National Lease deal between Camaro coupe vs convertible
Dave712Dave712 Member Posts: 12
edited February 2021 in Chevrolet
Current national lease on 2021 Camaro couple 1LZ (assuming 1LT) msrp $35,595 with competitive cash is $274/ 39 mos, first payment and zero security. I am interested in a 1LT convertible lease around $37k msrp. Is the money factor and residual the same on the couple and convertible? Looking to see if lease payments would be similar and zip is 51503 and 12k/yr. Thanks
Best Answer
  • MichaellMichaell Moderator Posts: 266,505
    Answer ✓
    Dave712 said:
    Are there better miles/terms that are better than others? Not opposed to shorter terms with 39/10 advertised and ok too. Also, any idea on first responder discount and competitive lease amounts are on the convertible? Wanting to lease a convertible, just wanting to know I have square info for dealing. Thank you!
    39 months is the sweet spot. Get the number of miles you think you’ll need.
    No first responders incentive, and I see multiple conquest incentives; check with your dealer for eligibility.
Answers
    LT1 (1LZ)
    39/12
    'Vert - .00028 and 58%
    Coupe - .00028 and 63%
    Assume the MSRP of the convertible is slightly higher ($37K) - 5% of that is almost $1800, or $50/mo higher payment.
  • Dave712Dave712 Member Posts: 12
    Thank you for your help! I have used you guys over the years for leases and you were always spot on. This round I have had 2 dealers I have done business with before hit the LT1 convertible at a 43% residual; quite aways off from the 58%. They say the do not see that higher residual anywhere on their end. Any insight?
    You sure they aren't quoting you the residual for an SS?
    They were working off a 1lt they had in stock. I will double triple check with them if that appears to be the residual on a 39/10 for the SS vs 1LT. Thank you.
