Visitor Agreement.
Bookitty
2) are there any grease fittings on the 2001 Dakota?
thanks in advance
Thanks for the feedback. As Ferous guessed, I am already pulling the car on a trailer -- it's just a little one, 14x7' deck. I'd love to have a big enclosed monster with workshop-type space and storage but I'm not too certain the QC would be happy pulling it, and it would be a bunch of $$$.
I am considering selling the existing trailer and just getting a slightly larger one -- say 18' or so -- so I can sit the car farther back and reduce the tongue weight. But if I then attach a whole bunch of stuff to the front of the trailer (tire racks, lockable cabinets, etc) then I'm eroding that advantage.
My basic question was quite straightforward -- does anyone know what's involved in removing the bed? If I go this route I'll put together a flatbed config with lockable storage for all sorts of stuff and a level roofline so I can put big things on top like I would have put in the original bed. I'm already investigating the various helper spring options (air & rubber springs seem to be the prevailing options) and I'll probably end up with a weight-distributing hitch.
I think firmer shocks are also in the cards -- both the Edelbrock IAS and the Rancho 9000 adjustables are now available for the Quad.
twj
Any feedback would be appreciated.
Robert
twj
Just my opinion and alot of others I know,
Robert
10,500 miles on the truck now.
No problems.
Been doing construction work, and have carried a lot of building materials without too much trouble. Have utilized the notches in the bed sides for the horizontal lumber supports in order to carry 4'x8' size material.
FYI: sheetrock will be better supported if a piece of plywood is used before stacking sheetrock. Without the plywood, the sheetrock seems to bend too far past the rear horizontal lumber support, and could possibly crack.
The short bed is a challenge at times when hauling long items. I have carried 16' moulding, lumber, and vinyl soffet material, by sliding it through the rear sliding window.
Have had the bed FULL of old asphault shingles and roofing material, which were hauled to the recycle center. The truck was probably at the maximum weight limit. First time I saw the rear end sag a bit. It hauled it well. The 3.92 axle ratio would have been better suited for this application. With the 3.55"s that my truck is equipped, accelleration was slower than normal, otherwise, I really did not notice there was any load at all.
Have carried 4 passengers, (this is the maximum amount of passengers this truck will carry as equipped), no complaints at all about comfort. The only complaint I heard from the passengers,is that, it was not their truck.
So far so good!
Keep on trucking,
Bob
I've been looking into the Yakima racks for the top of my QC, so I have a question for you. Do you have both cross bars on the cap and none on the cab, or do you have 1 on each?
I want to carry ladders, canoe, etc on top of my QC so I have been looking at 1 on top of my Century cap and one over the front door section of the cab. What are your comments?
The only thing I'm uncertain about is tying down a long heavy load to all three racks. Could the flexing of the bed/frame cause the fiberglass canopy to crack at rack mounting points? I'm considering using the back and cab rack for canoe, then the canopy racks for bikes or car top carrier.
Sounds like you have right configuration for hauling stuff.
My truck and cap do not have racks, so long items are slid through the rear sliding window.
Guys, I have been searching for an "over the cap" ladder rack.
I believe there are 2 which will fit.
One is from hauler racks, MODEL C-7-R, which runs about $500. It is suppose to carry 1000 lbs with the camper brackets.
The other is a universal type called the Renegade XT, made by Crosstread. It is available from different suppliers. It is suppose to carry 750 lbs with the camper brackets.
Still have to decide on which one to buy.
I am kind of leary about having racks on the fiberglass cap, as I do not know how much weight it will hold.
Any suggestions or advice are welcome.
Bob
Thought I'd throw in my 2 cents worth.. my 00/4.7/5 speed/2wd is still running fine at 44k. ran from east Texas to Guadelope river in central Texas pulling a trailer and all the camping gear with no problems.a/c ran fine,mpg's were prob 17-18.my new dayton tires were quiet yet griped like crazy in the rain and on the campground dirt roads.
I will need to do spark plugs soon and will go with the wisdom of the group.
has the rumor of the demise of the dakota been laid to rest? around here (houston)you can buy the ram 1500 with those four puny doors for thousands less than the dak..will wconomics kill us ?
all for now,...steve
MODERATOR /ADMINISTRATOR
Review your vehicle
i will do all the needed maint. soon and let you guys know how i made out.can not do truck work and have beer....lose too much skin on my knuckles!!
steve
I had a couple of small issues when my truck was new, all fixed under warranty. A bad window regulator and 2 different recall notices.
It is up to you which truck to go with.
They will still be covered by the warranty.
It is a pain in the neck to get the bugs worked out sometimes.
If it were me, I would go with truck #2.
Also, with either truck, try to get a free extended warranty and maintenance contract for all your trauma in dealing with the first truck.
Good luck,
Bob
Good luck,
Robert
good luck.
any ideas?
thanks quaddub for the comeback on #4121.
Eric
4.7L, 5 spd,3.55 LSD,2WD, Loaded, added Dodge heavy rubber mud flaps, K&N drop-in, 3" dynamax cat back, ARE LSII tonneau, Smittybilt nerf bars. So far still getting 16-17 mpg combination driving.
Took a day trip up to LA, round trip of 355 mi's. 20+ mpg on trip up from San Diego with a/c at 70 mph. Trip home was spent in traffic jams of up to 30 mph for 30% of the time, again with a/c on ended up avg of 19.4 mpg for entire trip.
I've been very happy with performance and mpg. My '98 with 5.2L same equip as '02 was not as smooth and was very easy to break the tires loose even running a taller wider tire.'02 seams to always keeps good traction even with stock Goodyears (handling package).
So far not even counting extra space in the Quad the 4.7L beats the 5.2L my opinion hands down, I can now see why everyone is so happy with the 4.7 even with the problems with other things (brakes,wipers, heater-a/c air etc.)
that is it for now hope everyone has a great 4th, and be safe!!!! So we can all talk later!!!
Lee
From the Service manual,
1. Remove sun visors and visor hooks
2. Remove coat hooks
3. Remove overhead console
4. Remove A-pillar trim
5. Remove quarter trim/B-pillar trim panels
6. Remove dome lamp
7. Separate headliner from roof panel
8. Extract headliner through door opening
I had to pull my headliner partially down to troubleshoot a windshield leaking. It appears to be a fiberglass shell with the foam/fabric glued to it. Hope this helps, Dick
However within the last week I started to get a "knocking" noise and feel which appears to be coming from the steering column. It seems to occur at the beginning of any acceleration or deceleration. It definitely was not there previously. I plan to take to the dealer, but I'd appreciate any comments or advice.
I'm sure there are posts here about this issue, I just didn't want to wade through the thousands that here now.
No knocking from my truck, so can't help you out there. Dealer should help you out about your concerns though.
Good luck,
Bob
I'll take it into the dealer next week but wondered if anybody had any thoughts on the subject.
thanks,
twj
- I averaged 14.5 MPG doing anywhere between 65 and 85 MPH. During one 400 mile stretch I got 18.5 MPG but that was with a tailwind. The rest of the trip I was fighting a 30 MPH headwind. I was a little disappointed with the MPG but maybe that's to be expected fighting a constant Nebraska wind.
- I used a quart of oil which surprised me. Previously I had not added any oil between oil changes. Maybe this was due to the engine working harder to maintain 80-85 MPH on I-80 with the headwind.
- The cruise control struggled to keep the speed constant at 80 MPH in the headwind. I figured this beefy engine could handle this speed. My old '90 Nissan Maxima 3.0 never struggled (might not be a good comparison)
- I drove for 12 hours straight and was quite happy with the ride and the comfort inside the cabin. There were 3 of us in the cab plus we had one back seat folded up for luggage storage. we had 3 dogs in the back along with more luggage and 3 bikes on the trailer hitch. (What an awesome truck)
- So far no brake problems.
Overall I am very happy with the truck so far.
I would be kind of worried about a quart of oil being consumed. I will be interested to hear if anybody else has had this engine consume oil with as little as 10,000 miles.
Blue
Neglecting mechanical drag (a very bad assumption, but we don't have the room here for the full calculation), driving 80 into a 30mph headwind requires about 2.5 times as much force than driving 70 mph on a calm day, so don't be disappointed by the reduced gas mileage on your trip. I recommend driving down-wind more often ;-)
I have an '02 4.7L 5-speed quad, and I added an ARE lid (tonneau) . . . what a great truck . . . got it Jan 6 and already have 14k on it! As for mpg, I routinely get in the 19's on the highway and 17's in town, unless I'm really getting on it . . . you gotta love that 4.7 when you punch it!
Overall, I'm very happy with the truck, except I can't believe that they only put one drink holder in the front (sheesh!). Also, the left-right deflecting capability of the air vents really sucks, but I guess it *is* a truck.
Greg
I needed more than one cup holder too with the 5-spd. manual setup and found a good solution at Walmart of all places. It fits nice and snug on the floor between the seat cushion and the plastic housing on the floor. It is called "SpillMaster" and holds two drinks and is adjustable to hold many different sizes. It can be velcro'd down or screwed down but the fit is snug so I let gravity do the work and that way it can be easily removed for the occasional cleaning. Unlike most products today, it is made in the good ole USA.
Installed them and, as expected, the nasty vibration under braking went away. The new pads have a slightly higher initial bite but are also even dustier than the stock pads! I'm surprised about that. My front wheels are almost black now.
Anyway it was a relatively cheap fix. My local dealer wanted to charge me $165 just to resurface the existing OEM rotors. So for basically the same money i've got all new parts. Incidentally after 26k miles, the OEM pads still had LOTS of life left, so i've kept them as spares for now.
twj
Have you been following these guidelines for new Rotors/Pads? This will help reduce chances of warping your new rotors before they are seasoned.
http://www.shotimes.com/brakes/part1.html
** anyone else experience this problem or something similar***?
Yes, I was most careful in seasoning the new rotors. The one thing about this which bugs me is that I don't recall exactly when I warped the OEM pieces, what driving conditions I was in, that sort of thing. So I don't know if it was genuine poor components, or I reefed on the brakes at some point and cooked 'em.
Oh well, only time will tell.
twj
