2022 Land Rover Defender Lease Deals and Prices
135678
  • MichaellMichaell Moderator Posts: 261,496
    Hi Mod,
    Can you please share the MF & RV for 2022 D90 X-DYNAMIC S, 36 months, 10k/year and 12k/year?
    Zip code 92603
    .00128 MF and 59% RV
  • deenxdeenx Member Posts: 125
    edited August 2021
    Can I please get the MF, RV and any incentives for the 2022 Defender 110 X-Dynamic HSE for 36 months, 10K miles/year in zip code 32224. Thank you.
    .00128 and 58%
    No incentives
  • SkullbaeSkullbae Member Posts: 4
    Hello mod,
    Could I please get the MF and residual value on a 2022 D110 X-dynamic SE for 24months 5k, 7.5k and 10k. Thanks In advance
    Sorry zip 11211
    Skullbae said:
    Hello mod,
    Skullbae said:
    Sorry zip 11211
    24/10
    .00193 MF
    73% residual
  • SevoDesSevoDes Member Posts: 4
    2022 D110 S 36/12, MF, residual, 62025. Thanks!
  • bentobento Member Posts: 5
    Hi Mod,
    Can I get the MF and RV on 2022 S or S110 for 24/10 and 24/12. Zip 07470
    Thanks you
  • kyfdxkyfdx Moderator Posts: 264,407
    .00128 MF and 67% residual
    bento said:
    Hi Mod,
    Thanks you
    Number first, then the letter.
    Please try again. Not sure which two trims you want.
    Sorry 110 and 110S
    bento said:
    Hi Mod,
    Thanks you
    bento said:
    Sorry 110 and 110S
    24/12
    .00193 MF
    81% RV
    Either model
  • Damian2505Damian2505 Member Posts: 97
    Can I have the MF and RV for Defender S 90 and 110 24/12 33157 zip code thanks
    .00193 MF
    76% / 81% for 90/110
    2022 Defender 90 x-dynamic S, RV, MF 36/12, 62025. Thanks
    .00128 MF and 59% residual
  • bucks84bucks84 Member Posts: 3
    Hey,
    Hoping to get lease terms for a 110S or 110SE, 36/10, 85249.
    bucks84 said:
    Hey,
    .00128 MF
    68%/64% residual for S/SE
  • Justme123Justme123 Member Posts: 1
    Can you please help me with rates and residuals for
    Defender 110X base and Discovery Sport
    Both base with all wheel drive option and 2022
    ZiP 02493
    24/10, 35/10 or 40-42/10
    Do you have any incentives info as well?
    Thanks in advance!
    ZiP 02493
    Thanks in advance!
    110X
    24: .00193 MF and 64% residual
    36/42: .00128 MF and 53%/46% residual
    There are no 2022 Discovery Sport numbers
  • nickboznickboz Member Posts: 13
    Looking for some help on Defender 110 V8s
    What are the currents residuals and money factors for 92603 and 5k to 7500 miles per year. 36 or 39 months for term as well.
    Thank you again
    Thank you again
    .00128 MF
    62% / 58% for 36/39 months and 7500 miles
    Thank you again
    .00128 MF
    62% is for the 2022 V8? My dealer is quoting 51%, 36/7500
    Thank you again
    .00128 MF
    Sorry, the correct residuals are:
    51%/49% for 36/39 mo, 7.5K/yr
  • mrh1976mrh1976 Member Posts: 14
    Def 110s
    60126
    36m
    12k
    This place rocks, thanks so much
    mrh1976 said:
    Def 110s
    60126
    36m
    12k
    .00128 MF and 66% residual
  • mattevanmattevan Member Posts: 57
    Hello, may I please get MF/Res for 110 S
    24/12k
    33/12k
    Many thanks.
    24/12k
    33/12k
    Many thanks.
    .00193 and 80%
    .00128 and 70%
  • connorbmxconnorbmx Member Posts: 19
    Can I get the MF & Residual on a 22 Defender 110 s 4cyl & 22 Defender X Dynamic SE 15k/36mo
    .00128 MF
    64% and 57% residual, respectively
  • po65nypo65ny Member Posts: 34
    Hello, can you please send MF/Res for 2022 90 X-Dynamic S in zip 92618?
    24 / 7.5k
    36 / 7.5k
    Thanks in advance
    24 / 7.5k
    36 / 7.5k
    Thanks in advance
    .00193 MF and 72% residual
    .00128 MF and 60% residual
  • inaterinater Member Posts: 14
    Can I please get MF/Res for 36/15 for a 2022 base 110. Zipcode is 78703
    .00128 MF and 65% residual
  • chicagocarschicagocars Member Posts: 9
    MF and residual please for: Zip 60093 2022 110SE 400PS 3.0P at 15k/yr on 36month.
    I was told they are using 0.00228 and 60% for 36 months. Attached is the payment sheet. Are dealers charging more right now due to chip/delivery issues and if so, what amount is a reasonable market rate upcharge?
    No markup on the MF is reasonable, in my book.
    But, given the current supply issues, almost every dealer is marking up the MF (not just LR, mind you).
    Work to get the base MF - engage with multiple dealers, if possible.
  • DS_princeDS_prince Member Posts: 2
    Hi ,
    Can you please share the MF & RV for 2022 Defender 110 XS
    36 months, 12k/year
    36 months, 15K/year
    Zip code 08540
    DS_prince said:
    Hi ,
    36 months, 12k/year
    36 months, 15K/year
    Zip code 08540
    .00128 MF
    59% residual
  • taichi84taichi84 Member Posts: 48
    Hi Can you please provide the MF & RV for 2022 Land Rover Defender 110 S and 110 SE?
    33/10
    19355
    33/10
    19355
    .00128 MF
    71% / 66% for S / SE
  • mtbuonocoremtbuonocore Member Posts: 16
    Hi can I have the MF and RV for a 2022 Land Rover Defender 110SE, 36/12 and 36/15 for 07853. Thank you.
    .00128 MF
    60% RV
  • Mmac47Mmac47 Member Posts: 23
    Hello- many thanks for you guidance over the years. Looking for 24/12 and 36/12 MF and residuals on a Defender 110S. 60187
    .00193 MF and 80% residual
    .00128 MF
    60% RV
    What would be the RV for 36/12? Thank you!
    .00128 MF
    60% RV
    62% RV
  • rrbarchettarrbarchetta Member Posts: 7
    Looking for numbers on 110S P300 and 110SE P400 33/10 and 24/10 in MA. Thanks!
    24/10
    .00193 and 81% / 76% for S / SE
    33/10
    .00128 and 71% / 66%
