2021 Porsche Macan Lease Numbers
24
  • MichaellMichaell Moderator Posts: 266,568
    jrz995 said:
    @jrz995 said:
    Hello, good afternoon. For a 2021 Macan , could I get MF, RV, and MRM for -- 36/10k, 39/10k and also 36/15 , 39/15. (Dealer says payment is only $20 difference between 10k and 15k miles?). Thanks in advance!
    What trim level?
    Sorry, Base trim level please
    .00200 and 57% / 55% for 36/39 months and 15K
    Get the number of miles you think you'll need; there isn't a 'sweet spot'
  • kimmy05kimmy05 Member Posts: 5
    Hi, could I please get the RV, MF and any incentives for a Macan S? 36/12 and zip code is 92663. Thank you!
    .00200 and 59%
    No incentives
  • Claytoo12Claytoo12 Member Posts: 3
    Hi, could I please get the RV, MF and any incentives for a Macan S? 36/12 and zip code is 75074 Thank you!
    .00200 and 59%
    No incentives
  • ijk90825ijk90825 Member Posts: 2
    Hi, could I get RV/MF for Macan base 36/10 or 42/10 for zip code 11501? Thank you!
    .00200 MF and 60% / 56% residual
  • babramsonbabramson Member Posts: 3
    Hi, could I please get the RV, MF and any incentives for a Macan base model? 36/12 and 39/12 in zip code is 07079. Thank you!
    .00200 MF and 59% / 57% residual
    No incentives
  • SailorCarGuySailorCarGuy Member Posts: 34
    May I please have June residual / money factor. Macan base. 36/15. 19002
  • kyfdxkyfdx Moderator Posts: 269,598
    Porsche only updates quarterly.
    .00200 MF and 57% residual
  • newzienewzie Member Posts: 14
    Hello all-
    Could I get the money factor, residuals, and any incentives for a Macan Base in 50266? Also does anyone know if Porsche has an affiliate company program like some manufacturers?
    Thanks in advance!
    newzie said:
    Hello all-
    Thanks in advance!
    .00200 and 57%
    No info on affiliate programs.
  • OhioSpartanOhioSpartan Member Posts: 3
    edited June 2021
    Macan S residual, mf and incentives in 44145 please for 24/10, 24/12, 36/10 and 36/12. Thank you.
    .00200 and 66% / 59% for 24/36 months and 12K
    No incentives
  • bissimbissim Member Posts: 10
    Hello. Can I get base Macan MF/Residuals and any lease incentives for zip 19122? 36/12
    .00200 and 59%
    No incentives
  • JohkNgJohkNg Member Posts: 1
    Hello, can I get base Macan(MSRP 63k) MF/Residuals and any lease incentives for zip 98115? 36/10k. Thank you!
    .00200 MF and 60% residual
  • sender1sender1 Member Posts: 43
    Hello, can I get Macan base MF/residual zip 11797 36/10? Thanks!
  • Jam928Jam928 Member Posts: 27
    Hi, could you provide the MF and RV for a 2021 Base macan 36/12 & 36/15 in 60126 (IL). Thank you!
    .00200 and 57%
  • fncimpxfncimpx Member Posts: 11
    Hi, may I please have MF and residual for Macan S
    36 and 39 moths. 10K miles in 91724 (CA) Also, I doubt there are, but any incentives? Thanks in advance.
    .00200 and 60% / 58%
    No incentives
  • PurpleMartyrPurpleMartyr Member Posts: 2
    Hello, could I please get the MF and residual for a 2021 Macan base? 15k a year/36 months, zip 01966. Thank you!!
  • SixOh8SixOh8 Member Posts: 4
    Hello! Could I please get MF and Residual for 2021 Macan Turbo in 53029? 36/12 please.
    .00183 MF and 56% residual
  • OmemOmem Member Posts: 2
    Can I get the latest RV and MF for base versions of the Macan 2020 and 2021 (36/10K)? I'm in 11249
    2020 programs have ended.
    2021 - .00200 MF and 60% RV
  • Abhi_28Abhi_28 Member Posts: 17
    Hi, can I please know the MF and RV for a 2021 Macan base (36 months/12k miles) in zip code 20024?
    .00200 and 59%
  • Iron_100Iron_100 Member Posts: 24
    Hello ,
    Please, can you provide me with the RV / MF for the following car :.
    2021 Porsche Macan (Base-PDK 4dr All Wheel Drive)
    24m/12k
    36m/12k
    39m/12k
    Zip 32819
    Thanks again
    Iron_100 said:
    Hello ,
    24m/12k
    36m/12k
    39m/12k
    Zip 32819
    Thanks again
    .00200 MF
    66%
    59%
    57% RV
  • shireeshshireesh Member Posts: 23
    Could you share the mf & rv for macan base for 36/7.5k in 94089. And any incentives.
    thank you
    thank you
    .00200 MF and 61% RV
  • CodesCCCodesCC Member Posts: 8
    Hello
    Can you share the MF/RV/Incentives for Macan base for 36/12k in 90292/94560?
    Thanks in advance!
    CodesCC said:
    Hello
    Thanks in advance!
    .00200 and 59%
  • drgrady26drgrady26 Member Posts: 31
    Can I get the latest RV and MF for the 2021 Porsche Macan S 24/10 and 24/7.5 in Zip 60514.
    And, if available, the same for the 2022 Macan S.
    24/10
    .00200 MF and 67% residual
    No info on 2022 model
    Can I get the latest RV and MF for the 2021 Porsche Macan S in zip 60514, Please. If they don't do 7.5k miles then 5k works. Thanks!
    1. 24/7.5 and
    2. 36/7.5
    1. 24/7.5 and
    2. 36/7.5
    .00200 MF
    68%/61% residual
    1. 24/7.5 and
    2. 36/7.5
    .00200 MF
    68%/61% residual
    Dealer stated the MF at .00250. He said he'd never seen .0020. Is he flat out lying or could there be another explanation?
    drgrady26 said:
    1. 24/7.5 and
    2. 36/7.5
    .00200 MF
    68%/61% residual
    .00200 up to 42 months
  • bogart05bogart05 Member Posts: 5
    Hi there,
    Looking for mf and residual on macan base and macan s. 36 or 42 month lease, 10k miles, 91101.
    bogart05 said:
    Hi there,
    .00200 MF
    60% / 56% for 36/42 months and 10K
    Either model
  • EVSearchEVSearch Member Posts: 4
    Can I get MF and Residual for 42/10 2021 Macan GTS in 91710?
  • Umberto98Umberto98 Member Posts: 16
    Hello Everyone, Can I please get MF, Residual and Incentives for both Macan S and GTS.
    36/15k and 48/15k.
    Located in 90290
    Thank you so much!
