I wanted to change my powersteer fluid. Is this any special type? Do I need the dealer product? What is a good kind and how much needed?
I have a 01 QC 4x4 auto, 39k miles.
Tom.
Depending on the rear axle you have, the 8.25 holds 4.7 pints, the 9.25 4.9 pints. That does not include four (4) ounces of friction modifier if it's limited slip.
Mobil 1 gear oil probably is fine, but I would recommend using the Mopar synthetic 80-140W gear lubricant.
Power steering fluid is dependent on the year. Newer Dakotas use ATF+4 automatic transmission fluid. There's some ambiguity on when Dodge switched from Mopar Power Steering Fluid to ATF+4 and I can never keep it straight. I would consult your owner's manual on this one.
Best regards,
Dusty
The PCM registered a P0456, the infamous Evaporative Leak Detected code. The dealer's tech put the DRB on it and instead came up with a P0301, misfire in #1 cylinder. This surprized me since this 4.7 runs almost as smooth as a watch and my fuel mileage has been averaging 17.7 for the last 15 tanks of gas. The service manager at first said it was probably a bad fuel cap since he said the vast majority of P0456 codes are caused by it. But they're indicating that nothing was wrong in the emissions area. Time will tell. They said they found a bad connection at coil number one causing the P0301 code.
The front end groan that I thought would be sway bar bushings turned out to be dry ball joints! They greased them and so far the groan is gone, but I find this a little disconcerting. Dry means friction, in my mind any ways. I wonder how much life I took off of those ball joints driving it around for five months that way. The sway bar bushings are fine, by the way. The tech said that the newer Dakotas have a different bushing and now seldom make noise.
The window on the drivers side began chattering on the upstroke a couple of months ago and seemed to be getting slower, too. Apparently some lubricant fixed that. It now works fine.
Had the D22 recall for the wiper motor.
Since I was at 30,000 miles and seriously lacking the time, I let the dealer drain the 545RFE transmission and replace both filters. Had a coupon that Chrysler sent me that saved me $40.
The dealer's service department addressed all my concerns and my Dakota is just like new, except for the Coca Cola Icy I spilled on the carpet the other night. The truck felt different to me when I picked it up today, but I can't tell what I'm feeling. Maybe the engine is smoother, or the transmission is shifting different, or something else. But there is a difference.
Bests,
Dusty
How did they grease the ball joints? I have an 02 with no grease fittings
For that Coca Cola Icy, try Tuff Stuff (sp?). I found it at Wal-Mart in the Auto section, and it worked great on the soda stains in our van (right before I traded it on the Dakota).
Yeah, I asked that question. The service manager said they used a special tool that resembles a syringe. I assume it has a larger needle port to shoot in the fairly thick grease.
Someone here said that such a tool is available from AutoZone, etc.
Bests,
Dusty
Thanks. I tried to mop it up with a dry towel. In the form of ice it was a rather messy soda-type substance to get up. I got the most of it but the carpet is sticky in a few spots.
Appreciate the recommendation.
Bests,
Dusty
Well, I bet you won't be missing those wonderful Buffalo winters and salt covered roads.
Bests,
Dusty
Here is the link to the photo. (again)
http://hometown.aol.com/peebs4u2/dak1.jpg
I can attest that my A/C blows colder air than before I did this.
One caution: A buddy that is trained in HVAC told me that adding too much insulation to the low-pressure lines may cause the compressor to suck liquid freon.
Kevin
Check ebay.
Let us know how it works out.
Bob
What I did was READ the specs on the various pipe insulations at HomeDepot and selected one that can withstand the high underhood temps. (Foam may melt or burn)
Kevin
However, I do have a question regarding ball joints and "perma-seal" connections. I have always greased grease fittings and obviously on the new stuff like a QC, they are all non-greasable. I once knew a person that owned a "jiffy-lube" and she told me they would spray them with a special spray. (this was 20 yrs ago)
Since then I always spray them with silicone, I guess that's what they used, probably to keep the rubber pliable. I recently puchased a set of needles that have a grease fitting on them. They are to inject grease into things I assume. Now, I have heard guys on this board say they inject grease into those fittings, but my dealer knows nothing about such practices. I have also not heard of this anywhere else. Does anyone know if this is an acceptable method????
Tom.
As soon as mine reaches 36,000 miles and the suspension components are no longer covered under the factory warranty, I'm going to drill the caps on each ball joint and install a Zerks fitting so that I can grease them conventionally. My son's '93 Dakota with 270,000 miles was greased regularly and is still sporting the factory original ball joints!
Best regards,
Dusty
I'm not here to put you guys down but I am here to let you and new buyers know that dodge is the worst I have ever delt with. Now I do own a 94 half ton dodge truck with 160K miles. All I ever done to it was a water pump and radior @ 100K and just now put my 3 front pads on and never a rotor problem, and only one se of back shoes. Once someone on this site said your 94 truck has been a good one how can you burn on dodge D/Q/C and talk so bad about dodge. Man they got to be kidding. Got one good one so big deal if they make bad ones now. I bought one at a time. Anyway the good one out does the bad one in every way so the 2001 stays parked most of the time. They may have made a good 94 but these new ones are at lease the Dak. Q/C is nothing but a problem that dodge won't fix, back up are are anything. I hate it. Can't afford to trade it it. I tried and the killer part is Dodge want even give me more than 6K on this 2001 and I paid 25K 3 years ago. Not one scratch, towels on the seat so they still look new, tono cover etc. on this truck. You guys pay this much and have to buy after market stuff to fix it. LOL. Why?. Since I have had so many problems, many many many letters, reports, phone calls, trip to the shop, loss of much time etc. etc. etc., I now tell all my story and hope they don't buy what I bought and get burned. I even pull into Dodge parking lot and tell people looking at trucks and I show them my paper work if they want to see it. Dodge would have been better off to take mine back like I wanted them to at 5K miles or fix the darn thing right. O' on the rear end, the guy at the shop said I could have had an axle come out and don't even see how it was still driving like that with the shape the rearend was. Also on wet roads it would just spin around when hitting brakes kind of hard. Nope, I am done with dodge and I will let all know. Its hard for a man like me to lose 25K and still not be able to use it like a truck. Man I am so mad at them folks. Well I don't have time to spell check are re read this and I don't have the time to debate on this so I may check back in a few days, weeks, months etc.
I also want ever believe a Edmunds review cause I did the research before switching to dodge and all the problems didn't come up on this board until after I bought my 2001. All I really talked about today is the rearend and brakes but there is much more. Ya'll have a good night and LOL keep driving those wore out Dakotas form day one. I still can't believe people are still buying them. Funny stuff.
I know many people that own Dakotas of various years as well as other competitive trucks, and from a reliability standpoint the Dakota appears to be holding it's own, despite the myth that Toyota and Nissan are automatically better. Are Dakotas perfect. Nope. But a short perusal through the S10, Ford Ranger, Toyota Tacoma, and Nissan Frontier boards indicates all is not well over there, either.
Now I'm sure you will refuse to believe that most people I know with Dakotas are more than satisfied, but I don't care, unless you want to call me a liar. At this point your note is so notably sour that I doubt you'll ever change your opinion, regardless of facts otherwise, and since your admitted hatred is so obviously compulsive I'm sure Dodge felt they had nothing to lose with you.
Fortunately for you there are a host of competitive product out there. Try one. Please.
Thus, I did the most basic thing, I traded it and got a vehicle that so far has held up better than the Dak.
Yes, I agree that all Daks and Chrysler products are NOT junk. MAtter of fact, until the Dakota, I had nothing but good service from Chrysler products. And let me tell you, I pounded those vehicles, hard! Yet they never broke or left me stranded.
I see where this guy is coming from. He vented (and I have too but that was a loooooong time ago). What he needs to do is decide whether or not he wants to get his rig fixed or get rid of it and try another vehicle.
It is a crapshoot these days. I've talked with people who rave about their Hyundais and at the same time, converse with people who have had nothing but problems. So in the end, who is right?
That being said, I may consider a Dodge again when I pay off my zuke. Time will tell on that. ONe thing though, should I decide to try again with Dodge, I will research my [non-permissible content removed] off with respect to the brakes! LOL. If they are still junk, then at least I know aftermarket will be an option.....as others here have posted.:)
Well, I can understand anyone being upset with getting something less than satisfactory, especially when the product is as expensive as a motor vehicle. And I'm not naive enough to believe everyone's Dakota has been as good as mine.
But he crossed the line, in my opinion, when he tried to cast Dakota owners as something less than intelligent for buying one. It is curiously oxymoronic that he bought the same make and model as I did, yet he implies that he was fooled but the rest of us are stupid. It reeks a little of saturated self-indulgent pity. His "story" in reality is a diatribe and as such did not elicit any sympathy from me. He was in effect castigating Dakota owners for owning one. I know the type. He wants everyone to hate Dakotas and Dodge because he does and anyone with something good to say about one becomes a target for ridicule.
Needless to say my first visit for warranty service occurred last week after 23 very pleasant months in my Dak. The problems were minor and the dealer's service was outstanding. At this point in terms of both mileage and time this Dakota has been the best vehicle I've ever owned, bar none. My '93 Nissan was good, but not this good. Our '99 Toyota is as bad as the last Chevy we ever owned, which is pretty bad! Of all the people I know I can only name one that's had less vehicle service time than me and that's on a Kia.
As to the brakes, if I can keep the scuz off of mine they're smooth. My around town driving doesn't help that, unfortunately. But even this isn't a significant problem. I'm at 31K with the factory rotors -- so far. The pads are wearing very well with about 70% pad life left. I'm actually quite happy with this vehicle.
Hope everything is well with you and your family.
Take care.
Bests,
Dusty
It's unfortunate that you've had problems and even more so that either the dealer didn't back you up or the factory didn't take care of you. No one would blame you for walking away from Dodge if they couldn't get it right. But at the same time there are those that haven't experienced these problems, have had good dealer service and are justifiably pleased with the Dakota.
I will also tell you that I did my share of research before I bought this '03 Dakota. Even though most people I talked to that owned one for a while had very few problems, I was initially suspect of Dodge truck reliability. I am now convinced that the Dakota is probably one of the better trucks on the market. Yes, they had some issues in previous years but I also see that they've been addressed.
When I compare price, value, features, and performance, there is really nothing that equals the Dakota in it's market segment.
I hope your next purchase, what ever it is, is a much better experience for you.
Dusty
The Malfunction Lamp came on again a few days later. I drove to the dealer and the tech immediately checked it out with the DRB2. He said that a small leak was usually a cracked evaporative return line, either under the hood by the pump or at the fuel tank. But the lines on mine looked good. A "large leak" code is usually thrown when you fill up with gas with the engine idling, or start the vehicle with the gas cap loose or off.
In this case he felt that the gas cap might be the culprit, in part because this was intermittent and also because he didn't like the way the cap tightened. He installed a new one and so far the problem hasn't returned.
One note: the new gas cap is different than the original version. The new one is shaped somewhat differently and medium gray in color. The tech also said that the gas caps are usually the culprit for this type of problem (large leak detected). He said this was the first time he saw one that caused a "small leak" code, however.
He also said that on the '04 Dakota they went to steel lines in the evaporative return system because of this problem.
Bests,
Dusty
Is that Suzuki really holding up better? I got the impression from what I read in the Suzuki forum you were trying for a buyback!
No, its not my evil twin either!
while making turns. 50K miles. Changed rear lube with Amsoil 75/w90 + 4oz. slip additive. Squeak is gone.
Gonna need a new set of tires soon.
Can I resolve this problem myself with limited tools or do I need to take it into a dealership? Mine is a 2003 Quad 4.7 5-45RFE LSD 3.92?
Thanks in advance,
dataguru
Thanks Ger & Best Regards,
dataguru
