2021 Jaguar XF Lease Deals and Prices
ema_jxfema_jxf Member Posts: 2
edited May 2021 in Jaguar
Please provide zip code 33018 Jaguar XF 250 SE money factor, residual and incentives for
36/10K
36/12K
39/10K
39/12K
«1
  • kyfdxkyfdx Moderator Posts: 276,430
    36/10K
    36/12K
    39/10K
    39/12K
    36/12: .00060 MF and 56% residual
    39/12: .00063 MF and 54% residual
  • ema_jxfema_jxf Member Posts: 2
    Thanks! Are the rates the same or does a program exist for 36/10K? Same residual?
  • MichaellMichaell Moderator Posts: 271,204
    Add 1% for 10K
    Same MF
  • ChicagoESQChicagoESQ Member Posts: 50
    Please provide zip code 60712 Jaguar XF P300 R Dynamic SE money factor, residual and incentives:
    24 and 36 months. 10k
    .00166 MF and 68% residual
    .00077 MF and 59% residual
    Can you update for May - zip code 60712 Jaguar XF P300 R Dynamic SE money factor, residual and incentives:
    .00166 and 68%
    .00077 and 59%
  • hotsaucedanklehotsaucedankle Member Posts: 29
    Looking for May program
    06109
    06109
    .00077 MF and 58% residual
  • 13een13een Member Posts: 5
    Hello, could you please provide MF, RV, and any incentives for 2021 Jaguar XF P300 R Dynamic in 98101 for 24/36 months and 10/12K miles per year? Many thanks!!!
    24/12 - .00166 and 67%
    36/12 - .00077 and 58%
    No incentives
  • SalvadorSalvador Member Posts: 13
    Hello, would you kindly provide the money factor, residual, & any incentives (including Jaguar loyalty) on a 2021 Jaguar XF P250 SE for the following:
    * 36mo/10k miles
    * 39mo/10k miles
    Zip code: 28759
    Many thanks for all your help!
    * 36mo/10k miles
    * 39mo/10k miles
    Zip code: 28759
    .00060 MF and 57% residual
    No info on loyalty
    Just curious if you have the factory invoice price for Jaguar XF P250 SE ? Hopefully this is close to accurate, but I have seen the following:
    * Base MSRP = $47,095
    * Destination = $1150
    * Total MSRP = Base MSRP + Destination + Any Options
    Going back to my question, I have seen a handful of different factory invoice prices. Any definitive price to your knowledge? Many thanks.
    Edmunds price tools
    Hi there, for zip code 29927 would you please provide the money factor, residual, & any incentives on a 2021 Jaguar XF P250 SE based on 36mo/10k miles?
    As always, thank you for all your help!
    .00060 and 57%
    No incentives
    Thank you very much!!!
    For zip code 28212, would you please provide the money factor & residual on a 2021 Jaguar XF P250 SE based on 36mo/10k miles and 39mo/10k miles? Thanks again.
  • Bryant_FarmsBryant_Farms Member Posts: 5
    Kindly provide the MF and residual for 2021 Jaguar XF P250 SE per the following:
    - zip: 27616
    - 36/10k
    - 36/12k
    Really appreciate in advance.
    - zip: 27616
    - 36/10k
    - 36/12k
    .00060 and 56%
    Looking for June program
    06073
    06073
    .00122 MF and 58% residual
    For June (zip 27616), would you kindly provide the MF and residual for 2021 Jaguar XF P250 SE plus any incentives/JLR loyalty for the following:
    - 36mo/10k
    - 36mo/12k
    As always, thank you very much.
    - 36mo/10k
    - 36mo/12k
    .00083 MF and 55% residual
    No loyalty info
    Per immediately above, please advise if the MF & residual differ for 36/10. Thank you.
    +1%
    edited June 2021
    kyfdx,
    Just a sanity check on your information right above...is your 55% residual tethered to 36/12 for the SE? or S? I'm running into dealership discussions where your 55% number befits instead the P250 "S" which inherently possesses a nominally higher residual than Chase's structured/published residual for the "SE" -- case in point under the June program (refer to zip 27616). Thanks.
    kyfdx,
    55% for the SE at 36/12
    59% for the S at 36/12, but the MF is higher at .00122
    Appreciate the clarification, Michaell.
    Looking for July program
    06073
    06073
    .00128 MF and 58% residual
  • TimsBait_TackleTimsBait_Tackle Member Posts: 1
    July Lease Program Question
    Money Factor + Residual % for the following:
    MSRP: $50,765
    Zip: 29466
    MSRP: $50,765
    Zip: 29466
  • Pnay01Pnay01 Member Posts: 19
    MF/Incentives/Residual on
    2021 Jaguar XF R-Dynamic SE (P 300)
    at OR 97223 for 36 m / 12 k
    .00128 and 58%
    No incentives
  • copdxcopdx Member Posts: 8
    Could I get the 10K/36mo RV and MV for a 2021 XF P300 R-Dynamic SE for ZIP 20001? Any incentives or other duration sweet spots?
    .00128 MF and 59% residual
    36 months is the best term
  • Antny3Antny3 Member Posts: 3
    What is the money factor and residual value on a 2021 XF P300 R-Dynamic SE in ZIP 06095? Are there any rebates or incentives?
    .00128 MF and 56% residual
    For August (zip 27616), would you please provide the MF & residual for 2021 Jaguar XF P250 SE plus any incentives/JLR loyalty for 36mo/12k. Thank you.
    .00128 MF and 55% residual
    No info on loyalty
    Just to confirm per above, P250 SE money factor increased from .00083 (July) to .00128 (Aug) while residual held steady at 55% for 36mo./12k fo zip 27616?
    I confirm the numbers for August. I don't have access to last month's numbers
    Thank you kyfdx.
    Looking for August program
    06073
    06073
    .00128 and 58%
    What is the money factor and residual value on a 2021 Mercedes C-Class Sedan in ZIP 06095? Are there any rebates or incentives?
