2022 Nissan Frontier Lease Deals and Prices
13468916
  • smarttouchsmarttouch Member Posts: 27
    Good morning,
    My local dealer quoted me 92% residual on Frontier s crew cab 4x2 for 18/10. Zip 91784
    He also sent me a part picture of the lease rate chart showing 92%. Do residual numbers have this much difference?
  • MichaellMichaell Moderator Posts: 268,959
    Good morning,
    92% is the 18/15 residual - they probably aren't doing the adjustment for the 10K allowance.
  • ddes24ddes24 Member Posts: 8
    Hi, looking for residual, MF and any incentives for January on 2022 Frontier ProX Crew Cab 4x2 (5ft bed)
    in zip 30024
    18mo 12k yr
    24mo 12k yr
    36mo 12k yr
  • kyfdxkyfdx Moderator Posts: 272,632
    in zip 30024
    18mo 12k yr
    24mo 12k yr
    36mo 12k yr
    .00227 MF
    88%
    83%
    71% residual
  • e46guye46guy Member Posts: 75
    Hi there! Can I get the residual and MF for a frontier s crew cab 4x4 for 18/10 in 84095?
    .00227 and 99%
  • marjon099marjon099 Member Posts: 26
    Hi - I am looking to lease a 2022 Nissan Frontier.
    Can you help me understand what the current MF and RV is for the S, SV, and Pro-4X.
    Lease would be for a 10k/36m for zip code 08550.
    Appreciate the time and info!
    New programs start tomorrow. Suggest waiting until then to ask your lease questions
    Thank you for the heads up. Will do.
    Hi, can you provide the MF and RV for the lease details above? Thanks!
  • BaseballplerBaseballpler Member Posts: 4
    Frontier Pro-4x
    18/10 and 24/10
    97220
  • John13333eJohn13333e Member Posts: 19
    **frontier 4 by 4 and 4 by 2 crew cab s and sv
    85286
    18/10 term **
    King Cab or Crew Cab?
    2WD or 4WD?
    Frontier Pro-4x
    18/10 and 24/10
    97220
    .00225 MF
    94%/89% residual
    85286
    18/10 term **
    .00227 MF
    S: 98%/95% residual for 4WD/2WD
    SV: 93%/90% residual for 4WD/2WD
  • tzinannitzinanni Member Posts: 86
    Can I get MF and Residual for 22 Frontier S Crew Cab 4X4 zip 60525.
    18/10
    18/12
    18/10
    18/12
    .00227 and 96%
    18/10
    18/12
    .00227 MF and 98% residual
  • nearyednearyed Member Posts: 11
    Hi, could you give the short term lease information on a 4x4 Pro-4x CrewCab, 10k miles - zip is 32901.
    edited February 2022
    Thank you everyone for lease info. I was finally able to get the truck on Jan 31.
    Crew cab , s trim 4 x 2, no packages , 31k msrp - $500 dealer last minute discount. 91784 zip.
    Dealer quoted 92% residual for 10k miles. There is a nissan finance bulletin that was released separately that clearly states to add 3% more to existing residual on 18 month/ 10 k miles lease only. Had to find this for the dealer.
    Final: $30500k, 0.00227 mf
    Dealer fees $573, lease fees$695, $200 some not desired dealer package. Total $1660 drive off. Lease amount $202 / month with taxes included.
    Thank you again for the Edmunds team that help with the lease numbers. 🙏
    .00225 and 94%
    Thanks for the report.
  • jmcortes93jmcortes93 Member Posts: 37
    hello can i get the residual and money factor for 75087 for the S crew cab in 4x2 and 4x4 for 18 and 24 months, thanks!
    What annual mileage allowance?
    ugh, i knew i was missing something, 10k please - for 12k is -1%, and for 15k is -3%?
    .00227
    95% / 90% for 4x2, 10K
    98% / 91% for 4x4
    -2% for 12K
    -3% for 15K
    .00225 and 94%
    Thanks!!
    .00227 and 99%
    Hi there, same for Feb?
    e46guy said:
    .00227 and 99%
    Nope.
    .00227 and 98%
  • Sluggah67Sluggah67 Member Posts: 51
    Hi, Can I get the February MF and RV for the 2022 Frontier Pro-4X Crew Cab?
    18 Month Lease / 12K per Year
    Zip Code 01867
    Thank You!
    Zip Code 01867
    Thank You!
    .00225 MF and 92% residual
    2WD or 4WD?
    4WD and King Cab.
    36m/10k for zip 08550.
    2WD or 4WD?
    4WD and King Cab.
    .00227 MF
    76%/72% residual for S/SV
    Pro 4-X (only available in Crew)
    .00225 MF and 77% residual
  • LpzLELpzLE Member Posts: 1
    Can I get the February MF and RV for the 2022 Frontier S Crew Cab 4x4?
    18 Month Lease / 10K per Year
    Zip Code 33540
    00327
    2WD or 4WD?
    4WD and King Cab.
    .00227 MF
    Thanks for the quick reply.
    Received the following for a Pro-4X: .00327 MF and 75% Residual
    What do you think? Seems off, especially their quoted MF.
    marjon099 said:
    00327
    2WD or 4WD?
    4WD and King Cab.
    .00227 MF
    The dealer cannot alter the RV; it's fixed by the bank.
    They can mark up the MF, however.
    Zip Code 33540
    .00227 MF and 98% RV
    marjon099 said:
    00327
    2WD or 4WD?
    4WD and King Cab.
    .00227 MF
    Gotcha, understood.
    Is the .00225 MF the regional average based on zip 08550?
    marjon099 said:
    marjon099 said:
    00327
    2WD or 4WD?
    4WD and King Cab.
    .00227 MF
    Gotcha, understood.
    It is the base rate for top tier credit
  • wcolwellwcolwell Member Posts: 5
    Looking for MF and Residual on a 2022 Frontier Pro4-X Crew Cab (4x4) 18/10 and 18/12
    Zip 23233
    I should also add a 2022 Frontier SV 4x4 Crew Cab same terms 18/10 18/12 MF RV please
    Zip 23233
    Pro-4X - .00225 and 92%
    SV - .00227 and 91%
    Zip 23233
    SV - .00227 and 91%
    do you have the terms for 18/10 as well? same vehicles?
    wcolwell said:
    Zip 23233
    SV - .00227 and 91%
    Add 2% for 10K
  • crni123crni123 Member Posts: 67
    Hi may I please get the numbers on the SV. 4x2 and 4x4 for 33462. Also any incentives currently 18/10 and 12
    King or Crew Cab?
  • WayneWayne Member Posts: 38
    MF/RESIDUAL please for:
    Frontier Crew SV 4x2
    Frontier Crew ProX 4x2
    Both 18/12k & 18/15k
    ZIP 34957
    ZIP 34957
    .00227 MF and 88%/87% residual
    Either trim
  • jennyjenjennyjen Member Posts: 113
    Thank you very much for the quick and concise info both on this board and others. Definately was challenging this time around chasing inventory, price and programs. Was able to get a S Crew Cab 4x4 $35.2 K (no markup) for $269 month- 18months/10K with only 1st payment out of pocket and 5 MSD's.
  • LoGiKLoGiK Member Posts: 98
    Can I please have MF and RV for 2022 Frontier S Crew Cab 4x4?
    18 months / 10k miles
    Zipcode: 33016
