2021 Ram 1500 Lease Deals and Prices
13738394143
  • JayB91JayB91 Member Posts: 53
    May I please have the rv, mf, and incentives for ram bighorn crew cab with the hemi v8 for 33755. 36/12
  • kyfdxkyfdx Moderator Posts: 272,632
    2WD or 4WD?
  • samnj2018samnj2018 Member Posts: 4
    Hi, I am looking for MF ,RV & Incentives for 2021 Ram1500 BIG HORN CREW CAB 4X4 5'7 BOX 4WD for 3 year 15K/yr lease in zip 22630. TIA.
    .00064 MF and 53% residual
    $2225 incentive
    Hi, I am looking for MF ,RV & Incentives for 2021 Ram1500 BIG HORN CREW CAB 4X4 5'7 BOX 4WD for 3 year 15K/yr lease in following zips,
    08515
    21228
    TIA
  • MichaellMichaell Moderator Posts: 269,018
    08515
    21228
    TIA
    .00064 and 53%
    $2225 incentives
    Either location
  • dylrexdylrex Member Posts: 130
    Hello. Looking for the MF ,RV & Incentives for the 2021 Ram1500 BIG HORN CREW CAB 4X4 5'7 BOX 4WD for a 3/36k lease in zip 41048.
    Thank you in advance!
    .00064 and 55%
    $3350 incentives
  • mort4848mort4848 Member Posts: 25
    Can I get the MF RV and incentive for a 2021 Ram 1500 Big Horn Quad Cab 4X2 Night edition for 3/36K lease in 71115 ?
    .00075 MF and 53% RV
    No incentives
  • ErlexxErlexx Member Posts: 50
    Can I get the MF RV and incentives for a 2021 RAM 1500 Big Horn and Laramie Crew Cab 4x4 for 3 year 15k miles please. 40475
    BH - .00064 and 53%; $3350 incentives
    LAR - .00060 and 53%; $1350 incentives
    Thank you! Could I also get the same numbers for 10K miles?
    Add 3% to residual
  • KJP1994KJP1994 Member Posts: 17
    Hey and thanks in advance. Can I get the MF RV and incentives for a 2021 RAM 1500 Big Horn and Laramie Crew Cab 4x4 for 3 year 15k miles please. 07753
    BH: .00064 MF and 53% residual. $1225 incentive
    LAR: .00060 MF and 53% residual. $725 incentive
  • Sal93Sal93 Member Posts: 32
    Can I get the MF RV and incentives for a 2021 RAM Laramie Crew Cab 4x4 for 3 year 15k miles please. Zip 94804.
  • aldayiialdayii Member Posts: 3
    Looking for the money factor and residual (and incentives if they exist) for a 2021 RAM Laramie Crew Cab 4x4 for 3 year 15k miles in the Zip code 46204.
    Appreciate your help with all the quotes.
    $1350 incentive
  • mmendoza2mmendoza2 Member Posts: 200
    Good evening,
    May i please have the mf and residual for a 2021 ram 1500 big horn crew cab (rwd) in south florida (33027) for the following terms:
    Any incentives??
    mmendoza2 said:
    Good evening,
    Any incentives??
    36/12 - .00082 and 54%
    42/12 - .00087 and 52%
    $1000 incentives
    mmendoza2 said:
    Good evening,
    Any incentives??
    $1000 incentives
    Will the numbers be the same on a Big Horn with a Diesel engine?
    Lastly, are the the numbers on a Laramie different?
    mmendoza2 said:
    mmendoza2 said:
    Good evening,
    Any incentives??
    $1000 incentives
    Same for diesel
    Laramie are different
  • koyp975koyp975 Member Posts: 14
    Would you be able to share the MF, RV, and any incentives for a 2021 or 2022 RAM 1500 Laramie RWD or AWD for 36mo/12K and 36mo/15K at ZIP 85224, please? Thank you for the reply in advance!
    2021
    2WD: .00066 MF and 51% residual
    4WD: .00060 MF and 53% residual
    $1000 incentive
    2022 model discussion
  • walnut05walnut05 Member Posts: 1
    Hello, Looking for MF,RV, and any incentives for a 2021 Ram 1550 classic 4WD quadcab warlock, 39mo/10K for zip 14432. Please and thank you in advance.
    36/10: .00021 MF and 51% residual
    42/10: .00025 MF and 49% residual
    $3525 incentive
    39 month term is not supported
  • KaiserLaw313KaiserLaw313 Member Posts: 16
    Good Afternoon,
    Can I please get October’s numbers for:
    Laramie crew cab 4x4
    Longhorn crew 4x4
    Zip: 60631
    Good Afternoon,
    Longhorn crew 4x4
    Zip: 60631
    LAR: .00060 MF and 56% residual
    LH: Standard MF and 52% residual
    $725 incentive
    edited October 2021
    mmendoza2 said:
    mmendoza2 said:
    Good evening,
    Any incentives??
    $1000 incentives
    Same for diesel
    Can you please provide me with the MF and Residual for the same Big Horn crew cab (South FL - 33027) with 10000 miles a year on a 36 and 42 month term.
    Could you also do the same for a Laramie?
    mmendoza2 said:
    mmendoza2 said:
    mmendoza2 said:
    Good evening,
    Any incentives??
    $1000 incentives
    Same for diesel
    What is the MF and residual percentage for a base Laramie crew cab (RWD) in South FL (33027)?
    is the $1000 incentive still applicable?
    .00066 MF and 54% residual
    .00072 MF and 52% residual
    $1000 incentive
    mmendoza2 said:
    mmendoza2 said:
    mmendoza2 said:
    Good evening,
    Any incentives??
    $1000 incentives
    Same for diesel
    $1000 incentive
    Could you please provide the same info for the Big Horn? sorry for the multiple questions. I have to pick one so I'm trying to do the comparison between a loaded Big Horn or a base Laramie.
    mmendoza2 said:
    mmendoza2 said:
    mmendoza2 said:
    mmendoza2 said:
    Good evening,
    Any incentives??
    $1000 incentives
    Same for diesel
    $1000 incentive
    Add 1% to the 12K/yr residuals
  • jplino1jplino1 Member Posts: 95
    Looking for numbers on a 2021 Laramie 4x4 Crew Cab Diesel 36/15 in 33609? Thanks!
    $1000 incentive
  • EbelhjsEbelhjs Member Posts: 1
    edited October 2021
    Could I please get the numbers on a 2021 Big Horn 2WD V6 quad cab 36/12 in 30060? Thanks!
    .00082 MF
    53% RV
    $1000 incentives
  • MichaelMMichaelM Member Posts: 2
    Can I please get the numbers on a 2021 Ram 1500 Limited Crew Cab 4x4 eco diesel? 36/15 (or longer term if available). Zip 76657. Thanks!
    Standard MF
    50% / 48% / 44% residual for 36/42/48 months, 15K/yr
  • TrentgwTrentgw Member Posts: 59
    Hi - Can I get the numbers on 2021 Ram 1500 Laramie Crew Cab 4x4?
    36/12 and 36/15 for Zip 64055
    $2000 incentives
  • blkx97blkx97 Member Posts: 23
    Can I get numbers on a 2021 RAM 1500 LARAMIE CREW CAB 4X4? 36/15 for zip code 19525. I'm a current Chrysler Capitol lessee. Thanks!!!
    $1225 incentive
    No info on loyalty
  • Wdbrown55Wdbrown55 Member Posts: 1
    Can I get current numbers for 2021 Big Horn Night Edition quad cab and crew cab, 4x4, for 36/10k for 43213 Ohio. Thanks!
    Crew - .00064 MF and 56% residual; $3350 lease cash
    Quad - .00060 and 56%; $3750 lease cash
  • Pavers2020Pavers2020 Member Posts: 1
    Can I get the MF and RV on 2021 Ram 1500 big horn crew cab 5’7 4x4. Also incentives. 39/10, 36/10. Not sure if they are doing 42 months? Located 07737
    36/10 - .00064 and 56%
    42/10 - .00070 and 53%
    $1725 incentives
  • KevKevKevKev Member Posts: 3
    Can I get current numbers on a 2021 Ram 1500 limited crew cab w/ Night Edition 5’7 4x2? 36/12 and 36/10. Zip 77070. Thank you so much.
