2022 Land Rover Discovery Lease Deals and Prices
MichaellMichaell Moderator Posts: 270,708
edited June 2021 in Land Rover
Ask your 2022 Discovery lease questions here! Get information on money factors, residuals, incentives, deals, payments and prices.
When making a request for lease information, please include the following information for the quickest response - body style, cab style (for trucks), trim level, RWD/FWD/AWD/4x2/4x4 (as appropriate), lease term, mileage allowance and your location.
«1
  • MarcNYG1MarcNYG1 Member Posts: 48
    Can you provide the incentives, MF and RES for a '22 Discovery R Dynamic S P300 12/36 in NJ? Thank you!
  • MichaellMichaell Moderator Posts: 270,708
    .00122 and 61%
    No incentives
  • kp1a000kp1a000 Member Posts: 11
    Hi. Can you provide the MF and RES for a '22 Discovery R Dynamic HSE? It will be for 12/36 or 12/39 in NJ. Thank you.
  • kyfdxkyfdx Moderator Posts: 275,560
    .00122 MF
    58%/55% residual
  • jstrav0329jstrav0329 Member Posts: 15
    Hi, wondering about MF and RV for 7500 miles, 36 months:
    • R Dynamic HSE
    • S R Dynamic
    1. Thank you!
    • R Dynamic HSE
    • S R Dynamic
    1. Thank you!
    S R-Dynamic - 300 or 360?
    Can you send the MF & Res for 12k/36 for the Discovery R-Dynamic P300 and P360 in NJ. Thank you.
    .00128 MF
    60%/59% residual for 300/360
  • AudiNapAudiNap Member Posts: 7
    Hi, can you kindly provide MF, RES, incentives on 2022 Discovery S-R dynamic in NY? Thank you!
    P300 or P360?
  • vecarvecar Member Posts: 2
    Hi, could you please provide MF, RES, incentives on 2022 Discovery P360 HSE R-Dynamic in 43017? Thanks!
    .00128 MF and 55% residual
    What about 39/10?
    What about 39/10?
    Same numbers
  • lookingforalease123lookingforalease123 Member Posts: 8
    Can I get the MF & residual for 22MY Discovery S R- Dynamic (HC462/351QL/2.0P/30 0PS)
    22MY
    36/12 in 11790 NY
    THANKS
    22MY
    36/12 in 11790 NY
    THANKS
    P300?
    .00128 and 60%
  • CarGeeCarGee Member Posts: 24
    Can I please have the RV/MF and incentives for the following:
    1. R Dynamic S 360
    2. R Dynamic HSE 360
    Zip: 18914
    36/10k
    1. R Dynamic S 360
    Zip: 18914
    36/10k
    .00128 MF
    60%
    58% residual
  • BenzS600GuyBenzS600Guy Member Posts: 6
    Hi - Can you please provide RV and MF, incentives (if any) for the following?
    1) Discovery S (4cyl)
    2) Discovery S R Dynamic (4cyl)
    Zip 91203
    Zip 91203
    .00128 MF
    64%
    61% RV
    No incentives
    Hi - Can you please provide RV and MF for the following?
    1) Discovery P360 S-R Dynamic (6cyl)
    2) Discovery P360 HSE S-R Dynamic (6cyl)
    36/10K
    Zip 91203
    36/10K
    Zip 91203
    .00128 MF
    60%
    58% residual
    Can you please provide the RV, MF and any incentives for the HSE R- Dynamic P360.
    36/10k
    Zip: 18914
    36/10k
    Zip: 18914
    .00128 MF and 58% residual
    36/10k
    Zip: 18914
  • Snowden225Snowden225 Member Posts: 2
    Hi. Can you provide the MF and RES for a '22 Discovery R Dynamic HSE, for 12/33, 12/36, and 12/39. The zip code is 70816 (Baton Rouge, Louisiana). Thanks a bunch.
    .00128 MF
    59%, 57%, 52% residual
    Hi. Can you provide the MF and RES for a '22 Discovery R Dynamic HSE, for 12/33, 12/36, and 12/39. The zip code is 77024 (Houston, TX).
    .00128 MF
  • BeetsbyDwightBeetsbyDwight Member Posts: 44
    Hello! Interested in seeing the MF, RV, and incentives for a 2022 Discovery SE R-Dynamic in FL. Open to 24 and 36 months. Thank you!
    I don't see that trim for the 2022 Discovery.
    My bad! It's just 'S'
    300 or 360 S R-Dynamic?
    360 s r-dynamic
    360 s r-dynamic
    .00128 MF
    57% / 42% residual for 36/48 months and 15K
    .00128 MF
    Thank you!!
  • Etera1Etera1 Member Posts: 1
    Can you help with MF and residual for a 2022 Discovery p360 S R-Dynamic 4dr 4x4. 36 months, 12k miles. Zip: 53005. Dealer is quoting a MF of .00228
    .00128 MF and 59% residual
    Typical LR dealer behavior, marking up the MF
    Hi, Can you please provide the RV, MF & any incentives for the following: 12/36 & Zip: 18914
    1. 2022 Discovery S P300
    2. 2022 Discovery R-Dynamic S P300
    3. 2022 Discovery R-Dynamic S P360
    This might be an issue. I'm looking to place an order and the dealer says to put down a non-refundable deposit and the RV & MF will be calculated based on the time of delivery.
    If they decide to markup the MF, you'll have to either go with it or lose the deposit.
    You can specify no markups in your negotiation.
    .00133 MF
    62%
    59%
    59% residual
    .00133 MF
    62%
    59%
    59% residual
    But how can you prove that the dealer is marking it up other than using this forum? Does the manufacturer provide it directly to the buyer?
    LR won't give you the numbers directly.
    You'll just have to trust us ... and expect the dealer to play fair.
  • arux18arux18 Member Posts: 11
    Can I please get MF and RV for 2022 Discovery S and Discovery S R-Dynamic, both P300 engines? Zip is 33137 and looking for 7.5k miles if they do that, or 10k.
    I'm open to the cheapest month term length they have...24, 33, 36, 39, etc.
    .00133 MF
    300 S: 66%/64% residual for 33/36 mo, 7.5K/yr
    300 RDyn S: 63%/61% residual
  • OzertimeOzertime Member Posts: 56
    Can I please get the December MF and RV for 2022 Discovery HSE R-Dynamic (P360 engine) for 10k/36 and 12k/36? Zip is 92657.
    Thanks in advance
    Thanks in advance
    .00133 MF and 56% residual
