2021 Ram 1500 Lease Deals and Prices
13738394042
  • MichaellMichaell Moderator Posts: 269,807
    KevKev said:
    Can I get current numbers on a 2021 Ram 1500 limited crew cab w/ Night Edition 5’7 4x2? 36/12 and 36/10. Zip 77070. Thank you so much.
    Standard MF and 51% RV
    $500 incentive
  • KevKevKevKev Member Posts: 3
    Sorry, I forgot to list one more model:
    2021 Ram 1500 Laramie crew cab w/ Night Edition 5’7 4x2. 36/12 and 36/10 if avail. 77070 Zip. Appreciate you.
    .00066 MF and 53% RV
    $500 incentive
  • CgalgirlCgalgirl Member Posts: 2
    edited October 2021
    2021 Big Horn Crew 4x4
    Night addition
    3.0 V6 Turbo Diesel
    5’7” bed
    Asking $63,060 before rebates
    Dealership telling me residual is $35,314
    36m
    10k & 12k miles
    Zip 92064
    MF & Residual please
    TIA!
    Night addition
    3.0 V6 Turbo Diesel
    5’7” bed
    36m
    10k & 12k miles
    Zip 92064
    TIA!
    .00064 and 55%
    $2000 incentives
  • GSXRAPTORGSXRAPTOR Member Posts: 6
    Can I get current numbers for both a 2021 Ram 1500 Rebel, Crew Cab, Night Edition, 5.7L, 4x4 as well as a 2021 Ram 1500 TRX please?
    36/12 and 36/15
    Zip is 85086
    Thank you for your time and help!
  • kyfdxkyfdx Moderator Posts: 274,017
    36/12 and 36/15
    Zip is 85086
    Standard MF and 56% residual
    Either trim
    $1500 incentive on Rebel only
  • lease4everlease4ever Member Posts: 32
    Hi can I please have mf,rv,inc, for 2021 ram 1500 big horn crew cab 2wd night edition. Zip 92543. 36/10
    .00082 MF and 54% RV
    $2000 incentives
  • SPS83SPS83 Member Posts: 34
    Hi can i please get current numbers for a 2021 Ram 1500 Limited and 4x4 a 2021 Ram 1500 TRX - Zip 73102. 36/10? Thank you.
    Standard MF and 53% (LTD) or 59% (TRX)
    What is the current standard MF? I tried to figure it out from the other posts above, but none seemed consistent. Thanks.
    Also, any incentives on the 2021 limited or TRX Zip - 73102
    .00222 MF
    No incentives
  • Sal93Sal93 Member Posts: 32
    edited October 2021
    00060 MF and 53% residual
    What about 42/15. Thanks
    .00067 and 50%
  • redeagle79redeagle79 Member Posts: 13
    Could I get the numbers for 4x4 Limited 3/45 and 3/36 46123? Thanks,
    36 month term not supported, this month.
    39/15
    .00126 and 48%
    $1300 incentives
  • JjmnkkJjmnkk Member Posts: 6
    Can I get MF, RV, and any rebates/incentives for the following?
    Zip Code - 64064
    2021 Ram 1500 Limited 4x4 Crew Cab 5.7L Hemi
    36/8
    39/10
    39/12
    Can I also get the same info for the same vehicle with the 3.0L Turbo Diesel Engine? Or maybe it’s the same…??
    Zip Code - 64064
    36/8
    39/10
    39/12
    39/12
    .00126 MF and 50% RV
    No incentives
    Either engine
  • dylrexdylrex Member Posts: 131
    Hello. Looking for the MF ,RV & Incentives for the 2021 Ram1500 BIG HORN CREW CAB 4X4 5'7 BOX 4WD for a 3/36k lease in zip 41048.
    Thank you in advance!
    39/12
    .00023 and 52%
    $1800 incentives
  • takeoff127takeoff127 Member Posts: 4
    Hi, please can I get the numbers for a 2021 1500 Big Horn Crew Cab Night Edition 4x2 5'7" w/ 5.7L V8
    39/10
    32817
    Many thanks!
    39/10
    32817
    Many thanks!
    .00021 MF and 51% residual
    $1000 incentive
  • helplolhelplol Member Posts: 108
    edited November 2021
    Ram 1500 Big horn
    Crew Cab
    5.6 ft bed
    V8 eTorque 4x4
    39/10
    Zip 60169
    Incentives ?
    helplol said:
    Ram 1500 Big horn
    Crew Cab
    5.6 ft bed
    V8 eTorque 4x4
    39/10
    Zip 60169
    Incentives ?
    .00023 MF and 53% residual
    $2675 incentive
    $2675 incentive
    Can I get number for that exact spec for 50014
    $2675 incentive
    Same
  • Hello, looking for MF, RV and incentives for 2021 RAM 1500 LIMITED CREW CAB 4X4 5'7 BOX" V6 Diesel 3.0L engine. Looking for 39/10 in zipcode 20854.
    TIA!!
    TIA!!
    .00126 MF and 51% residual
    $1175 incentive
  • gosoonersgosooners Member Posts: 45
    Could you please provide MF and Residuals for 2 options in ZIP 77429 for a 2021 Laramie Crew Cab RWD:
    - 36mo/12k
    - 36mo/10k
    Thanks ahead!
  • Oneill19057Oneill19057 Member Posts: 7
    Help with the lease numbers. 2022 Laramie 1500 GT night edition loaded crew cab MF residual and incentives. Could I please have it two areas. One is 19057 PA and the other 70607 Louisiana
    - 36mo/12k
    - 36mo/10k
    Thanks ahead!
    39/12
    .00022 MF and 52% residual
    2022 model discussion
  • belfattobelfatto Member Posts: 49
    Hello, looking for the MF, RV & incentives for 2021 RAM 1500 CLASSIC SLT/WARLOCK QUAD CAB 4X4. 36/15k for 14220
    .00021 MF and 50% residual
    $2525 incentive
  • Helenr12Helenr12 Member Posts: 1
    Hi. Could I please get the MF, Residual Value and Incentives for a 36/10K Lease of 2021 RAM 1500 LIMITED CREW CAB 4X4 5'7" BOX, V6 DIESEL. Zip Code 60164. Thanks
    39/10
    $675 incentives
    Ram 1500 Classic Express & Tradesmen
    4x4
    5.7
    Reg Cab and 6 bed (short)
    Zip 60192
    39/10 RV MF. & any incentive ?
    4x4
    5.7
    Zip 60192
    Standard MF
    46% Express
    I don't see the Tradesman trim available as a regular cab
  • mort4848mort4848 Member Posts: 25
    Hello
    Can I get the MF and RV for 2021 Ram 1500 Bighorn quad cab night edition 5.7 v8 4*2 in 77320?
    mort4848 said:
    Hello
    .00013 MF and 50% residual
  • HotshotHotshot Member Posts: 69
    Ram 1500 TRX 4x4 residual and mf for 36/10 and 48/10 or best term for 11219. Thanks
    Standard MF and 58% / 51%
    .00222?
    .00222?
    36: .00242
    48: .00275
    Ram TRX
    39/10 and 48/10
    Rv mf
    Can you pls number the MF
    60192
    helplol said:
    Ram TRX
    39/10 and 48/10
    Rv mf
    60192
    Standard MF and 57% / 51%
    39 - .00250
    48 - .00275
  • edsonperedsonper Member Posts: 27
    Can someone please provide me res and mf for
    2021 ram 1500 classic 5.7
    2021 ram 1500 bighorn/etorque v6
    10k miles-36mos
    Zip is 11234
