2022 Nissan Frontier Lease Deals and Prices
2456716
  • travisbrotravisbro Member Posts: 8
    MF and RV for 22' frontier Pro-4x crew cab and SV model please?
    36/12, zip 97005
  • MichaellMichaell Moderator Posts: 269,001
    36/12, zip 97005
    SV -
    King Cab or Crew Cab?
    4x2 or 4x4?
  • Mikemikemike1313Mikemikemike1313 Member Posts: 6
    Hi, can I have rv/mf for SV 4x4 and Pro4x for 08816. Crewmax short bed. 24/10 and 36/10 please.
    .00213 MF
    Pro4X - 89% / 76%
    SV - 86% / 74%
    36/12, zip 97005
    SV -
    4x2 or 4x4?
    SV- Crew Cab 4x4
    travisbro said:
    36/12, zip 97005
    SV -
    4x2 or 4x4?
    SV- Crew Cab 4x4
    .00213 MF
    Pro-4x - 74%
    SV - 72% (short bed)
  • edwardk15edwardk15 Member Posts: 7
    Could I please get the number for 22 Crew Cab 4x4 S for 24 and 36 months with whatever is the lowest miles allowance for Colorado 80015.
    .00213 MF
    91% / 78% for 24/36 and 10K
  • purduealum91purduealum91 Member Posts: 285
    Please forward the MF, RV, and incentives for 24/15 S, SV and Pro-4X in zip code 07960. Thank you so much.
    Just following up to my request just in case it didn’t go through. Thank you so much.
  • kyfdxkyfdx Moderator Posts: 272,632
    Assuming all three are Crew Cab and 4X4
    .00213 MF
    88%, 83%, 86% residual
    No incentives
  • GrandPappyJGrandPappyJ Member Posts: 4
    May I please have MF and RV for 2022 Frontier Pro-4X? Thanks!
    24/12 and 36/12
    37601
    24/12 and 36/12
    37601
    .00213 MF
    87% / 74% RV
    Please forward the MF and RV for a S, SV and Pro-X extended cab 4x4, 36 months, 15k per year in zip code 07960. Thank you so much in advance. I
    New programs start on Tuesday.
    Good morning,
    When will November's numbers be known?
    Crew cab please
    Crew cab please
    Pro-4X: .00212 MF and 72% residual
    S: .00213 MF and 75% residual
    SV: .00213 MF and 71% residual
    Moderator, Im so sorry, but I thought I had requested the 24 month numbers too. Can you please provide these as well?
    Same mileage - 15k per year
    85%
    88%
    83%
  • ebuccoebucco Member Posts: 11
    It is my understanding that there is now an 18 month lease available on the 2022 Frontier. Can someone share the MF, RV and Incentives for 18/10 on a Pro 4X 4X4 in 10307.
    Thank You.
    Thank You.
    .00212 MF and 94% RV
    No incentives
  • hawkmultimediahawkmultimedia Member Posts: 9
    Hi, may I get MF and RV for '22 PRO-4X crew cab for 24mo/15k and 36mo/15k in 40324? Thanks
    .00212 MF
    85%/72% residual
    Thanks for all of the help! Was able to negotiate a lease for a Frontier S Crew Cab 4x4 in NJ, MSRP $35,535, zero down, 24 months, 15k, drive off only - $290 per month.
    Thanks for the report.
  • qbrozenqbrozen Member Posts: 33,851
    you say "drive off only." What does that mean? What exactly did you pay at signing?
  • vanlor90vanlor90 Member Posts: 8
    Hi. Can i please get mf and residual for pro-4x 76248?
    24mo/10k miles
    24mo/12k miles
    Can i also get 76248 pro-4x for 18mo/10k miles?
    24mo/10k miles
    24mo/12k miles
    .00212 MF
    94%/88% residual for 18/24 mo, 10K/yr
  • Khawkins10Khawkins10 Member Posts: 22
    Hello. May I please have numbers for 2022 4x4 Crew Cab Frontier SV - 36/12 in 64152. Also any incentives?
    .00213 MF and 72% residual
  • GooteechevGooteechev Member Posts: 104
    Crew Cab S/SV 4x4 18 months 10K 97006
    .00213 MF
    98%/92% residual for S/SV
    How about PRO 4-X 4x4 18 months 97006 10K
    .00212 MF and 94% residual
  • petspepetspe Member Posts: 7
    Hello. May I please have numbers for 2022 4x4 Crew Cab Frontier PRO 4X - 36/15 24/15 in 63011. Also any incentives?
    edited November 2021
    .00212 MF
    85% 24/15
    72% 36/15
    No incentives
  • DFischer85DFischer85 Member Posts: 10
    May I please have the MF and RV for 2022 4x2/4x4 Frontier S , SV Crewcab and Frontier PRO 4x4 for 24/10 and 36/10 ? 08094
    PRO 4-X
    .00212 MF
    88%/75% residual
    .00213 MF
    S 2WD: 89%/75%
    S 4WD: 91%/78%
    SV 2WD: 84%/71%
    SV 4WD: 86%/74%
    Apologies. Could I also get 18/10 for S,SV 4WD as well as PRO 4x4? 08094
    Pro 4X - 94%
    S - 93%
    SV - 92%
    Same MF as above
  • ApplephanApplephan Member Posts: 52
    Please forward the December MF, RV, and incentives for 24/15 S, SV and Pro-4X Crew Cab in zip code 07960. Thank you so much.
    .00213 MF
    88%, 83%, 85% residual
    Assuming all are 4WD
  • timmccluretimmcclure Member Posts: 1
    Hello. Can I please have MF and RV for a S trim 4WD crew cab in 08053? 18/10 and 24/10 please. Thank you!
    .00213 MF
    98% 18/10
    91% 24/10
  • amruamru Member Posts: 38
    Can I have mf and rv for SV and PRO4x crew cab 4wd
    For 80014
    24/15
    If you can also tell me what the sweetspot is for mileage and term?
    For 80014
    24/15
    SV - .00213 and 83% / 71% for 24/36 and 15K
    Pro4X - .00212 and 85% / 72%
    Looks like the shorter term will give you a better payment on the Frontier.
