2022 Audi RS6 Avant Lease Deals and Prices
kyfdxkyfdx Moderator Posts: 276,019
edited October 2021 in Audi
Ask your 2022 RS6 lease questions here! Get info about prices, money factor, deals, incentives, and payments.
  • ssimssim Member Posts: 113
    2022 RS6 36/10k ZIP 90211
  • kyfdxkyfdx Moderator Posts: 276,019
    .00170 MF and 58% residual
    edited October 2021
    Is MF the same across the entire country (like Porsche) or does it vary by region? If it varies by region, is it based on where I'm located or where the dealership is located?
  • MichaellMichaell Moderator Posts: 270,923
    Audi numbers are national.
  • rewtri1rewtri1 Member Posts: 8
    2022 RS6 36/10k ZIP 37215
    .00171 MF and 58% residual
  • hybrid_eghybrid_eg Member Posts: 46
    2022 RS6 36/10k ZIP 92663 (mf/res/any incentives)
    .00184 and 58%
    No incentives
  • kevin911kevin911 Member Posts: 22
    Hi. May I have leasing factor and residual on 2022 RS6 Avant, 36 month, 15k in 83001?
    Kevin911
    .00251 MF and 57% residual
  • willemattwillematt Member Posts: 4
    Can I have 36/12 in 19010?
    .00264 MF and 59% residual
  • mbc320_sportmbc320_sport Member Posts: 50
    Can I have 36/10K and 48/10k in 90064?
    .00287 and 62%
    .00307 and 55%
  • peterm17peterm17 Member Posts: 8
    Can I have 24/10k and 24/7k and 36/7k for 07624
    .00287 MF
    69%/62% residual for 24/36 mo, 10K/yr
    +1% for 7.5K/yr
  • SlateEdSlateEd Member Posts: 3
    Are these numbers historically predictable by time-of-year? My RS6 Avant should take 8-10 months to build and I haven't decided if it will be a lease or buy. Thanks!
    Nope
  • goldfishtxgoldfishtx Member Posts: 7
    Looking for current 36/10k rates for 94085.
    .00335 MF and 61% residual
    Good lord that's terrible. Thank you.
    You shouldn't be surprised. MF are up, across the board.
    Can I have this months rates and residuals for 24/7.5 and 36/7.5k for 07624
    .00322 MF
    69%/62% residual
  • carguyshucarguyshu Member Posts: 3
    2022 RS6 with as short of a lease as possible (I believe that is 24 months) and a 20% residual value (I know this is the lowest residual Audi will allow and if you buy enough miles it can drop it down this far). What would the money factor on that be with zip code 66073? Thanks!
    The 24 month money factor is .00322
    If it's different because of the lower residual, I wouldn't know about it.
    is audi currently allowing any MSDs? If I were to buy extra miles, would it lower the residual value? If so, how much does each mile purchased lower the residual?
    MSDs - max 9 @ .00005 reduction each
    I think it's .10/mile deducted from the residual over the 15K you have to start with to buy extra
  • hemingway9hemingway9 Member Posts: 87
    Hi, what is RV/MF for 22’ RS6 36mo/10k for 91356?
    .00371 and 62%
  • Corrado79Corrado79 Member Posts: 6
    Hello, what is current RV/MF for '22 RS6 36mo/10k for 90045?
    .00406 MF and 62% RV
    Is Audi still doing Multiple Security Deposits? An Audi dealer in CA is saying no.
    We have no information to suggest that the MSD program is no longer available.
    However, dealers can opt in or out of it, as they see fit.
    Check with other dealers.
    When do 2023 lease factors get published?
    Kevin911
    Standard MF and 58% residual
  • fen3fen3 Member Posts: 5
    Hi, what are the MF and RV for a 2023 RS6, 36/12, 06820?
    Please re-post in our 2023 model discussion
