Dodge Dakota - Quad Cab
18182848687101
  • sunburnsunburn Member Posts: 319
    I've also had the MIL come on for same problem you've described. The first time I took it to the dealer. They didn't find any problems and reset the computer. About one month later, it was on again. I retrieved the OBD codes myself and saw that it was the same problem. I reset the computer myself by removing the negative battery cable for 30 sec. The problem hasn't been back since.
  • tegwjtegwj Member Posts: 51
    Dealership just called me, diagnosis says my fuel pump is going bad so they've ordered a new one but won't get it til Monday. They're not giving me a loaner, claim chrysler won't reimburse them for it anymore (previously i had an overnight loaner when some other problem wasn't fixed same day).
    Anyway net net is that it doesn't seem to have been weather/heat-related. Hopefully this will fix it...
    twj
  • bpeeblesbpeebles Member Posts: 4,085
    (tegwj) This is not an uncommon occourance. The "fuel pump assembly" wich also contians the fuel filter and other components, is known to be a 'trouble spot' on the Dakotas, Durangos and Rams. (same assembly on all truck lines)
    You should be thankful if they are paying for the replacement. I have a friend with a Ram that had to pay for his out of pocket. He was just barely beyond the warrantee period.
  • slickwilliedjslickwilliedj Member Posts: 252
    thanks for the reply. how do u retrieve the OBD codes? what did your codes say the problem was? has this occured again? i'm wondering why the dealer doesnot try this instead of droping the tank. the computer is picking something up somewhere unless its defective. what do u think would cause this sort of thing?
  • dskoczylasdskoczylas Member Posts: 22
    My truck is at the dealer right now for the Hard starting problem. I just got off the phone with service and they said no trouble codes were detected. I am going to call them back and let them know to check the Fuel pump. May save me getting stranded soon since last night the truck barely started at my son's baseball game.
    Definitely have them to do pressure tests on the fuel system. My ECU apparently hadn't thrown a code so the diagnostic test didn't reveal anything.
    twj
    You can get the OBD codes out by turning the ignition switch off-on three times ending in the on position. You heed to do the three cycles in about 3-4 sec. It can be a little tricky. Keep trying if it doesn't work the first time. The odometer will display the OBD code(s). It will display "PdonE" when all the codes have been displayed. Most service manuals have a listing of the codes. You can also find them on the internet. When I had my problems, I got the code for a small leak in the evaporative emissions system. The problem happened twice last spring. It hasn't happened since. My dealer mentioned doing a smoke test if the keeps happening. So far, it hasn't. I think the problem is due to an overly touchy sensor. I think that the evaporative emissions system maintains a slight vacuum for proper operation. Hence, a small change in vacuum (possibly caused by a loose gas cap or other leak), can cause an error.
    (sunburn) The EEC (Evaperative Emmission Contol) tests are a bit more intense than that. There are several "tests" that take place based on operational conditions of the vehicle.
    BASICALLY:
    1) Pump up a slight pressure in the fuel tank and seal it... check that it can hold this pressure.(The pump can be heard as a "clicking" under the hood for about a minute when engine is first started.)
    2)bleed the pressure thru a specific-sized orfice and time how long it takes.
    3)go back top "normal" operation of allowing the charcoal canister to store fuel vapors and then feed them into the intake manifold for burning.
    Please refer to the shop manual that contains several pages of description about the EEC tests.
    It is interesting that there is a definition of a "TRIP" which is the basis of most of the OBDII tests that take place. Without a complete "TRIP" many of the tests are void.
  • jstenjsten Member Posts: 5
    I constantly get shocked when I get out of my truck. I have a 2001 quad with cloth interior. I have been told that the frame or body are not grounded properly. What can be done? Its a real pain and I hate it. Jer
    I constantly get shocked when I get out of my truck. I have a 2001 quad with cloth interior. I have been told that the frame or body are not grounded properly. What can be done? Its a real pain and I hate it. Please help . Jer
  • james_buchananjames_buchanan Member Posts: 6
    Bought my 2001 Dakota last June. For the most part it has performed well. I've noticed a few things and just wanted to see if anyone has had similar observation with their Dakota.
    1) Flecks of debris in the paint finish upon delivery. Most of these seemed to buff out, but still very disappointing.
    2) Transmission sometimes "clunks" as I accelerate from a stop. Seems to happen before I hit 40-50 km/h. Dealer service claims this is normal.
    3) Ventilation blows a musty smell for the first 5 minutes or so. Happened with the heater in the winter and with the a/c this summer - worse in winter though. Seems to be fine once the truck warms up. Dealer service said it is probably bacteria and sprayed for it - smelled nice for a bit and then started happening again.
    4) Vinyl panel on driver's leather seat (the piece you look at when the drivers door is open) developed a couple of cracks and split open. I was especially disappointed with this because I thought I bought leather seats. Dealer said he would patch this - I just need to make an appointment.
    I noticed some TSB's since last year. Should any of these concern me? Especially interested if anyone has info about the harsh upshifts/downshifts.
    18-003-02 JAN 02 Engine - Rough Idle/Hesitation/Spark Knock
    18-025-01 OCT 01 A/T - 45RFE/545RFE Harsh Upshifts/Downshifts
    11-002-01 SEP 01 Evaporator Drain/Exhaust - Hissing Sound
    24-011-01 SEP 01 Defroster Outlets - Whistling Sound
    19-007-01 AUG 01 Power Steering - New Fluid Type
    For the most part I'm satisfied with the truck. I really like the response of the V8 engine and the Quad cab seat is great for passengers.
    bpeebles -
    Thanks for the EEC information. Whenever I've had a "Check Engine" light come on for an EEC problem, it has happened within 2 miles after a start-up. Could be a problem transitioning from one mode to another.
    In an unrelated "what are some people thinking" topic I saw a late model Ford Taurus sedan towing a 22-23 ft 15-20 year old travel trailer. The trailer has to weight 3500-4000 lbs. The car appeared to have either a class I or II hitch, so no weight distributing gear. The back end of the car was almost touching the ground. If I remember correctly, the Taurus probably has a tow rating of 2000 lbs or less. Although I couldn't verify it, I would be willing to bet the trailer's brakes weren't even hooked up. This had impending disaster written all over it.
  • homerun1homerun1 Member Posts: 5
    I too have the same shocking issues. I've never owned a vehicule that exibited this much zap. Will talk with dealer Monday.
  • spike50spike50 Member Posts: 481
    Mine came on too. Dealer asked if I left the engine running while taking the gas cap off to fill up. Sounds like the gas cap seal is real touchy and often time produces the dreaded engine light. Dealer disconnected the battery for 20 minutes (their method) and the problem went away.
  • tuvtesttuvtest Member Posts: 237
    First, the "shocks" you are describing are not from the truck's electric system, but from a buildup of static electricity. Honda Accords were natorious for this a few years ago. A common reason for this is believed to be the amount of carbon used in the tires that allows the static to ground out to the earth.
    The amount of shock seems to change based on geography and weather conditions. The humidity in the air is the biggest factor. When it's dry there's more static.
    I cannot remeber all the remedies, but some that come to mind are spraying the seats with static guard spray, or maybe rubbing them down with a bounce sheet. Changing to a tire with a higher carbon content would be an expensive fix. Some research here on Edmunds or elsewhere for fixes used on the Hondas would work for you as well.
    thankyou for your replies its nice to here some insite in this and know i'm not the only one that has had this problem. I mentioned to the dealer that maybe the gascap is just bad they didnot feel that was the problem. the truck will be going in the friday for them to drop the tank and do the smoke tests to try to determin what the problem is. ** is there is difference between simply reseting the codes via computer verse disconnecting the battery for 20 mins. is this like resetting your computer vs turning it off (aka hard reboot) if so further insite would be great! I HATE THE MIL LIGHT!
    would like to hear from others that have installed one and what improvements they have felt. is it worth the approx $260.00 according to K&N a 16hp boost with 20lbs of torque are gained. also what about other fipk brands who has the best kit that generates the most gains in HP and torque? comments pls. thanks...
    anyone have any exp with this upgrade, pro/con. what type of hp/torque gains to u get from this modification? does dodge offer a cold induction kit for the dakota 4.7l (aka fipk) also what about a exhaust system from mopar? ididnot see any listed for this truck?
    i'm considering a performace upgrade including fipk kit,exhaust system, and performace computer or chip.
    I too have been looking for an intake upgrade for my 4.7L. Over on www.dodgedakotas.com someone recently posted a link that showed that the FIPK for the 4.7L produced a maximum gain of about 7 hp. All the gain was from 3000 RPM and higher. Seems like a lot of $$$ for only a 7 hp gain. I've been looking at the Intense Performance Stage II intake. It runs about $130-135. I guess it depends on where you want the power increase. Some intakes may give you a bit more on top end, but may actually decrease power on the lower end (below 3000 RPM). If you a interested in lowering you 1/4 mile times this may be OK. I prefer a little more balance in the power output.
    Driving to work this morning, the CEL came on. I pulled over and checked the code: P 0455.
    Called the service desk at the dealer and had them look it up -- "Major Evap System Leak" or something to that effect. i.e. the you-didn't-screw-on-your-gas-cap code. Which is kind of odd, since the last time the gas cap was off was Saturday (today is Wednesday) and the Truck has been driven most of 75 miles since then.
    My fear is that the replacement fuel pump module might have a leak somewhere, but I'm unclear on whether that could throw the code as well?
    Any thoughts? Truck is an '01 4.7L 2wd, in case anybody has a directory of codes handy.
    twj
    The EECtests attempt to build a slight pressure in the air above the fuel in the tank and "hold" it for a specific amount of time. In fact, I beleave that the code you are seeing means that the target pressure cannot even be REACHED. (major leak)
    It is possible that it has taken since Saturday for the requirements of a complete "trip" to be satisfied. The EEC tests are only run under specific conditions which may be several days in between.
    YES! it is likely that the fuel-pump assy may not have been seated, a hose not clamped, or some such thing. It does not take much of a leak to throw a code.
    Your dealer has special tools to "manually" run the EEC tests and locate the leak. I have had several problems such as this (due to a porkupine nibbling on hoses at night) and my dealer was very efficent at locating the leaks quickly.
  • bcarter3bcarter3 Member Posts: 145
    Toby, Check under the truck inside of the left frame rail forward of the tank. That is where the EVAP canister is located and it has hoses connected to it. Something might have been knocked loose or left disconnected. It is in kind of of an exposed location.
  • decentman4youdecentman4you Member Posts: 27
    So I drove the truck Dak QC 01/4.7/awd-ls/auto/ and Honda trail 110, to the dealer Greenspoint Dodge in Houston tx, left the truck overnight for repair, rode the honda home, next day the Dealer said that the gas cap was not on tight, Sheesh! I always turn the cap several clicks tight to ensure that the cap is on tight, What else can I do?
    Mileage is 14,932, trip cpu avg mpg say: 13.9mpg Really is 9.927mpg presently,,,, as I only have a drive of 3.6 miles to work 1 way...
    any suggestions?
    truck was in shop this friday with the hopes of this little problem being cured. well u no the saying(nothings easy) dealer did a smoke test on emissions system to attempt to find problem. I p/u my truck same day to find out they have ordered a NEW FUEL TANK. now since my serivce advisor had left for the day, and the shop foreman and the tech that worked on my truck i dont know why there replacing the tank but will find out and post reason. anyone know why they would need to replace a full tank to correct the mil light from coming on seems kinda drastic although it looks like a simple procedure...
    you made mention that someone mentioned that they only saw a 7hp gain after installing a fipk. do u know what brand they used was it a k&n kit or mopar or other. the k&n fipk lists specics at 16hp increase\ and 20lbs increase in torque. what gives?
    ck with dealer and no performace computer is avail for the 4.7l engine only the 5.9. come on mopar get with it!!!!! there seems like not much out there in the way of performance upgrades for this engine
    I have approx 15200 miles on my 01q/c sport t/h pkg tires look about 1/2 gone and I'm considering replaceing them when there gone with a set of r/t dakota rims and tires possible increase the tire size since the q/c is not lowered like the r/t to shortin the gap between the wheel wells. as anyone seen or done this. whata think. i think it would look awesome!!
    slickwilliedj - Here's the link that claims to have the dyno numbers for the K&N FIPK for the 4.7L.
    http://www.dodgedakotas.com/boards/per/4634.html
    According to this individual, K&N stated the hp increase to be a maximum of 7.3 hp at 4700 RPM. This is probably at the rear wheels, so 10 hp at the crankshaft might be plausible. I've poked around the K&N website, but a can't find any reference to a 16 hp gain for the 4.7L FIPK. Did K&N send you these numbers?
  • iowabigguyiowabigguy Member Posts: 552
    The 2002 Dodge Accessories catalog has a Red Quad that has the 17" rims on it! Rick
    spoke to shop foreman today and he says the reason they are ordering a new fuel tank is there vents on top of the tank that are manufactured in and 1 of mine has popped out not fallen off. so that to me means that the tank cannot pressureize when the system runs it test therefore causing the mil light to show its face... perhaps dodge has some defective tanks out there. those of you that have had this problem may want to look into this. also computer is showing code p0161 or p0160 can't remember which it is. WHAT SITE ALLOWS YOU TO CROSS REF THESE CODES?
    Here's a link with the OBD-II codes.
    http://autorepair.about.com/library/ts/bl-obd-main.htm
    I PERFORMED THE COMPUTER CK BY TURNIGN THE IGNITION ON AND OFF ENDING IN THE ON POSITION THE 3RD TIME AND RETRIVED THE OBD CODE P0161 = Chrysler/Dodge/Plymouth
                                  P0161
                                                 Oxygen sensor 2/2 heater element performance or rationality malfunction.
    the first part of this description is clear however WHAT DOES (RATIONALITY MALFUNCTION) MEAN?
     THIS WAS TAKEN FROM THE FOLLOWING WEB SITE http://www.obdii.com/obdii.html
                                  P0161
  • pgorgespgorges Member Posts: 28
    I just sold my regular cab RAM 1500. I will be buying a new Dakota 4WD Quad Cab shortly. I don't see any with manual transmissions on the dealer lots. Any idea why? How smooth does the manual shift? Do you think I can buy one for $22,000 including the $2,000 rebate? I'm talking a SLT or Sport, 4.7L, with minimum options. Thanks for any info.
  • jebsdaddyjebsdaddy Member Posts: 52
    I ordered my truck with the 4.7, 5spd. and 3.92 ls. The transmission is very smooth and the shifting feels positive. The clutch is easy enough and I would recommend it.
    Robert
  • ford_biiford_bii Member Posts: 120
    I agree, the shifting is generally very smooth, but for me the shifter is a bit too loose, I'm used to Ford transmissions. The entire drivetrain on this truck is very clunky, and if you have the radio off, you can hear it pretty good. This is my first dodge, so I'm not sure if they are all like this or not, but I know that Ford transmissions are much tighter to shift, and their drivetrains are not as clunky.
    I hope this thing holds up. I read on dodgedakotas.com that other people say their transmission clunks as well. I don't know if its anything to be worried about or not. On the bright side, the 5-speed in the dakota is the same one they are now putting in the Ram, so it should be ok, since the Ram is a much heavier vehicle.
    I like the 5-speed overall, except for the loud clunking if you shift wrong or let the RPMs drop too much on a shift.
  • eagleeye13eagleeye13 Member Posts: 29
    I have an 02 QC with 4.7, 5 spd, 3.55 lsd, 5000+ mi's have had no experience with any "clunking" noises. I had a '98 same set up with no problems with 5 spd I would have the tranny checked out.
    performance chips are now available for 4.7 at asechips.com
    ASE Performance Products, Anaheim,Ca.
    714/632-9344, I called and talked to John,he seemed very helpful with info. The web site shows hp/torq increases, but req's 91 octane fuel.John said they can do changes according to what you want !!!! see post #1695 in accessories.
    Keep on Truck-in
    Lee
    Try this:
    Roll down all your windows. Drive to 4th gear, start to slow down. Drop it into 3rd, keep the clutch in, let the RPMS drop to about 1000 , then let the clutch out. Let me know if you here a loud "clunk" as the drivetrain re-engages the engine and the RPMS jump up. I can make it do it everytime. It's not just a little "click".
    Try it and let me know.
    (ford_bii) It is not the NV3500 tranny! This transmission is used in most light trucks on the road today (including Dodge RAMs and many Chevies)
    Your description sounds like the 'slop' in the rear end that we all seem to have with our Dakotas. In time, you will learn to drive VERRY smoothly. Think of it as a challange that you need to step up to. You are lucky enough to be provided the oppertunity to improve your throttle/clutch coordination.
    If you are making the engine RPMs "jump up" by releasing the clutch... there is room for improvement ;-) Try to equalize the engine RPM with the throttle BEFORE easing out on the clutch.
    There should be no noticable RPM transition between 'clutch depressed' and 'clutch released'.
    The more powerful the engine you are driving, the more this tecqunique is important to master. You would not want to be making the engine RPMs "jump up" by releasing the clutch on a 20-ton truck with a DT466 engine. You just may leave some drivetrain parts on the road!!
    As a bonus to learning proper clutch/throttle tecnique, you will find that the clutch NEVER wears out. (3 vehicles over 150,000 miles all on original clutches)
  • slr9589slr9589 Member Posts: 121
    Well I did it yesterday ! had the red fuel light on so I bought a tankful (20.0 gal.) of cheap unleaded. started for the highway,got up to 70 and the truck started bucking,surging, and shaking...not to mention that the check engine light came on. I stopped,checked the fuel cap for tightness,looked around the vehicle,than drove off to the highway.it was able to do 62 without bucking...idled ok at stop when I got off.after a 12 hour shift it ran much the same with the light still on..
    saw my dodge dealer this am but could not see the car till late pm and i work at hospital at 12 noon.took car to walmart and got can of dry gas and injector cleaner....has been in only 12 miles now..first word out of service rep's mouth was "fuel pump".....not exactly friendly!will drive vehicle 44 miles today and see what happens.
    Any thoughts guys????
    stephen
  • bookittybookitty Member Posts: 1,303
    Steve, off of the top of my head and from previous experience, it could be water in the fuel. Depending upon how much water is present, the dry gas (alcohol) may or may not solve the problem (if indeed this is the problem). There are methods to determine this, and removal is fairly simple. This has happened to me over the years with gasoline engines and twice involving diesel engines, where I actually ended up with chipped injectors. An expensive problem and difficult to lay blame.
    Bookitty
    Bruce,
    I saw your response coming from a mile away!
    In a sense you're right, it was a bit of a challenge to learn to drive this sucker smoothly. I drive it very well, probably took me about 7 k to get that way (16k on it now).
    The example about dumping the clutch was just to illustrate where the problem lies, not that I do that all the time. I think I actually get the clunking more often when I do a delayed upshift, like from 4th to 5th. What's very annoying is the occasional lapse in "perfect" shifting that would be totally normal on any other 5-speed out there, and on the Dakota you're rewarded with a great big "CLUNK".
    I guess my main complaint is that a 5-speed really shouldn't act that way (in my opinion). I have only ever driven Fords, but in my resume under trucks: 86 Bronco II, 89 Ranger, 95 F-150, 98 F-150, 2001 Super Duty (6-speed). All these are manuals, and NOT ONE HAS ANYWHERE NEAR the slop that my Dakota has. I've never had to work as hard to drive a vehicle perfect as I did for my Dakota. I love the thing, it's a great truck, but there is just something that irks me that my Dakota clunks more at 15k then my 86 Bronco II with 135k on it. I've driven my Dad's SuperDuty 6-speed and that drivetrain is solid as a rock, exactly what I would expect on a heavy duty truck.
    Normal or not, it could definitly be better. So when people ask me about how the 5-speed is, I feel it could be better. There is a looseness to the entire drivetrain, shifting, everything that just annoys me. Go take an F-150 for a ride sometime and tell me there isn't a difference, and that the drivetrain on a Dakota has to be so loose.
    I'm particularly spooked because my uncle's '98 Ram 5-speed had the rear end blow out recently, not under warranty. For what it's worth the shop that fixed it said it looked like a factory defect.
    So it's rear end slap, 'eh? Well, I guess rears are cheaper to replace then transmissions. We'll see!
    Just a final word for those who are asking about the 5-speeds, I would be very hard pressed to get another Dakota 5-speed, I would probably go with an F-150 instead. Much more positive shifting feel, stronger feeling drivetrain overall. I think Ford matched their 4.6L engine and tranny a little better then Dodge did with the 4.7L to the NV3500. (or rear-end, or whatever).
    I still think my Dakota is a great truck, and I'm not going to get rid of it, I just hope it goes the distance.
    Bruce, would you say that the clunky drivetrain/lack of smoothness is indicative of a stronger overall drivetrain? I've never driven anything bigger then my Pop's SuperDuty so I'm no expert in drivetrains. I'm only giving my 'seat-of-the-pants' opinion.
  • kwanderikwanderi Member Posts: 33
    The "clunk" has been a trade mark of Chrysler/Plymouth/Dodge rear ends since at least the early 60's.
    There is nothing wrong, I've driven mopars over 200K miles and the "clunk" got no worse or better.
    If it really bothers you that much, you might do well to get a brand X.
    Just wanted to say that the 5 spd. 4.7 3.92 is very smooth in my truck. Anyone remember the old Saturday night live skit where instead of splitting a diamond in the rear seat of the Lin. Town Car, they performed a "medical procedure" instead?
    I have been driving manual transmission vehicles for more than 25 years including Concrete mixers equipped with 13 speed road rangers and older models with a 5 spd. main transmission and a 4 spd. auxiliary transmission next to it for a total of 20 forward speeds and 4 reverses.
    Just wanted to prove my manhood with this reply and at the same time recommend the manual to anyone that desires one.
    Robert, you were fooling with those famous Mack side by side shifters. Probably had a Thermodyne as well. Been there, done that.
    Bookitty
    (ford_bii) I appreceate that you did not take my append the wrong way. It sounds to me as of you may have more "clunk" than some of the rest of us.
    You are not the first person to 'complain' about their 5SP transmission. What engine do you have? Full Time 4X4? I am just trying understand your situation. (I still beleive it is the rear-end)
    BTW
    I have purchased all of the necessarry RED LINE lubricants to change all drivetrain units on my truck. (NV3500 tranny, NV231 Xfer case, C205F front axle and 9.25" rear)
    I am especially looking forward to what the MTL will do for my transmission. It is supposed to greatly improve the shifting by making the syncronizers "Sync up" better during each gear change.
    Thanks for all the advice. I am picking up my 2002 SLT Quad tommorrow. It will have a 5 speed with the 4.7L and 3.92 axle ratio. I will post my first impression in a few days.
    Bookitty thanks for the encouraging words...i am an old new englander and dry gas is something we always kept in the garage ! But now that i live deep in tx. i had to look for it.
    Anyway,I drove to work this am and the warning light went out and it ran as smooth as silk,maybe better than before ! Have to call that dealer and cancel the service appointment...
    I will add reputable gas once it reaches half way.
    thanks for the input...
    stephen
    "Gorilla in heat" ??
    Anyways... :)
    Just to maintain that it is not my shifting, the drivetrain is noisy even when I don't shift, and just go from an off-the-gas to on-the-gas situation. This is usually if I let it glide around a corner and don't shift to a lower gear. The drivetrain will clunk when I ease back onto the gas. Kind of when the engine goes from being pushed to pushing, there is some slop somewhere in the drivetrain that makes it clunk. I've never driven a 5-sp with that amount of noise in that situation.
    My truck may be out of adjustment somewhat. I'll check with the dealer at the next inspection, I'm sure it'll be "normal", which it very well may be...for a Dodge.
  • ferousferous Member Posts: 226
    I haven't checked the board in over a week and boy did I miss some good comments
    I have the 4.7 5spd 3.55lsd and just love it. I also agree that there is a little more of a clunk with this combo than with my previous Fords or Chevy's, but I am use to it now. I have 54K miles on mine, so I should be use to it.
    Most of you know that I have been driving 43 miles to work one way, so I have racked up the miles. Not any more. Myself along with the rest of my department (Quality) was downsized last week. So the truck is just sitting in the garage. I'm looking for a job closer to home so that I don't have to drive so much. So there goes my 200K miles in 8 years goal. I guess I won't be testing the longivity of this combo. I have averaged 22.3 MPG over the life of the truck, but I know that will drop a lot if I get a job in town. My MPG always drops when I do a lot of local driving. I guess my best tank of 24.6 MPG will stand for a long time.
