2022 Chevrolet Tahoe Lease Deals and Prices
24
  • smartbuyerjrsmartbuyerjr Member Posts: 6
    hey folks,
    can i ask for December Tahoe numbers on a z71 36/10 for zip code 07450.
    Also, do you know which model has the lowest MF / highest residual out of the tahoes for the same?
  • MichaellMichaell Moderator Posts: 269,468
    hey folks,
    .00202 and 62%
    LS probably has the best program - and, with a much lower MSRP, you'll see a lower payment.
  • JT402480JT402480 Member Posts: 12
    1) Tahoe LT 2WD
    2) Tahoe LT 4WD
    3) Tahoe RST 4WD
    36/12 on all. 85258. Thank you so much!!
  • DHDHDH123DHDHDH123 Member Posts: 32
    Hi. MF and RV for 2022 Tahoe, Z71
    36/12 and 36/10
    zip92130
  • kyfdxkyfdx Moderator Posts: 273,254
    JT402480 said:
    1) Tahoe LT 2WD
    2) Tahoe LT 4WD
    3) Tahoe RST 4WD
    .00212 MF and 62% residual
    .00202 MF and 61% residual
    36/12 and 36/10
    zip92130
  • Tiffosi12001Tiffosi12001 Member Posts: 14
    Hi looking for numbers on 36mo/12k zip code 95404:
    1.) premier 4x4
    2.) z71 4x4
    3.) high country 4x4
    1.) premier 4x4
    2.) z71 4x4
    .00197 MF and 57% residual
    Thanks for the response. Can you also let me know same for zip 75019?
    Same
  • bmacchiobmacchio Member Posts: 30
    4WD RST - zip 92107
    36/10k and 39/10k
    RV ?
    MF?
    Also, do you know when the next rate reset will be for GM? Thank you!
    bmacchio said:
    4WD RST - zip 92107
    36/10k and 39/10k
    RV ?
    MF?
    .00207 MF
    62% / 59% for 36/39 and 10K
    Current GM programs expire 1/31. No predictions if the new programs will be different or not.
  • Randy599Randy599 Member Posts: 12
    Can you please help with the lease numbers on a 2022 Tahoe 4WD, LT Trim, 12/36 and 12/39 in 06117?
    .00201 MF
    61% / 58% RV for 36/39 and 12K
  • jegre123jegre123 Member Posts: 77
    Hi, looking for MF and residual for 2022 Tahoe 4wd Z71, 36/15 and 36/12 in 60012. Assume no incentives? Thanks!
    .00207 MF and 59% RV
    Can I also get MF and residual on a 2021 Tahoe LT 4WD 36/12 and 36/15 in 60012? Thanks!
    .00201 MF and 59% residual
    .00201 MF
    Same for RST trim? Or does the residual and MF move a little?
    Randy599 said:
    .00201 MF
    .00207 MF is the only difference
    Hi
    Looking for numbers on Z71, 36/12, 92130.
    DHDHDH123 said:
    Hi
    .00207 and 61%
  • CJ05CJ05 Member Posts: 39
    Hi, can you please share MF and residual for 4x4 premier and high country? 36/12. 06850. thank you.
    Prem - .00207 and 61%
    HC - .00202 and 57%
  • Jay1905Jay1905 Member Posts: 44
    Hi, can you please share MF and residual for RWD LT and RST ? 36/12 and 39/12. Zip - 33063 thank you.
    LT: .00201 MF and 61%/58% residual
    RST: .00207 MF and 61%/58% residual
    Hi, could you please tell me Feb programs for Premier, 4x4, 36/12, zip 06840? Thank you.
    .00207 MF and 61% residual
  • genny777genny777 Member Posts: 2
    Looking for MF and residual on 2022 Chevy Tahoe LT $69,880 36/12 14450
    .00201 MF and 61% residual
  • hammer3612hammer3612 Member Posts: 38
    Can i get MF and residual on 2022 Chevy Tahoe Premier 36/12 and 36/15 in zip 78006
    .00207 and 59%
  • HotshotHotshot Member Posts: 69
    Tahoe LT 4x4 (signature plus pckg) 39/10 rv mf and incentives (conquest and loyalty). thank you
    What is your location?
    sorry 11219
    sorry 11219
    $500 loyalty
  • FireFire Member Posts: 7
    Looking for lease residual/mf/ incentives for 2022 Tahoe Z71 & LT, in 08050. Thanks!
    Hey Mike, looking for 36/39/48 month lease terms, with 10k miles. Thanks
    LT
    .00201 MF and 62% residual
    .00201 MF and 59%
    .00219 MF and 53%
    Z71
    .00207 MF and 62%
    .00207 MF and 59%
    .00212 MF and 52%
  • cats13cats13 Member Posts: 34
    Hi, can you please tell me the RV, MF and incentives for a 2022 Tahoe Z71 in 37215 for 36/39/48 and 12/15K miles? Many thanks in advance!!
    36/15: .00207 MF and 59% residual
    39/15: .00207 MF and 56% residual
    48/15: .00212 MF and 48% residual
    Awesome, appreciate the quick response? And how about for 12K miles?
    +2%
    +2%
    Perfect, thanks again!
    +2%
    Sorry, I messed up the zip. Can you please send same info for 59716?
    +2%
    Same.
    Hello, are March lease #s out for 2022 Tahoe 4wd LT? Looking for 15/36 and 15/39 MF, residual, incentives in 60012. Thanks!
    .00201 MF
    59% / 56% RV
    .00201 MF
    59% / 56% RV
    What is the residual, MF for 15k, 48 months?
