I was told they are using 0.00228 and 60% for 36 months. Attached is the payment sheet. Are dealers charging more right now due to chip/delivery issues and if so, what amount is a reasonable market rate upcharge?
No markup on the MF is reasonable, in my book.
But, given the current supply issues, almost every dealer is marking up the MF (not just LR, mind you).
Work to get the base MF - engage with multiple dealers, if possible.
.00128 MF and 59% RV
Can I please get the MF, RV and any incentives for the 2022 Defender 110 X-Dynamic HSE for 36 months, 10K miles/year in zip code 32224. Thank you.
No incentives
Hello mod,
Could I please get the MF and residual value on a 2022 D110 X-dynamic SE for 24months 5k, 7.5k and 10k. Thanks In advance
Sorry zip 11211
.00193 MF
73% residual
2022 D110 S 36/12, MF, residual, 62025. Thanks!
Can I get the MF and RV on 2022 S or S110 for 24/10 and 24/12. Zip 07470
Thanks you
Please try again. Not sure which two trims you want.
.00193 MF
81% RV
Either model
Can I have the MF and RV for Defender S 90 and 110 24/12 33157 zip code thanks
76% / 81% for 90/110
2022 Defender 90 x-dynamic S, RV, MF 36/12, 62025. Thanks
Hey,
Hoping to get lease terms for a 110S or 110SE, 36/10, 85249.
68%/64% residual for S/SE
Can you please help me with rates and residuals for
Defender 110X base and Discovery Sport
Both base with all wheel drive option and 2022
ZiP 02493
24/10, 35/10 or 40-42/10
Do you have any incentives info as well?
Thanks in advance!
24: .00193 MF and 64% residual
36/42: .00128 MF and 53%/46% residual
There are no 2022 Discovery Sport numbers
Looking for some help on Defender 110 V8s
What are the currents residuals and money factors for 92603 and 5k to 7500 miles per year. 36 or 39 months for term as well.
Thank you again
62% / 58% for 36/39 months and 7500 miles
62% is for the 2022 V8? My dealer is quoting 51%, 36/7500
51%/49% for 36/39 mo, 7.5K/yr
36m
12k
This place rocks, thanks so much
Hello, may I please get MF/Res for 110 S
24/12k
33/12k
Many thanks.
.00128 and 70%
Can I get the MF & Residual on a 22 Defender 110 s 4cyl & 22 Defender X Dynamic SE 15k/36mo
64% and 57% residual, respectively
24 / 7.5k
36 / 7.5k
Thanks in advance
.00128 MF and 60% residual
Can I please get MF/Res for 36/15 for a 2022 base 110. Zipcode is 78703
Can you please share the MF & RV for 2022 Defender 110 XS
36 months, 12k/year
36 months, 15K/year
Zip code 08540
.00128 MF
59% residual
33/10
19355
71% / 66% for S / SE
.00128 MF
60% RV
Hello- many thanks for you guidance over the years. Looking for 24/12 and 36/12 MF and residuals on a Defender 110S. 60187
.00128 MF and 66% residual
What would be the RV for 36/12? Thank you!
62% RV
.00193 and 81% / 76% for S / SE
33/10
.00128 and 71% / 66%
