2022 Land Rover Defender Lease Deals and Prices
123457
  • bakerrrm2bakerrrm2 Member Posts: 105
    Can you please provide MF and residual for 110, 6 cylinder for 24/10, 33/10 and 36/10 Zip 29205. Thank you
  • kyfdxkyfdx Moderator Posts: 271,331
    24: .00265 MF and 81% residual
    33: .00211 MF and 71% residual
    36: .00211 MF and 65% residual
  • sdkhldsdkhld Member Posts: 24
    edited January 2022
    Hello, can you please provide the MF and residual for:
    2023 110 S 4-Cyl
    2023 110 SE 6-Cyl
    24/10, 33/10, 36/10
    Zip 77479
    Thank you in advance!
  • MichaellMichaell Moderator Posts: 267,802
    2023 110 S 4-Cyl
    2023 110 SE 6-Cyl
    24/10, 33/10, 36/10
    Zip 77479
    We do not have the 2023 Defender numbers, this month.
    Are they showing up at the dealer, already?
  • mblockkmblockk Member Posts: 2
    edited January 2022
    Hello. Can I please get mf and residual for:
    110 X Dynamic SE and 110S, 36/10 and 36/7500 in 90036?
    Thanks in advance!
    Thanks in advance!
    .00211 MF
    63% X-Dyn SE
    70% S
    2023 110 S 4-Cyl
    2023 110 SE 6-Cyl
    24/10, 33/10, 36/10
    Zip 77479
    I had placed an order for a 2022 Defender S 4-Cyl back in November with the understanding that I would have a 81% RV on a 24/10 lease.
    The dealer just called me and said my allotment got pushed through but it will be a 2023 model and they do not have any 4-cyls available but can get me a V6. This is for April delivery. I am unsure how to respond without the 2023 lease numbers.
    Can you all share the following MF and residual numbers for my understanding:
    2022 110 S 4-Cyl
    2022 110 SE 6-Cyl
    24/10, 33/10, 36/10
    Zip 77479
    Thank you for helping me through this, again!
    sdkhld said:
    2023 110 S 4-Cyl
    2023 110 SE 6-Cyl
    24/10, 33/10, 36/10
    Zip 77479
    2022 110 S 4-Cyl
    2022 110 SE 6-Cyl
    24/10, 33/10, 36/10
    Zip 77479
    110 S
    33: .00211 MF and 70% residual
    110 SE
    24: .00265 MF and 75% residual
    33: .00211 MF and 66% residual
    36: .00211 MF and 61% residual
  • MA21MA21 Member Posts: 4
    Happy New Year!
    Hoping you can assist with numbers for below - thanks in advance!
    Zip: 92591
    2022 Defender 90 S
    36 month | 10K miles
    33month | 10K miles
    2022 Defender 110 S
    33 month | 10K miles
    MA21 said:
    Happy New Year!
    Zip: 92591
    2022 Defender 90 S
    33month | 10K miles
    2022 Defender 110 S
    .00211 MF
    90 S: 66%/61% residual for 33/36 mo
    110 S: 70%/65% residual for 33/36
  • nkf2008nkf2008 Member Posts: 89
    Looking for a MF/R on a 110SE
    7500 Miles, 24 months, 33 months zipcode 08869
    24: .00265 MF and 76% residual
    33: .00211 MF and 67% residual
  • BfigsBfigs Member Posts: 13
    Can you please provide me with the MF and RV for a 2022 Defender 110 X-Dynamic SE at 24 months and 12k miles and 27 months 12k miles?
    Zipcode 11968
    Thanks in advance for the help.
    Zipcode 11968
    24/12 - .00265 and 71%
    33/12 - .00211 and 62%
    No 27 month term from LR
  • SkiDoggSkiDogg Member Posts: 36
    Can you provide me with the MF and RV for a DEFENDER 110X-DYNAMIC SE3.0L P400, for 36mo and 10K, zip code is 27587? Thanks.
    .00211 MF
    63%/58% residual for 33/36 months
  • GTWilly1GTWilly1 Member Posts: 11
    Hello! Can you provide the MF and RV for the Defender 110 X-Dynamic SE, 400PS for 39mo/10k, zip code 30004? Thanks!
    .00206 MF and 55% residual
  • mkleasemklease Member Posts: 9
    Hi
    Can I have the Feb MF and residual for a110s. In NY
    33/7500
    I believe this was the best program last month . If 24 or 36/39 is better this month let me know please
    Thank You
    mklease said:
    Hi
    33/7500
    Thank You
    .00211 and 71%
  • SCV76SCV76 Member Posts: 36
    Hello would it be possible to get the MF and RV for a 110s for 24 and 33 months at 10k a year?
  • soupconsoupcon Member Posts: 25
    Looking for 12k/yr 33,36, and 39 mo numbers for a 2022 XDynamic 400 , zip is 92625. Thanks much in advance.
    90 or 110?
    S, SE or HSE?
    90 or 110?
    S, SE or HSE?
    Apologies. 110 x-dynamic se.
    soupcon said:
    90 or 110?
    S, SE or HSE?
    .00211 MF and 62% residual
    .00211 MF and 57% residual
    .00206 MF and 54% residual
  • francodzfrancodz Member Posts: 15
    Hey!
    Can I get MF & residuals for a base & S in 92805.
    7.5K / 10K a yr for 36 & 39 months.
    francodz said:
    Hey!
    90 or 110?
    Apologies a 110.
    francodz said:
    Hey!
    francodz said:
    Apologies a 110.
    36/10: .00211 MF and 65% residual
    39/10: .00206 MF and 62% residual
    Either trim
  • dbiridbiri Member Posts: 32
    Hello Can you provide me with MF and Residual for 110 X Dynamic SE for 36 months 12k miles
    Zip 70433
    Zip 70433
  • gradsgrads Member Posts: 47
    Hello all - about to put an order in for a 2023, Quick question I want to confirm. I understand it's impossible to look months into the future but the builds I am considering are a 110S or 110SE they are similarly priced. I assume I'll be better off with the residual if I choose the S over the SE correct?
    For the 2021 and 2022 models, the residuals are definitely higher for the S.
  • vsingh1068vsingh1068 Member Posts: 8
    Hello, can you give MF and RV for 110S and 110Se for 19096. 24 and 36 months please with 7.5k and 10K.
    24/7.5 - .00265 and 82% / 76% for S / SE
    36/7.5 - .00211 and 66% / 62%
  • tmerriamtmerriam Member Posts: 8
    Hey there, can anyone share the MF and RV for an DEFENDER 90 X-DYNAMIC SE with a few options on it? 24/33/36 could do 7.5k or 10k a year if it makes a difference. Thank you!
    10K
    .00265 and 70%
    .00211 and 61%
    .00211 and 56%
    10K
    .00265 and 70%
    .00211 and 61%
    .00211 and 56%
    Thank you! But ooof, these numbers end up looking pretty rough at over $1k a month for a 2 door.
    tmerriam said:
    10K
    .00265 and 70%
    .00211 and 61%
    .00211 and 56%
    Yeah, LR has never been known for good deals
  • beachbums12beachbums12 Member Posts: 7
    Hi, could I please get numbers for a 2022 Defender 110 X, 10k/year at 36 or 39 months? Thanks in advance!
    .00211 MF and 51% residual
    .00206 MF and 49% residual
  • Damian2505Damian2505 Member Posts: 97
    edited March 2022
    Can I get the MF and RV for a defender 110s 36/10 and 33/10 33033 zip code. Thanks
    .00211 MF
    68%/65% residual for 33/36 mo
  • bmacchiobmacchio Member Posts: 30
    Can I get the MF and RV for a defender 110 SE 33/10? 92009 zip
  • JPGSJPGS Member Posts: 28
    Can I please have the 24/10 and 24/15 MF & Residual for the 22' Defender in 06492:
    110 S
    110 X-Dynamic SE
    110 X-Dynamic HSE
    Appreciate your guidance very much.
    .00211 MF and 64% residual
    110 S
    110 X-Dynamic SE
    110 X-Dynamic HSE
    24/15
    .00265 MF
    78%
    70%
    67% residual
    +3% for 24/10
    Thank you so much!
    May I also have the numbers for the 2022 110 SE (non X-Dynamic).
    Apologies for the many requests. Trying to work with dealers on any inventory they might have.
    JPGS said:
    Thank you so much!
    72% RV for 24/15
    Same MF as above
