2021 Jeep Grand Cherokee Lease Deals and Prices
1545557596064
  • MichaellMichaell Moderator Posts: 270,840
    Thanks. One more if you don't mind.
    Grand Cherokee L Overland 4x4 MF, residual and any incentives for a 36/12 in 90266.
    Standard MF and 54% RV
    No incentive info
  • sundevilocsundeviloc Member Posts: 64
    Hello, could I please get the current MF and Residual for the GC L Altitude 4X2 for 36/10 for 89149?
  • kyfdxkyfdx Moderator Posts: 275,687
    Standard MF and 62% residual
  • nyccarguynyccarguy Member Posts: 17,966
    Good morning. Can I please have the current November money factor & residual value for a 2021 Jeep Grand Cherokee L Laredo 4X4 & 2021 Jeep Grand Cherokee L Altitude 4X4 for 24 months/15K per year as well as 36 months/15K per year in zip code 06902? If the standard money factor applies, can you please list what that is as well? Thanks so much!
  • JJLJJL Member Posts: 31
    Please provide rv, mf and incentives for a grand Cherokee L limited 4x4. Zip code 43015
    27/12:
    39:12
    Standard MF
    72%/59% residual
    Either trim
    27/12:
    39:12
    Standard MF
    64%
    55% residual
    Standard MF
    64%
    55% residual
    Are you able to provide the standard mf for the 27 month. I found the 39 month but can’t seem to find that
    Standard MF
    72%/59% residual
    Either trim
    What is this month's standard money factor? Thanks.
    JJL said:
    Standard MF
    64%
    55% residual
    27: .00259 MF
    39: .00094 MF
    Standard MF
    72%/59% residual
    Either trim
    24: .00261 MF
    36: .00098 MF
    Standard MF
    72%/59% residual
    Either trim
    24: .00261 MF
    36: .00098 MF
    That money factor throws the 24 month term off the table
    Standard MF
    72%/59% residual
    Either trim
    24: .00261 MF
    36: .00098 MF
    Yup
  • nickyS_713nickyS_713 Member Posts: 54
    Could you please provide the MF, residual and incentives for a 4x4 2021 Grand Cherokee Laredo X.
    36/12k
    36/10k
    Thank you in advance!
    36/12k
    36/10k
    What is your location?
    36/12k
    36/10k
    10804
    36/12k
    36/10k
    10804
    39/12
    .00033 MF and 48% residual
    $4320 incentive
  • dg97dg97 Member Posts: 40
    Hello!
    I'm looking for the MF, Residual, and any incentives for a 2021 Jeep GRAND CHEROKEE 80TH ANNIVERSARY 4X4. Area Code 48133.
    36/10k
    42/10k
    48/10k
  • Vito DiGiorgioVito DiGiorgio Member Posts: 88
    Can I have MF/Residual/Incentives for 21 Grand cherokee Limited and Laredo 4WD 36/10 in 28677?
    dg97 said:
    Hello!
    36/10k
    42/10k
    48/10k
    .00018 MF and 51% residual
    $3810 incentive
    No lease support for the other terms
    LAR: .00033 MF and 49% residual
    LTD: .00006 MF and 49% residual
    $2500 incentive
  • BabboBabbo Member Posts: 7
    Hi
    Can I please see MF/residual/incentives for 2021 GC limited and Limited X 4wd, 36/10. 11224
    Babbo said:
    Hi
    LTD: .00018 MF and 51% residual. $4310 incentive
    LTD/X: .00006 MF and 49% residual. $1250 incentive
  • MidwestMurphyMidwestMurphy Member Posts: 16
    edited November 2021
    May I please have the MF, RV and any incentives for the 2021 Grand Cherokee Laredo X 4x4 Sport AND the 2021 Grand Cherokee Limited 4x4 Sport?
    Zip 47201
    36/39 mos
    10k miles
    Zip 47201
    36/39 mos
    10k miles
    LARX - .00033 and 49%; $3820 incentives
    LTD - .00006 and 49%; $4240 incentives
    Ouch. Those are some pretty low numbers. Some of the leasehackr closed deals show 60% + on RV but must be old numbers. Thanks
    Could be a different bank. We only have the Chrysler Capital numbers.
  • jjcpa82jjcpa82 Member Posts: 37
    Hello - can you please provide GCL Limited 4x4 MF/R for 36/10 and 24/10 in 80212
    Standard MF
    67%/57% residual for 24/36 mo
    Thanks could you also provide mf/r for 2021 80th anniversary 4x4 in 80212? 36/10 and 24/10?
    27/10 - .00017 and 60%
    39/10 - .00018 and 51%
    $2500 incentives
  • mbeach0315mbeach0315 Member Posts: 34
    Hello. Can you please provide the MF and residual for a Grand Cherokee L Summit Reserve in 90266 for 36/12? Thank you.
  • quattromikequattromike Member Posts: 160
    May I have the MF and RV for a 2021 Jeep Grand Cherokee L Overland 4x4 for 36/12 in 60515? Thank you
    Standard MF and 55% residual
    Standard MF and 54% residual
  • ElfishymanElfishyman Member Posts: 4
    Hi - looking for money factor and residual value on 2021 Jeep Grand Cherokee L summit and summit reserve
    10k miles/36 mo
    Zip: 08081
    Thanks for the help in advance!
    10k miles/36 mo
    Zip: 08081
    Standard MF and 56% residual
    Either trim
    Either trim
    Thank you, is the standard MF .00018?
    Either trim
    For 36 months, it is .00098 MF
  • Cferraro85Cferraro85 Member Posts: 5
    Hi - looking for money factor and residual value on 2021 Jeep Grand Cherokee L Limited and Overland (both 4x2). if standard mf, then let me know what that number is please.
    12k miles/36 mo
    Zip: 32708
  • slolankanslolankan Member Posts: 273
    @slolankan said:
    Hello
    is this right forum for Grand Cherokee L ? if not please let me know.
    Trying to see if October numbers changed from last month and if there are additional incentives for CA 90710?
    Limited 4x2
    Summit 4x2
    Overland 4x2
    Limited 4x4
    Summit 4x4
    Overland 4x4
    68% / 59%
    64% / 56%
    64% / 56%
    69% / 60%
    66% / 58%
    66% / 58%
    .00143 for 36 months
    .00241 for 24 months
    THank you!
    Hello
    Did these numbers change for November on the L for 12k miles?
    Any incentives? Conquest / loyalty?
    12k miles/36 mo
    Zip: 32708
    Standard MF
    57%/52% residual for LTD/OVL
    36 mo = .00098 MF
  • sgirwin01sgirwin01 Member Posts: 1
    Hi - may I have the current money factor, residual value, and any incentives on 2021 Jeep Grand Cherokee Limited 4x2. If standard MF, could you please let me know what that is?
    39 Months / 12K Miles
    Zip: 78741
    Zip: 78741
    .00008 MF and 47% residual
    $1750 incentives
  • KMTPAKMTPA Member Posts: 7
    Hi - may I have the current money factor, residual value, and any incentives on 2021 Jeep Grand Cherokee Limited 4x2 and 2021 LAREDO X 4X4
    39 Months / 10k & 12K Miles
    Zip: 33572
    Zip: 33572
    LTD: .00008 MF and 47% residual
    LARX: .00033 MF and 48% residual
    $2500 incentive
  • taketheturnstaketheturns Member Posts: 16
    Hello - may I have the current money factor, residual value, and any incentives on 2021 Jeep Grand Cherokee L, Altitude and Limited 4x2?
    36/7500 miles
    90731
    36/7500 miles
    90731
    Standard MF
    62%/58% residual for ALT/LTD
    Can i please get the numbers for Grand Cherokee L ?
    Trying to see if November numbers changed from last month and if there are additional incentives for CA 90710? Loyalty? Conquest?
    Altitude 4x2
    Limited 4x2
    Summit 4x2
    Overland 4x2
    Altitude 4x4
    Limited 4x4
    Summit 4x4
    Overland 4x4
    24/36 months for 12k miles please
    Also did the MF change?
    Thanks again!
    Altitude 4x2
    Limited 4x2
    Summit 4x2
    Overland 4x2
    Altitude 4x4
    Limited 4x4
    Summit 4x4
    Overland 4x4
    Thanks again!
    71%/61%
    66%/57%
    61%/52%
    61%/52%
    73%/61%
    66%/56%
    64%/55%
    63%/54%
    24: .00261 MF
    36: .00098 MF
