2021 Chevrolet Colorado Lease Deals and Prices
13
  • MichaellMichaell Moderator Posts: 269,155
    I’m looking for best MF/RV on a 2021 ZR2 Bison Edition. My area code is 85212. Thanks!
    .00135 and 64%
    No incentives
  • Extinction1229Extinction1229 Member Posts: 6
    edited April 2021
    I'm looking for the MF/RV on a 2021 Crew Cab 4WD WT (or LS). 36m/10k .. Area Code is 48356.
    Also wondering if there are any incentives
  • kyfdxkyfdx Moderator Posts: 272,729
    WT
    .00124 MF and 65% residual
    $250 customer incentive
    Don't see any supported programs for an LS trim.
    WT
    Does this MF/RV change at all if adding in 'packages' above the base? I can provide the VIN of the vehicle being leased if helpful.
    Dealership Zip is 48375 if that changes any of the calculation.
    WT
    Packages and options have no effect on the above numbers.
    Any dealer in the market area will have the same programs.
  • Mr. ToadMr. Toad Member Posts: 44
    edited April 2021
    Looking for MR/RV/Incentives on LT and Z71 4x4 V6. 36 months and 10k miles or whatever is close on the miles. 07066
    LT: .00128 MF and 67% residual
    Z71: .00131 MF and 66% residual
  • j2timesj2times Member Posts: 44
    Hi, I'd like the MF and residual for an LT crew cab 4X4 SB and a Z71 crew cab 4X4 SB. For 36mos/10k or equivalent in zip 22180. Thanks!
  • Jebba1220Jebba1220 Member Posts: 3
    Hi, can you please provide the MF, residual and incentives for a 2021 Chevy Zr2 AWD 24/18k 36/18k and 48/18k.
    In 32720 and 34711
    In 32720 and 34711
    We only have the residuals up to 15K/yr
    24/15: .00184 MF and 71% residual
    36/15: .00135 MF and 64% residual
    48/15: .00154 MF and 54% residual
  • George63George63 Member Posts: 85
    Hi There,
    May I get the MF and RV for;
    2021 Chevrolet Colorado LT - Crew Cab RWD
    24 MO
    36 MO
    15 K
    Zip; 92630
    Any Incentives.
    George63 said:
    Hi There,
    24 MO
    36 MO
    15 K
    Zip; 92630
    Any Incentives.
    .00178 MF and 70% residual
    .00128 MF and 64% residual
  • pcarrollgpcarrollg Member Posts: 17
    Hi, I was wondering if you had the MF and residual for a Z71 4x4 with short box for 36 month, 10k and 12k miles per year. My zip code is 12065, thanks!
    .00131 and 65%
    No incentives
  • saz3kgtsaz3kgt Member Posts: 1
    Good morning. Can I please get the MF and residual for 36/12k in 33067 for an LT extended cab 2WD LB and an LT crew cab 2WD SB?
    .00128 and 66%
    Either cab
  • Aloe747Aloe747 Member Posts: 7
    hello, looking for MF and residual for 36/12k in zip 33431. Crew cab short box 4-wheel drive ZR2. TY
    .00135 MF and 66% residual
    Hi, I'd like the MF and residual for a Z71 crew cab 4X4 SB. For 36m/10k, 36m/12k, and 36m/15k in zip 22180. Thanks!
    Which trim is this Z71 package on?
  • JD1234JD1234 Member Posts: 8
    Could you please provide the MF/RV for Colorado LT using 36/10K, and are there any other incentives for 33629?
    Thank you .
    Thank you .
    Which cab style?
    4x2 or 4x4?
    Please provide for both 4x2 & 4x4…
    I'm confused. Z71 is the trim.
    The Z71 is a package that can be added to multiple trims..
    "The Z71 Off-Road Package is available on almost every Silverado (standard on Trail Boss models; not available on Custom) and includes the Autotrac 2-speed transfer case, twin-tube Rancho® shocks (Rancho monotube shocks on Trail Boss), a metal underbody shield, a heavy-duty air filter, an industry-first air filter ..."
    Thank you .
    Either drive or cab
    I'm asking for a Chevy Colorado which has 4 trims, WT, LT, Z71, and ZR2.
    Well... big duh for me. I was looking at Silverado.
    Sorry.. :(
    .00131 MF and 63% residual
  • tgwooftgwoof Member Posts: 79
    LT 4WD
    tgwoof said:
    LT 4WD
    LT 4WD crew
    tgwoof said:
    LT 4WD crew
  • LTWonLTWon Member Posts: 11
    ZR2 Crew Cab
    12/36
    43065
    Thanks all!
    LTWon said:
    ZR2 Crew Cab
    12/36
    43065
    Thanks all!
  • papamak45papamak45 Member Posts: 11
    Hi, I was interested in the MF and Residual for a 2021 Colorado LT Crew Cab 4x4 36/10 in 11740. Thanks!
    Can you provide me details and incentives on a 36/12 Colorado Crew short box LT z71?
    43065
    Much Appreciated
    43065
    Much Appreciated
    .00131 and 65%
    No incentives
    Z71 4WD
    19054
    tgwoof said:
    Z71 4WD
    19054
    Sorry to ask again, with tight inventories I haven't been able to find a truck that meets my specs near me. I'd like the MF and residual for a Z71 crew cab 4X4 SB. For 36m/10k, 36m/12k, and 36m/15k in zip 22180. Thanks!
    Thank you! Is there any difference for 36/10?
    66%
  • rmcsscormcssco Member Posts: 19
    Can you tell me MF and RV for a '21 Colorado ZR2 Dbl Cab 4x4 Short box? 36/10k and 39/10k.
    Also for a '21 Colorado LT Dbl Cab 4x4 short box, 36/10k and 39/10k.
    What is your location?
    80104
    rmcssco said:
    80104
    LT - .00128 and 67% / 65%
    ZR2 - .00135 and 67% / 65%
    No incentives
    Hi, I'd like the July MF and residual for a Z71 crew cab 4X4 SB. For 36mos/10k or equivalent in zip 22180. Thanks!
