2021 Toyota Highlander Lease Deals and Prices
1242527293036
  • MichaellMichaell Moderator Posts: 268,966
    cramsey13 said:
    Hello - Can you please provide the MF, RV and incentives for the following:
    Zip: 43062
    36 / 10
    Toyota Highlander LE AWD
    Thank you so much for your help!
    .00140 and 65%
    No incentives
  • icarus10889icarus10889 Member Posts: 6
    Hi there! Looking for MF, RV and incentives
    Highlander Hybrid LE AWD
    Highlander Hybrid XLE FWD and AWD
    36/10 and 36/12
    Zip 54914
    36/10 and 36/12
    Zip 54914
    .00109 MF
    65% residual
    No incentives
    All three trims
    .00109 MF
    65% residual
    No incentives
    All three trims
    Is there not a 36/10 option?
  • kyfdxkyfdx Moderator Posts: 272,632
    .00109 MF
    65% residual
    No incentives
    All three trims
    +1%
  • geekrestoredincgeekrestoredinc Member Posts: 24
    edited May 2021
    Can I please get the MF, Residual and Incentives for the '21 Highlander XLE, Limited, Platinum AWD, for both Gas and hybrid. 36/12 in 20832? Thank you
    Gas
    .00141 MF
    64%, 63%, 62% residual
    Hybrid
    .00144 MF
    65%, 63%, 62% residual
  • ellmalellmal Member Posts: 14
    Hi, can you please provide the MF/RV + Lease Incentives for ZIP 23451? Thanks!
    2021 Toyota Highlander Hybrid (36m/10k): XLE / Limited / Platinum
    FWD or AWD?
    .00109 MF
    65% residual
    No incentives
    All three trims
    So dealer showed me the T1+ rate from
    Toyota and it’s .00144. Any idea why the rate provided here was different? Dealer showed me their sheet. So unless the dealership group as a whole Mark’s them up, I’m not sure why it was at that number.
    .00109 MF
    65% residual
    No incentives
    All three trims
    Sure enough, the hard copy document says .00144 MF
    Appears our provider has had a data entry problem.
    Sorry..
  • TslavinTslavin Member Posts: 7
    Can you please share the RV, MF, and incentives for the following vehicles in 97212?
    2021 Highlander XLE AWD (36/10k)
    2021 Highlander XLE FWD (36/ 10k)
  • ram_in_mdram_in_md Member Posts: 1
    Can you please share the RV, MF for 36M/15K XLE. Zip code 20878.
    2021 Highlander
    .00141 MF and 65% residual
    $500 lease cash
    Either drive
    2021 Highlander
    .00141 MF and 62% residual
    No incentives
  • avid918avid918 Member Posts: 4
    edited May 2021
    Can you please share the RV, MF and incentives for 36m/10k and 36m/12k 2021 Platinum AWD. Zip code 10965.
    .00084 and 62%
    No incentives
    FWD or AWD?
    sorry, AWD, thanks!
    FWD or AWD?
    sorry, AWD, thanks!
    .00144 MF
    66%/64%/63% residual
  • dmmoneydmmoney Member Posts: 30
    Hello can I get RV, MF, incentives in 98115 for the AWD versions of the XLE, Limited, and platinum? 36/7.5 Thanks!
    .00141 MF
    65%, 64%, 63% residual
  • RaFf78RaFf78 Member Posts: 2
    Hello - Can I get MF, RV, and incentives on AWD Platinum 36/12 in 13057?
    .00084 MF and 62% residual
    No incentives
  • goo_ACGgoo_ACG Member Posts: 1
    Looking for the MF and residual on a Toyota Highlander Hybrid XLE 36/12 in zip code 02445
    .00130 MF and 65% residual
  • cobeast1cobeast1 Member Posts: 17
    Hello! Looking for MF, RV and incentives gasoline models ONLY
    Highlander AWD XLE
    Highlander AWD Limited
    Zip 10065
    Highlander AWD XLE
    Zip 10065
    .00084 MF
    62%
    61% residual
  • BT18BT18 Member Posts: 96
    Hello, could I please get the numbers for the XLE AWD gas and hybrid for 08054
    TIA!
    TIA!
    Gas: .00084 MF and 65% residual
    Hyb: .00101 MF and 66% residual
  • Cars85250Cars85250 Member Posts: 31
    Hello can I please get
    mf and residual for (both gas/non hybrid)
    XSE AWD
    Limited AWD
    36 or 39 month lease (whatever is better for Toyota)
    15k miles year
    zip 85206
    XSE AWD
    Limited AWD
    15k miles year
    zip 85206
    .00117 MF
    62%
    61% residual
    No incentives
  • tenth_planettenth_planet Member Posts: 26
    Can you please share the RV, MF, and incentives for the following vehicles in 08732?
    2021 Highlander XLE AWD (36/12k)
    2021 Highlander XSE AWD (36/ 12k)
    .00084 and 64%
    No incentives
    Either trim
  • pmm6691pmm6691 Member Posts: 86
    Can you please share the RV, MF, and incentives for the below in 60025?
    2021 Highlander Limited AWD (36/ 10k)
    2021 Highlander Platinum AWD (36/ 10k)
    .00141 MF
    65%
    64%
    63% residual
    No incentives
  • BRW99BRW99 Member Posts: 3
    Hi! Can you please tell me the MF, Residual, and incentives for a 2021 Highlander Platinum AWD outside of Atlanta, GA (zip code 30060). Thanks
    .00179 MF and 64% residual
    Does it change if we do a 36/10?
    67%
  • kingkong827kingkong827 Member Posts: 15
    Good Morning.
    May I please have residual and money factor
    Any Incentives?
    XLE AWD 36/15 06073
    Good Morning.
    Any Incentives?
    XLE AWD 36/15 06073
  • smalleyBiggssmalleyBiggs Member Posts: 40
    Could you provide numbers for Highlander Platinum AWD in 29485 for 36/12? TIA
    edited May 2021
    .00179 and 66%
    BRW99 said:
    What do you think? Does this look like a good deal? Zip code 30062
    $900/mo for a $50K SUV?
    Not a good deal, at all.
    I assume there is no discount from MSRP, and $2200 of junk just makes things worse.
  • AnthonyGAnthonyG Member Posts: 6
    Hi. I am looking for MF/RV and incentives on 2021 Highlander Platinum FWD for 36m/12k at 92691. Thank you!
  • jwockyxyzjwockyxyz Member Posts: 5
    Please post the RV / MF / incentives for a 2021 Highlander Hybrid Platinum AWD in zip codes 07631 and 10069. Much appreciated!
    Can I get XSE AWD rv, mf, incentives in 98115 for 36/7.5? Also please confirm no incentives for limited or platinum
    .00101 and 60%
    No incentives
