Visitor Agreement.
Can someone please enlighten me ? Before I break something,
Part 2
Just came back from Linex dealer, he did a nice job and the truck looks great ! So thanks to the guys who encouraged me to pay the extra money and get a Linex, I feel it was money well spent...................now if I could only get that headlight out......................
You will be "working blind" and not see what you are doing but esssentially do the following.
1) remove the connector (squeeze the release tab first)
2) 1/4 turn counterclockwise (looking from drivers seat!) of the lamp retainer.
3) retainer pulls off (place it somwhere safe)
4) bulb pulls straight out (observe the "keying" of the tabs on the bulb)
Do not forget to clean envelope with IPA and NEVER touch it befor installing. (finger oils will cause premature failure)
In any case... I am SURE there is a way to replace headlight bulbs without removing the headlamp assemblies. (and disturbing the aiming)
Noone said it was easy...I have replaced my bulbs. (even the one behind the huge battery) Being a contortionist makes it a bit easier ;-)
Oh yeah, the driver side was easier.. except for a donated layer of knuckle skin to the project. (refer to that beer reward)
is right where the intake snorkel was. ( the snorkel will just rotate out of the way )
The drivers side is even easier, just reach in front of the battery and remove the bulb!
The headlight knob pulls out to activate the fog lights.
There should be a proper switch from mopar to replace the headlight switch in your truck. I don't think a seperate toggle switch is necessary, if the proper replacement switch can be located.
I am not sure about the sliding rear window replacement price. It may be the going price for the window and labor.
Good luck,
Bob
We all have it in out message center and follow it diligently anytime there is a new entry!
When I tested a new headlight bulb in my '00, I removed the whole assembly. There is a ball and socket (pivot point) that with a sharp pull while protecting the paint by using a soft flat piece of wood, pops out. With the headlight assembly out, you have easy access to the bulb. This is more difficult to preform in the cold of winter because the plastic ball and socket don't flex easily.
This process did not change the aim of the headlights. Also my more expensive special order Blue Vison Philips bulbs were no different than the factory originals. I don't think that you'll ever get a long lasting, significantly brighter, HID look by simply replacing the factory bulbs. Aren't HID systems $1,000+?
Many of the auto relays I install are like this. It uses MUCH less wiring to go from battery+,thru fuse, thru relay coil, thru firewall, to switch and ground the other end of the switch under the dash. This completes the relay-picking circuit.
From there, you may wire the relay contacts as you wish to perform whatever action you want.
Just spend some time with a DVM to determine what is the best way for you to wire the pick line for your driving-light relay. All you need is a switched circuit to hook up to. Use "negitive logic" if required.
I followed your instructions and with nominal skin loss to my forearms was able to change them.
Your help is appreciated.
Have lots of questions though...
Anybody attempt this on a newer Dakota???? (2000-2001)
Body lift or suspension lift??
Only thinking an inch or two.
Would larger tires work without a lift?
Ayrow
http://www.ayrow.com/truck.html
I am running 32" (actually LT265/75/16) BFG AT KOs on my 2001 4x4 QC with no problems. There might be a tiny rub on the front/lower corner of the wheel well on the front tires. I can't tell because my lower valence is a little loose and has some play from getting stuck in the mud one time. The original tires that came with the truck, 265/70/16 translate to approximately a 31" tire.
http://carrola.home.texas.net/dodge/PicsDec2000/PicsDec2000.html
mrjake, you got any pictures....I'd love to see a Dak with the MTs.
http://www.dodgedakotas.com/albums/viewer/093.htm
Anybody recognize this truck? Would very much like to learn more about the particulars of this lift.
My compliments to the owner.
Rich
KarenS "Dodge Dakota Owners: Events" Sep 24, 2001 8:16am
Tim in Atlanta
You will quickly find that the rear window is not needed... thus a defogger for a un-needed piece of glass is too.
My rear glass slides open to reveal the interior of the cargo bay. Besides... I rarely see any condensation on the rear glass anyway.
Pointing the center vents twards the rear glass should clear it very nicely. Remember to THOROUGHLY dry all carpeting with plenty of hot airflow. It is the moisture in the carpeting that evaporates and re-condenses on the interior glass. (Over 25 years of Vermont winters has taught me a trick or two)
If you REALLY want to add a defogger to the rear glass... you may need to install it yourself.
Thanks for the update on the kit..
Was getting a bit dark and the wife yelling that dinner was cooked, had to run!
Will look again tomorrow..and location details may help my quickest install..besides
circulating my 'cooler'...Thanks in advance.knowing lots of guys here have them installed..
Ger
appreciate the kick in the pants...Ger
Install was easy, bout 6 hours but I have a well stocked garage. To hide the frame, a set of westin nurf bars will tuck up nicely to the body if you swap the mounting brackest front to rear and left to right, placing the front bracket between the body and top of the body lifting block.(just notch the now front bracket mountng hole about 1 inch to make them adjustable).
Fabtech Motor Sports makes a 3" suspension lift but you must buy new rims (16" with different backspacing to clear the brakes) and this adds to the total cost.
Tim
Anyone know about K&N, or equally good, induction for 4.7 yet? If so, how's it working? Noticable improvement? How about any other performance ideas that that are cost-effective and WON'T affect warranty?
Thanks & Happy Trails from the Crossroads of the West and Home of the 2002 Winter Olympics!
I forget the exact filter model but the one i got is for the 2001. The difference is there are three tabs on the filter which fit the housing better and create a more air tight fit. The model for the 2000 does not have the tabs and just lays flat in the housing. Cant say that I have seen a huge improvement in performance or MPG but it is the piece of mind knowing that I have one of the best filters protecting my engine. John
Keith
DODGE TOOK THE TOP SEVERAL SPOTS with a Reliant K-car doing 10.5Sec at 130MPH (the Ricers rarely bettered 13 seconds.)
Why am I telling you this in a DAKOTA forum...
There was a guy with a 4.7L dakota that has obviously been down the track a few times in the past. His ONLY upgrades were a drop-in K&N and a DYNOMAX 3inch catback. He said that the pull above 3000 RPM was noticably improved.
I asked him if he would start it up so I could hear it. I was pleased that it WAS NOT extremely loud.
BTW, I've added a couple of new pics to my website and hope to put more up in the next week or so.
Is the Mopar accessories one any good? Any other ideas? Westin has some nice ones but not in Chrome for the Dak.
BTW. If you are in the Metro Atl area, "Lords" is the place to go. A couple bucks more than the cheapest, but worth it!
Travis
PS
As an aside several weeks after I got my Quad a large Buck ran into the drivers side of the bed and put in some rather large but shallow depressions into the metal. We had some hail damage on our other cars this summer that we had repaired using the paintless dent repair process. I was so impressed with the results I allowed them to work on my Quad. It is just short of amazing how they manage to restore the metal to its original shape with absolutely no external indication it was repaired. So now that my Quad has been repaired it has turned into a "deer magnet" again. Rick
Now I just have to figure out how to keep stone chips off of my grille and hood leading edge. Has anybody out there installed a full or half bra? The half bra looks OK and appears to protect the areas that usually get the most damage. What about bug/stone guards? I am looking at the EGR wraparound right now and I think it looks the best. Any experience would be appreciated.
