2021 Grand Cherokee L Lease Deals and Prices
warriorprncesswarriorprncess Member Posts: 10
edited December 2021 in Jeep
Hi. Can I please have MF/RV and any incentives for a 2021 Laredo 4x2 and 4x4 on 36/12 and 36/10? Zip code 32605.
«13
    Standard MF
    61% RV
    Either drive
    No incentive information
  • wingwizardwingwizard Member Posts: 9
    Hi! Can you provide MF/RV for the Grand Cherokee L in Limited, 4x2 and 4x4 in 90804? I seem to have gotten conflicting in formation.
  • Team_of_horsesTeam_of_horses Member Posts: 3
    Hello. I am looking for lease residual, money factor and incentives for the following:
    Grand Cherokee L Limited 4x4
    zip: 19025
    36/10k
    39/10k
    48/10k
    also, I see "standard money factor" stated on the forums here for Jeeps, but what is that? I can not find the number.
    zip: 19025
    36/10k
    39/10k
    48/10k
    Standard MF
    .00098 MF and 57% residual
    .00094 MF and 56% residual
    .00275 MF and 50% residual
  • warriorprncesswarriorprncess Member Posts: 10
    Hi again. Looking for MF/RV/incentives on 2021 Grand Cherokee L Limited, 4x2 or 4x4. Zip code is 32605.
    39/12
    39/12
    Standard MF
    2WD: 57%/56% residual for 36/39 mo, 12K/yr
    4WD: 56%/55% residual
    No incentive info
  • ToastManToastMan Member Posts: 3
    Hey, do you have the MF and RV and any incentives for a 2021 Grand Cherokee L Limited 4x4, 36/10, zip: 11741
    Standard MF and 57% RV
    No incentive info
  • bills2018bills2018 Member Posts: 11
    Hi, can you please provide RV and MF for 2021 Grand Cherokee L Altitude 4x4 36/10, zip 27606? Thanks
    Standard MF and 62% residual
  • aman13aman13 Member Posts: 2
    Hello, could you please provide RV and MF for
    2021 Grand Cherokee L Summit Reserve 4x4
    36months / 10k miles
    zip 48108,
    zip 48108,
    Standard MF and 56% RV
  • PauliePickup1500PauliePickup1500 Member Posts: 14
    I’m looking for RV MF and any incentive/ rebates
    For 2021 Jeep Grand Cherokee L limited 4x4
    36,39,48 months
    10k yr
    Zip 11554
  • Husker37Husker37 Member Posts: 10
    Hello.
    Can i have the MF on 2021 4x2 Jeep Cherokee L. Limited
    39,42,48 months
    12K miles
    TIER 3 credit
    28173 area code
    36,39,48 months
    10k yr
    Zip 11554
    Standard MF
    57%, 56%, 50%
    No incentive info
    Husker37 said:
    Hello.
    39,42,48 months
    12K miles
    TIER 3 credit
    28173 area code
    Standard MF
    56%, 53%, 50%
    Add .00081 to the MF for tier 3
    Tier 3 adds nearly .00200 to the Standard MF, depending on term.
    Thanks! Can you confirm that standard MF for 36/10 is .00098?
    That is correct.
  • esneakyesneaky Member Posts: 15
    Can I get residual and mf for 4x4 limited 36 months 10k miles zip 33176. Any incentives ?
    Standard MF and 61% residual
  • cfghmikecfghmike Member Posts: 31
    May I please have MF/R/I for Jeep Grand Cherokee L Overland 4x4 in 75009. 36/12 and 36/15. Thank you.
    Standard MF and 52% residual
    No incentive info
  • BT18BT18 Member Posts: 96
    Hello, I didn't see a thread for 2022 GCL...or are the numbers not out yet?
    2022 Grand Cherokee discussion
  • surfcaosurfcao Member Posts: 3
    Hi. Could I please have MF/RV and any incentives for a 2021 Limited 4x4 on 36/10k? Zip code 80303.
    Standard MF and 57% residual
    No incentive info
    Thanks for the fast response. What about the MF/RV for Zip code 80601 and 80026? Limited 4X4. Thank you!
    May I also ask which zip codes will used for the RV? Dealer's zipcode or buyer's residential zipcode? Thanks!
    The Grand Cherokee L numbers are national.
  • b3dr0ckb3dr0ck Member Posts: 9
    Hi. I am looking for MF/RV on 2021 Grand Cherokee L Limited, 4x2 or 4x4. Zip code is 92011.
    39/15
    39/15
    Standard MF
    4x2 - 55% / 54% for 36/39 and 15K
    4x4 - 54% / 53%
    39/15
    Standard MF
    4x4 - 54% / 53%
    Thank you. What will be the RV/MF for 12k?
    b3dr0ck said:
    39/15
    Standard MF
    4x4 - 54% / 53%
    +2%
  • Abarnesy13Abarnesy13 Member Posts: 6
    Do have the RV and MF for Jeep Grand Cherokee L Limited 4x2 for 36/10 and 36/12 in 91784. Thanks
    Thanks. Any info for 36/10. What is the standard MF?
    Add 1% for 10K
    .00098 MF for 36 month term
  • Huskers37Huskers37 Member Posts: 5
    Does the residual seem accurate.
    MF .00195 and Residual 56 on a Jeep Grand Cherokee L Limited 4x2
    area code 28173
    39/12
    area code 28173
    39/12
    I confirm the 56% residual
    The base MF for 39 months is .00094, however; tier 2 is .00161.
  • pgriz14pgriz14 Member Posts: 25
    Can you please provide the MF/RV for 2021 Jeep Grand Cherokee L Limited 4x4? Zip 43147. 36/10 and 39/10.
    Standard MF
    57%/56% residual
    I could have sworn i saw something that CCAP was offering tier bumps through November, did that get extended through December?
    What do you mean by "tier bumps"?
    Found it
    Huskers37 said:
    Found it
    Got it.
    Thanks for sharing!
  • hioctane2hioctane2 Member Posts: 27
    Good morning,
    Looking for MF/RV numbers for 24/12, 36/12 (or 39/12 if supported) and 42/12 for:
    Zip 60119
    Local dealer is advertising "$399/mo for 42 months" on the L Limited, but of course, I'm assuming that number does not include tax and requires a hefty down payment.
    hioctane2 said:
    Good morning,
    Zip 60119
    standard MF
    LTD - 66%, 56%, 55%, 52%
    ALT - 73%, 61%, 60%, 57%
  • ViceGearViceGear Member Posts: 1
    Can someone please post MV/RV numbers for Zip Code 94611?
    24/10, 36/10, 39/10
    Please share the actual MF, as I don't know what "standard MF" is for my area. example: 0.00013.
    Dealer is quoting me 0.0013 for top-tier credit but that seems marked-up
    24/10, 36/10, 39/10
    LTD: 67%, 57%, 56% residual
    ALT: 74%, 62%, 61% residual
    24: .00261 MF
    36: .00098 MF
    39: .00094 MF
