2022 RAM 1500 Lease Deals and Prices
1356730
  • fireberd350fireberd350 Member Posts: 2
    Curious how a Big Horn Quad 4x4 can have 1 quote at Standard MF 0.00222 and 1 at
    0.00045. Using Edmunds lease calculator thats 5.3% vs 1% APR.
  • kyfdxkyfdx Moderator Posts: 273,225
    Maybe, the two posts are from two different months?
    Maybe. I guess I could just ask for the MF and RV for the truck I was just quoted a lease on.
    2022 RAM 1500 Big Horn 4x4 Crew.
    39mo. 10k/yr
    Dealership Zip 70607, My Zip where it will be titled 19382
    39mo. 10k/yr
    .00048 MF and 55% residual
    $500 incentive (TX)
    $2175 incentive (PA)
  • HotshotHotshot Member Posts: 69
    2022 Laramie crew cab mf residual and incentives for 11219. Thanks
  • MichaellMichaell Moderator Posts: 269,458
    4x2 or 4x4?
    Lease term and mileage?
    4x2 or 4x4?
    4x2 for 36/10 or best term
    Hotshot said:
    4x2 or 4x4?
    39/10
    .00026 and 52%
    $1175 incentives
    .00026 and 52%
    $1175 incentives
    4x4?
    Hotshot said:
    .00026 and 52%
    $1175 incentives
    4x4?
    39/10
    .00022 and 53%
    $1175 incentives
  • dg97dg97 Member Posts: 40
    Do you have access to Ally's standard lease rate for a 36 month, 15k on a 2022 TRX in 48161?
    We do not.
  • samm14samm14 Member Posts: 176
    Good Evening,
    Looking for Rv And Mf 2022 Laramie crew cab 4x4 for 11714. First responder and leased 2019 ram which is due on feb 2022.
    .00022 and 53%
    $1175 incentives
    Residual is actually 56%. It gets bumped for ultra low mileage on the 36-39 terms etc.
    .00022 and 53%
    $1175 incentives
    Any change for this month?
    We do not.
    No problem, what is the standard lease rate for a 36 month, 15k on a 2022 TRX in 48161 with CCAP?
    samm14 said:
    Good Evening,
    .00044 MF and 53% residual
    No incentive info
    Hotshot said:
    .00022 and 53%
    $1175 incentives
    .00033 MF and 54% residual
    No incentive info
    dg97 said:
    We do not.
    Standard MF and 56% residual
  • dylrexdylrex Member Posts: 130
    Hello. Looking for the MF ,RV & Incentives for the 2022 Ram1500 BIG HORN CREW CAB 4X4 5'7 BOX for a 36 or 39 month lease with 12k miles per year lease in zip 41048.
    Thank you in advance!
    39/12
    .00027 MF and 54% RV
    $1750 incentives
  • neek555neek555 Member Posts: 4
    Can I please get numbers for a 2022 TRX in 33067? Is standard MF still .00222? Thanks in advance.
    We don't have the standard rates, yet.
  • scoperocscoperoc Member Posts: 10
    edited December 2021
    Looking for the MF ,RV & Incentives for the 2022 1500 LARAMIE CREW CAB 4X4 6'4 BOX. 10k miles per year, 36 or 39mos. Or if there is a special lease rate for a certain combo that as well. Thank you! Zip is 21601.
  • nomad317nomad317 Member Posts: 111
    Looking for MF/Res/Incentives on 2022 4x4/V8
    for 36mo/10k & 39mo/10k
    ---Big Horn Quad Cab
    ---Big Horn Crew Cab
    ---Laramie Crew Cab
    Zip 46614.
    THANKS!!!
    39/10
    .00044 and 56%
    $700 incentive
    ---Laramie Crew Cab
    Zip 46614.
    THANKS!!!
    39/10
    .00023 and 55%; $3150 incentives
    .00027 and 55%; $1750
    .00044 and 56%; $1250
    .00044 and 56%
    $700 incentive
    Same for 11219
    Hotshot said:
    .00044 and 56%
    $700 incentive
    Same for 11219
    Same as what?
    Just ask your question...
    Same as what?
    Was referring to same vehicle op asked, Ram 1500 Laramie 4x4 39/10 11219
    Hotshot said:
    Same as what?
    Crew or Quad cab?
    Crew or Quad cab?
    Crew cab
    Hotshot said:
    Same as what?
    Hotshot said:
    Crew or Quad cab?
    Crew cab
    .00044 and 56%
    $700 incentives
  • Hellp50014Hellp50014 Member Posts: 77
    Ram TRX L1 4x4
    Rv MF
    39/10 and 48/10
    60192
    Ram TRX L1 4x4
    Rv MF
    39/10 and 48/10
    60192
    Standard MF
    58%/52% residual
    Standard MF
    58%/52% residual
    Can you please number the mf
    Standard MF
    58%/52% residual
    36 - .00242
    48 - .00275
  • Emed115Emed115 Member Posts: 3
    Can I get MF/ RV and incentives for the following:
    Zip code is 07470
    2021 Ram 1500 Rebel & 2022 Ram 1500 Rebel 4x4 Crew Cab
    2021 Ram 1500 Laramie & 2022 Ram 1500 Laramie 4x4 Crew Cab
    2021 Ram 1500 Big Horn & 2022 Ram 1500 Big Horn 4x4 Crew Cab
    36/12/
    39/12
    Zip code is 07470
    36/12/
    39/12
    39/12
    REB - .00119 and 57%; $550 incentives
    LAR - .00044 and 55%; $700
    BH - .00027 and 54%; $1200
    2021 RAM discussion
  • cjsen93cjsen93 Member Posts: 20
    Hi There, I am looking for the MF, and RV for a 2022 TRX for 48/10k. Zip is 95630.
    Standard MF and 52% residual
    Looking for the MF ,RV & Incentives for the 2022 Ram1500 LIMITED CREW CAB 4X4 5'7 & 6'4" BOX 10k miles per year, 36 or 39mos. Or if there is a special lease rate for a certain combo that as well.
    39/10
    .00125 and 53%
    $700 incentives
  • flowers84flowers84 Member Posts: 18
    Looking for RV for 2022 ram 1500 TRX 27/10 and 39/10 for 44133
    Also, is the standard mf .00222 for december great lakes region through ccap for the TRX?
    Standard MF and 65% / 58% for 27/39 and 10K
    .00259 27
    .00250 39
    Looking for RV for 2022 ram 1500 TRX for 36/10 44133
    What is rv and exact money factor great lakes region thank you so much.
    .00242 and 59%
  • mp2103mp2103 Member Posts: 10
    Good Morning,
    Looking for the MF ,RV & Incentives for the 2022 1500 LARAMIE CREW CAB 4X4 5'7 BOX. Zip 76036
    mp2103 said:
    Good Morning,
    .00044 MF and 53% RV
    $1000 incentives
    Is there any difference with 36/15 terms? Thank you
