2022 Mercedes-Benz C-Class Lease Deals and Prices
jrd3553jrd3553 Member Posts: 7
edited December 2021 in Mercedes-Benz
I'm looking at ordering a MB 2022 C 300 4matic sedan. Do ou have the money factor and/or residual values for these yet? If so, may I get the MF and RV for a 36 month lease with 12,000 miles/yr in 92054? Thank you
«134
  • kyfdxkyfdx Moderator Posts: 271,373
    No lease programs for the 2022 C300 sedans, yet.
  • Natef50Natef50 Member Posts: 18
    What's the MF, Residual, and lease or loyalty credits (if any) for a new 2022 C300 4matic 36/10k. 40503Zip
  • MichaellMichaell Moderator Posts: 267,827
    Coupe, Cabriolet or Sedan?
    Coupe and sedan
    Coupe and sedan
    Coupe: .00145 MF and 54% residual
    No incentives
    We don't have the sedan programs, yet.
  • rcvallercvalle Member Posts: 2
    edited January 2022
    May I have the MF, RV, and incentives (if any) for 2022 C 300 Coupe and Sedan RWD, 36/10k, 95054 and 92807?
    No info on the sedan
  • jrd3553jrd3553 Member Posts: 7
    edited January 2022
    Hi, do you have any info on the 2022 C300 sedan yet? If so, can I get the RV and MF for 36 months, 12k miles in 92069? Thanks!
    RWD or AWD?
    RWD or AWD?
    Can I get both if you have them please? I’m debating on which to get.
    jrd3553 said:
    RWD or AWD?
    Still no lease info on the 2022 C-Class sedan. Sorry.
    Hi, I just wanted to check in to see if the RV and MF are in for the C300 yet? If so, can I get the RV and MF for 36 months, 12k miles in 92069 for both the RWD and AWD. Thanks!
    If they aren’t in yet, would you have an idea when the info may be released?
    Standard MF and 59% residual
    Either drive
    edited March 2022
    Either drive
    Hi, I’m new to this so I’m not sure what you mean by standard MF. Can you please give me a number? I also wanted to make sure that this is for the sedan. Thank you
  • loppolloppol Member Posts: 7
    edited March 2022
    Can I get MF, RV and incentives on C300 4matic? 36/10 in 11229
    Either drive
    .00170 MF
    Standard MF and 60% residual
  • curiouscarcuriouscar Member Posts: 17
    edited March 2022
    Hi! Please help with the MF and RF for C300 RWD (sedan) 7.5k/36 and 10k/36 for 94539. Thank you!
    Standard MF and 60% RV
  • CaliBCaliB Member Posts: 15
    Hello - looking for the MF and RF on the following
    2022 C300 Sedan FWD - zip code 95125
    36mo/7.5kmi
    36mo/7.5kmi
    We have no info on the C300 Sedan, this month.
  • JQTaxapayerJQTaxapayer Member Posts: 60
    Hi looking for MF, residual, incentives for a C300 FWD 36/10k 60563
    C-Class is RWD or AWD - which do you want?
    Sedan, Coupe or Cabriolet?
    Sedan
    AWD
    Sedan
    AWD
    Huh - there aren't any lease numbers for the 2022 C-Class sedan.
  • nicemoovesnicemooves Member Posts: 7
    Can I get MF, Residual and any incentives for a C300 RWD for 36/7500 in 78721? Thank you!
    Which body style?
  • MercdsmanMercdsman Member Posts: 5
    Hi! Can I have the MF, RV, and incentives (if any) for 2022 C 300 sedan 4matic And RWD, 36/48 10k/12k zip is 66214?
    Standard MF
    59% / 48% for 36/48 and 12K
    Either drive
  • jackfraserr80jackfraserr80 Member Posts: 4
    I'd like to know the MF, RV for 2022 C300 4MATIC 36 month lease 7.5k/12k in 22201. Thank you.
    Which body style?
  • lillwackerlillwacker Member Posts: 4
    Good afternoon,
    Could you provide me with the MF, RV for 2022 c300 4matic sedan, 36/12k for 55405.
    Good afternoon,
    Good afternoon,
    can you clarify what standard MF is? I was just quoted .00248 by my dealer, even after 10 MSDs.
    Good afternoon,
    .00200 is the base rate, for tier A1 credit.
    edited May 2022
    Which body style?
    I'd like to know the MF, RV for 2022 C300 4MATIC SEDAN 36 month lease 7.5k/12k in 22201
    Which body style?
    Standard MF and 61% RV
    Good afternoon,
    thank you for your assistance. Is that considered base rate specifically for Mercedes? Thanks again!
    Good afternoon,
    Yes, specific to MB.
  • gamboa47gamboa47 Member Posts: 17
    edited May 2022
    Hello, What is the Money Factor, Residual Value, and any current incentives on a 2022 c-class sedan RWD 36/10k & 36/12k zip-91732 Thank you!
  • txbengali1980txbengali1980 Member Posts: 8
    edited May 2022
    Could I get MF and residual on 36/10 single pay lease in 10601?
    Sedan, 4matic
    Sedan, 4matic
    Deduct .00080 for single pay
  • OtWOtW Member Posts: 40
    I am looking for the MF and RV of the re-designed C-Class for 10K/36, 12K/36, and 10K/48 in zip code 33131? Both RWD and AWD numbers would be fantastic. Does Mercedes keep the same RV and MF values among the 3 trim levels? Are they accepting MSDs at this time? Thank you!
    Are you asking about the 2023 model?
    We don't have those numbers, yet.
    When are they expected at the dealer?
    My apologies, should've been more specific. I was referring to the re-designed C300 sedan that came out which is a 2022 apparently. The one that just started to hit dealer lots this past couple of weeks or so.
    Standard MF and 60% / 49% for 36/48 months and 10K
  • ankit359ankit359 Member Posts: 7
    Hello. What's the MF and RV for 2022 C300 4matic?
    In Zip codes 20814 and 07631?
    How much does MSDs save?
    Thanks in advance!
    Thanks in advance!
    Sedan, coupe or convertible?
