ClaireS, Host
Terry
-Rob
ClaireS
:confuse:
believer
I loved that car, bought it new and when I traded her in she had 177,900 miles on her! The only thing not factory was the tint, Ungo alarm and remote start. She was in darn good shape and I while I definitely was ready for a new ride, I do miss her.
HTH,
Click
Has anyone ever replaced or fixed the drivers seat recliner latch on this 2 door ZX2?
Somehow that got sprung and it's irrititating as it is either fully straight up or totally flat back, nothing in between. I can find many 4 door Escorts in the local junk yards but the recliner does not look the same, probably since the 2 dr allows move ahead and rear seat entry. So far no hits on internet used parts either. The dealer wants $130 for a new recliner ... any ideas on how to fix or where to find a junk 98-01 Escort ZX2? :confuse:
Believer
I was reading about the idle problem people have, I have 51,000 miles on mine and I haven't seemed to notice any idle problem. Did they fix it before my year?
All I have found is an Audiovox aftermarket C/C kit and I'm not a fan of Audiovox products.
Btw, why the hell would Ford give me power mirrors and A/C, but not C/C and A/C???
Also, so some of you know, I've been told by 6 differant tire shops in town that you can NOT go any bigger than 185/60/R14 tires on these ZX2's because of front shock tower clearance.
Also it has a lot of vibration.
I'm getting really frustrated with my car.
Actual "tune-ups" on the newer cars really only consists of new plugs and possibly cleaning the injectors. I would be more concerned as to whether the timing belt has ever been replaced ( bet it hasn't) and at 75K you'd better at least have it checked. A failed belt can destroy the engine or at the least strand you somewhere on a dark and stormy night. Been there ,done that !!
believer
My son had a 2001 ZX and it always had a rough idle since new but got worse as the miles built up. At about 48K it got so bad he finally dumped it. He tried ALL the supposed "fixes" including the motor mounts. Nothing really worked.
I was going to buy a ZX2 back when my son did but out of the 4 or 5 I test drove they all shook @ idle. I had been used to Honda engines and of course was spoiled for their smoothe operation. Even the company vehicles our service techs drove ( Cavs & Sunfires with the Ecotech motors) were a lot better than the Ford engine in the ZX2.
The most the Ford people could suggest for the problem was "you'll just have to learn to live with it" Bill Ford can blame a lot of lost sales on that motor for sure.
believer
:sick: :confuse:
:confuse:
What you have is a clogged up crankcase breather filter. This is a $10-15 dealer part, and it takes about 2 min to change. Crankcase Breather Filter In that link it is the cylinder to the right of the red arrow. It is on the top rear of the drivers side of the valve cover. This noise drove several months and well over $500 trying to figure out what it was. You can check by taking the one that is on your car off and try to blow through it. If it is hard to do that then its time go go get another one. Write down the part number and take it to the service desk at your local parts store and you should be good to go. Let me know if you need anymore help.
Robert :shades:
I just bought my 98zx2 two days ago and it has some problems
granted I got it for $2,000 but it supposedly has only
60K miles on it... the service engine light came on today
and my cold/heater nob rotates as though it's hooked up to nothing? it's a base modle, plus I had the oil changed
and the guy put 4.5 qrts in the engine seems like too much?
And he told me that it needs a new transmission gasket?
do you know the cost of that? part and labor?
the engine and the transmission from underneath.
David
After getting the code from Autozone, took it to an auto repair shop, and they didnt really think it was that big of a deal...
I also have the EXACT same squeal/screech noise. However, I replaced the pcv valve and it still makes the same noise. The 1998 ZX2 does not have a Crankcase Breather Filter - at least that is what the dealer said when I tried to buy the part (I also could not find one in my Chilton's Repair Manual).
It is interesting to note that the noise goes away completely when I pull out the PCV Valve and just let it hang outside of its receptacle. So, it looks like the hose is blocked somewhere between the PCV Valve and its terminus. The hose goes up under the intake and I can't quite seem to figure out where it ends. In any case, I can't find any type of filter that might be clogged.
Any help someone can provide would be much appreciated!
Thanks in advance for you help,
Maurice
